Rear wheel bearing
Page: Previous  1, 2
titan3c
titan3c is offline
PostPosted: Tue Apr 03, 2018 4:13 pm    Post subject: Re: Rear wheel bearing Reply with quote
I just checked and the listing is still there if you want to check it out. Bob
raygreenwood
raygreenwood is offline
PostPosted: Wed Apr 04, 2018 8:07 am    Post subject: Re: Rear wheel bearing Reply with quote
titan3c wrote:
There is four of them listed on here in the parts section, and I bought them. They were new old stock still in the original boxes still lubricated and wrapped. Also included the races. Very reasonable price----all four for $20.00. Bob
Thats a great deal! Get them Bob!
Also bear in mind....they may not come with outer races. Many times you need to buy those separate .
Wait....just looked. They show the outer race....great deal!
Oh....when you get them....wash,them in solvent ASAP and oil with ATF fof storage if you are not going to install them now. Looking at that oil they are just at the limit of time for starting to rust.
Ray
titan3c
titan3c is offline
PostPosted: Thu Apr 05, 2018 7:23 am    Post subject: Re: Rear wheel bearing Reply with quote
I did buy them and should receive them in a few days. Thanks for the advice to clean and store them. I don't intend to install them now, but will later when I can get some help, and the weather is a little warmer. My shop building isn't heated. Bob
titan3c
titan3c is offline
PostPosted: Mon Apr 16, 2018 5:19 am    Post subject: Re: Rear wheel bearing Reply with quote
I just got around to unwrapping these bearings, and they look pretty good. What should I use as a solvent to clean them? Also will just storing them submerged in a plastic container of ATF be ok? Bob
raygreenwood
PostPosted: Mon Apr 16, 2018 8:52 am    Post subject: Re: Rear wheel bearing Reply with quote
The best thing to clean bearings with is a fast evaporating carburetor cleaner like Berrymans B-12. But...any good mineral spirit will do....especially if you are then going to store them submerged in ATF...which is perfect for storage.
You can clean them with xylene/paint thinner....then blow them mostly dry with compressed air. If the bearings came with the outer race...rare in the last 20 years with most brands. I zip tie them to their outer race and store them in ATF. Ray
titan3c
titan3c is offline
PostPosted: Mon Apr 16, 2018 10:55 am    Post subject: Re: Rear wheel bearing Reply with quote
OK---thanks
Page: Previous  1, 2
Page 2 of 2
