Spring Washer on Fan
Bohdan
Bohdan is offline
PostPosted: Thu Dec 15, 2016 3:17 pm    Post subject: Spring Washer on Fan Reply with quote
Gents, I have a dilemma and I couldn't get a definitive answer so here it goes.
The washer that goes on the fan is labeled as a "spring washer". This is between the fan and the nut that holds the fan onto the generator/alternator shaft.
It is curved slightly to what I originally thought to match the curvature of the fan. Then the name of this nut is called "spring". So I thought maybe this goes with the concave opposite the fan so that when it tightens that it presses against the nut sort of like lock washer?
So which way washer to match the fan or opposite?
Mighty obliged.....
Al Capulco Premium Member
Al Capulco is offline
PostPosted: Thu Dec 15, 2016 4:17 pm    Post subject: Re: Spring Washer on Fan Reply with quote
Opposite, you want it to put a little pressure on the nut.
Danwvw
Danwvw is offline
PostPosted: Thu Dec 15, 2016 4:20 pm    Post subject: Re: Spring Washer on Fan Reply with quote
Yeah, It's almost impossible to get them to tighten right the other way they go opposite. Only need 39 ft lbs.
1971 VW Sundial Camper:
Build Sheet: Type 1 1679cc & W-100 Cam, Type1 1800cc's Webcam 118 and 1.25:1 Rockers, Type 1 1800cc with Webcam 163 my current daily driver.
Wildthings
Wildthings is offline
PostPosted: Sun Dec 18, 2016 9:37 am    Post subject: Re: Spring Washer on Fan Reply with quote
The spring washers don't offer much resistance to a fastener coming loose. What they are is a fairly high quality steel with offers a smooth slick surface for the fastener to slide against guarantying consistent torque. I usually will place them concave side down, but I don't think it makes much difference, as it is the torque on the fastener which ultimately keeps it from loosening and not the washer.
Bohdan
Bohdan is offline
PostPosted: Sun Dec 18, 2016 7:55 pm    Post subject: Re: Spring Washer on Fan Reply with quote
Thanks gents. I have elected to go opposite. Even though some literature that I. Saw from some diagram should the other way.
kreemoweet
kreemoweet is offline
PostPosted: Tue Dec 20, 2016 12:28 am    Post subject: Re: Spring Washer on Fan Reply with quote
'67 bug: seized by the authorities
Wildthings
PostPosted: Tue Dec 20, 2016 6:20 am    Post subject: Re: Spring Washer on Fan Reply with quote
kreemoweet wrote:
Interesting, too bad they didn't give the part number of the washer. Is a "dished" washer the same as a "spring" washer? or is it something different? The VW fiche for a Transporter shows a standard style spring washer with a Beetle part number of 111 119 135 and shows it being installed in the opposite direction.
Did later Transporters with Type 1 engines use the same 111 119 135 spring washer or is the dished washer shown in the service bulletin a different part?
For myself, my 1973 Thing uses the 111 119 135 washer.
kreemoweet
PostPosted: Tue Dec 20, 2016 12:04 pm    Post subject: Re: Spring Washer on Fan Reply with quote
They all use the same washer. Although the VW parts lists refer to it as a "spring washer", it is unlike the usual spring washers
in being asymmetric, i.e., there is a front and a back side, and therefore it matters which way it's installed. The W.B page above
calls it a "dished" washer, but it really is not that either. I really don't think the parts diagram above can be said to show it being installed
one way or another.
The Type I Bentley service manual also warns that the washer (called a "lock washer" there) must be installed as shown above.
citroen
citroen is offline
PostPosted: Tue Dec 20, 2016 6:18 pm    Post subject: Re: Spring Washer on Fan Reply with quote
kreemoweet wrote:
this might confuse you this is for a VW Bus that takes a different fan and it is hooked to a alt. this is not for a bug type engine this picture is a flat engine. this is what yours looks like
PostPosted: Tue Dec 20, 2016 10:32 pm    Post subject: Re: Spring Washer on Fan Reply with quote
I remembered it as 50 ft. lbs but I looked it up and it looks like 40-47:
kreemoweet
PostPosted: Tue Dec 27, 2016 12:08 pm    Post subject: Re: Spring Washer on Fan Reply with quote
No. The page I posted refers to a standard Type I 1600 upright engine, which many busses in the world had up to the late '70's. The same diagram (and warning), less
the big black arrows, is in the Type I 70-79 Bentley manual.
Bohdan
Bohdan is offline
PostPosted: Mon Feb 27, 2017 6:32 am    Post subject: Re: Spring Washer on Fan Reply with quote
Oh my goodness. I don't know why my nut loosens itself on the fan. I think I put enough muscle into it that nothing would be able to budge. (albeit, I didn't use a torque wrench). Has anybody had the same issues and how were they corrected? Threadblocker?
PostPosted: Mon Feb 27, 2017 10:34 am    Post subject: Re: Spring Washer on Fan Reply with quote
Is the washer in good shape? Sometimes they crack from age and wear.
40-47 pounds is sort of hard to do in place in the car as you have to hold the other side too. It's pretty easy if the generator and fan are in a vice.
