How to lower a Bus and all lowering questions
Page: Previous  1, 2, 3 ... 89, 90, 91 ... 98, 99, 100  Next
mr. warehouse
mr. warehouse is offline
PostPosted: Fri Sep 29, 2017 9:29 am    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
KILLERWATT wrote:
Now that we're living in a time of 6 inch welded drop spindles. Can anybody give me an argument for why I would want adjusters in my beam? Seriously considering buying some plates and narrowing the beam myself without adjusters to save money, shipping and the wait time for a builder's beam.
Fone tuning the ride height.
I can usually have a beam out in a week. Depending on what you want, I may have it ready to go on the shelf.
vwchance
vwchance is offline
PostPosted: Thu Oct 05, 2017 4:49 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
I'm looking for some insight on my center pin and the adjustable beam that I'm working with. I don't have any proper diagram.
Here is a stock beam, the area where the spring washer sits.
Here is my beam. Its squared and the spring washer does not sit properly on top.
I have searched and can't find a similar situation.
Here are the parts I have. And the combination I have tried Am I missing something?
mr. warehouse
PostPosted: Thu Oct 05, 2017 4:53 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Knock the upper bushing up a bit so it catches the spring washer, but not so high it sits above it.
Cut the round dust shield so it fits over the square body of the beam.
64sunroofguy
64sunroofguy is offline
PostPosted: Tue Jan 16, 2018 9:32 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Ok I havent posted anything in a very looooong time. I have a 66 Kombi that is lowered with flipped spindles and an adjustable narrowed beam. The beam was made by a very reputable Bug beam builder but this was his first bus beam. Cut the stock torsions down to accomodate for the narrower beam and drilled new detents for the bolts on the trailing arms. I also used the bay tie rods and reamed the spindles so I could mount the tie rods on the bottom instead. So my problem is that my bus has ZERO front suspension. Meaning no downward travel at all. Rides like dog crap compared to mtbfriends buses. When I jump up and down on the bumper it DOES NOT MOVE! Its not bottomed out on anything that I can tell. I thought I did everything right. Any advice??
6sixTinBox
6sixTinBox is offline
PostPosted: Wed Jan 17, 2018 2:44 am    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Can you adjust your beam adjuster up? It sounds like it's at its lowest setting. Do you have shocks installed. Can you upload photos of your setup to get a better look at your beam?
This is for beam adjuster reference only of what you should try to adjust...
https://www.thesamba.com/vw/classifieds/detail.php?id=832840
1966 13 Window Deluxe
It is what it is
TDIvan
TDIvan is offline
PostPosted: Wed Jan 17, 2018 8:59 am    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Does anyone know who sells brand new straight axle spring plates (as in not a modified original)? I had seen them for sale a few years ago but I don't remember where.
still driving the holy snot out of buses
mr. warehouse
PostPosted: Wed Jan 17, 2018 1:21 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
I sell them.
Normal and 4" dropped.
Skim
Rants Master
Skim is offline
PostPosted: Thu Jan 18, 2018 1:17 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Sounds like your beam is completely bottomed out with the shocks completely compressed.
GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
mr. warehouse
PostPosted: Thu Jan 18, 2018 1:27 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Or when it was assembled, the arms were forced in.
64sunroofguy
PostPosted: Thu Jan 18, 2018 9:44 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Ya Skim. Its actually adjusted as high as it can go right now. And you saw it. Thats all the way up.
I thought same thing with shocks but it rides the same with or without shocks on. I cant remeber if I had to force control arms together to put spindle on. I’m Gonna pull everything apart completely tomorrow and just have a look see.
Outlaw1929
Outlaw1929 is offline
PostPosted: Sat Jan 20, 2018 5:26 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Can anybody tell me how far they are moving shock mount back when they cut new beam plates when Narrowing and lowering a bus beam? And is the shock mount stayed the same height as stock just moving back? Thanks guys
mr. warehouse
PostPosted: Sat Jan 20, 2018 8:41 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
I'm in Santa Rosa and have done beams waiting. If you want to grab one and be done with it, or you can come by and grab some measurements.
Outlaw1929
PostPosted: Tue Feb 06, 2018 11:52 am    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Thanks Greg, I’ll. Hallar at ya,
demon1018
demon1018 is offline
PostPosted: Tue Feb 27, 2018 5:45 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
I sell them.
Do you have new splined collars for those? I have a project that I have been looking for some of those but have had no luck
BATComm1
BATComm1 is offline
PostPosted: Sat Mar 10, 2018 3:24 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
I've looked around and got a few different answers...
Got a 66 bus that I am doing a IRS kit on, not going to slam it all the way down do to roads and such so my question is will a 6.5" wide wheel fit on the rear? I'm looking at some that are on a beetle now with no issues.
I support gay marriage...as long as both chicks are really HOT !!
1965 Beetle, 1966 13 window deluxe walk thru (SOLD) 84 Rabbit 16V Swap
mr. warehouse
PostPosted: Sat Mar 10, 2018 6:39 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
I sell them.
I do not. Try Nate @ WagensWest. He gets +/- $75 each for them I believe.
DubStyle
SBS Hit Squad
DubStyle is offline
PostPosted: Wed May 02, 2018 10:31 am    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Take some pictures, maybe something that looks normal to you, will jump out at someone here.
Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club"
TheVintageVw
TheVintageVw is offline
PostPosted: Mon May 14, 2018 1:22 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Been reading this post all the way thru and im confused Question
This might be a simple answer.
have a 66 bus, want to put in a 68 type 3 drum to drum tranny.
Other than nose cone and swing arm plates this is basically a bolt on affair right? could I just use 5 lug type 3 rear drums on the existing back plates?
I am reading mixed answers and can't figure it out.
Thanks in advance for your help
chris henry
chris henry is offline
PostPosted: Mon May 14, 2018 4:38 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
It is pretty much bolt in if you are using offset spring plates like the ones from wagons west of the bolt on kit from Old speed. If you go with a wolfgang style kit you will need to change the axle tubes to the longer ones supplied in the kit.
cdennisg
cdennisg is offline
PostPosted: Mon May 14, 2018 6:18 pm    Post subject: Re: How to lower a Bus and all lowering questions Reply with quote
Swap the nose cone to the type 2 style, offset spring plates will bolt up to your type 3 axle tubes, and a 4 to 5 lug adapter will make your stock wheels bolt on easily. The adapters may need some minor clearancing at the outer edges where they contact the raised ridge of the 4 lug drum.
Here is a 64 I built with this exact setup.
You can use 5 lug type 3 drums, but they are expensive and more difficult to find. 4 lug drums are much more common, and cheaper.
nothing
Page 90 of 100
