another 40HP 1385 build
Page: Previous  1, 2
prkid424
prkid424 is offline
PostPosted: Fri Dec 30, 2016 1:51 pm    Post subject: Re: another 40HP 1385 build Reply with quote
Have decided on a FK41 cam and 1.25 rockers, Engle lifters, single HD springs...
hopefully the crank is in good shape and I wont need to rebuild that as well. Still keeping it under the $600. Haven't factored in any machine shop costs...hopefully none is needed and if so hopefully they wont break the bank.
Thoughts?
I'll continue to update this post with pics and current status.
Bulli Klinik
Bulli Klinik is offline
PostPosted: Sun Jan 01, 2017 11:25 am    Post subject: Re: another 40HP 1385 build Reply with quote
I've used both the 100 and C25. I really like the Engle 100 and it runs well with a stock carb.
I'd crank up the compression to 8.5:1 or so. I built a similar combo for a local Baja and it was crackin' little motor.
Mike K
Bulli Klinik
Colorado Springs
Matthew
Matthew is offline
PostPosted: Mon Jan 09, 2017 4:45 pm    Post subject: Re: another 40HP 1385 build Reply with quote
You need to stay really mild with the cam timing with such small heads and intake. I think the CB2280 "cheater cam" would be best. The Engle W100 would be max for that engine combo.
1965 Beetle sedan
Click to view image
prkid424
prkid424 is offline
PostPosted: Tue Jan 10, 2017 4:41 pm    Post subject: Re: another 40HP 1385 build Reply with quote
All parts just arrived. WOOHOO. Going to get my garage cleaned up and ready for the job!
bug_65
bug_65 is offline
PostPosted: Thu Jan 19, 2017 4:23 am    Post subject: Re: another 40HP 1385 build Reply with quote
with the extra lift of the cam be careful that your spring retainers dont bottom out on the valve boss. I had this problem which caused some grieve.
I m current running 1385 with engle 100 and 1.25.1 solid rockers, but only standard 1600 springs and appears to be ok for the past 4 years.
By the way dont listen to the bone heads saying put a 1600dp in. blah blah.
Something to be said that the little 40hp 1385 is more interesting.
prkid424
prkid424 is offline
PostPosted: Tue May 09, 2017 12:23 pm    Post subject: Re: another 40HP 1385 build Reply with quote
as with most projects, life got in the way....work, kids sports, etc. However some quick updates. All parts for this are in - which is good so I am not really waiting for anything. I have cleaned up and set up a dedicated space in my garage...so really its finding available time. I am finishing up a rear brake job / transmission flush and since the weather is starting to get really nice I may drive it as is for a while. Goal is to finish the engine before I go to OBX this August. Wanted to tow the Buggy down there and have some fun at the beach. I'll be sure to continue to update this thread in three parts, 1) tear down and inspection, 2) Clean up, rebuild 3) test and tune
Page: Previous  1, 2
Page 2 of 2
