TheVintageVw Samba Member
Joined: July 19, 2004 Posts: 654 Location: Porter Ranch California
Posted: Mon May 14, 2018 8:11 pm Post subject: Re: How to lower a Bus and all lowering questions |
Will the ebrake bolt up?
Are the type 3 brake shoes the same between the 4 and 5 lug drums? |
mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5001 Location: Nor Cal 707
Posted: Tue May 15, 2018 6:59 am Post subject: Re: How to lower a Bus and all lowering questions |
halchka99 wrote: |
Been reading this post all the way thru and im confused
This might be a simple answer.
have a 66 bus, want to put in a 68 type 3 drum to drum tranny.
Other than nose cone and swing arm plates this is basically a bolt on affair right? could I just use 5 lug type 3 rear drums on the existing back plates?
I am reading mixed answers and can't figure it out.
Thanks in advance for your help |
Plenty of detailed info here - http://lowbus.com/BB/index.php |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Wed May 16, 2018 7:23 am Post subject: Re: How to lower a Bus and all lowering questions |
halchka99 wrote: |
You will need the e-brake cable extender available from wherever you buy your modded spring plates.
Brake shoes are the same, I think. _________________ nothing |
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Wed May 16, 2018 8:11 am Post subject: Re: How to lower a Bus and all lowering questions |
The 4 and 5 lug brakes use the same shoes. For a Type 3 rear, you can use 73-79 Super Beetle FRONT wheel cylinders and hardware (except hold down pins - too short). The Super Beetle shoes will fit, but are narrower. _________________ Tim |
BUSorBUST Samba Member
Joined: March 05, 2013 Posts: 42 Location: Laguna Beach
Posted: Tue Jul 24, 2018 6:51 pm Post subject: Re: How to lower a Bus: Adjusting Wagenswest Beefcake adjusters |
Hey All- just bought a panel and it came with a wagenswest beam with beefcake tooth style adjusters.
I want to lower it more- and it appears if I loosen the nuts and the adjuster on the outside swings upward that should allow the bus to go lower-
am I correct in my assumption?
Assumption #2- do I do the same amount of teeth for top and bottom tubes of the beam?
Thanks
Brian |
Split 66' Samba Member
Joined: October 07, 2010 Posts: 1255 Location: Bay Area, California
Posted: Thu Jul 26, 2018 1:01 pm Post subject: Re: How to lower a Bus and all lowering questions |
It would probably be best to ask Wagenswest these questions, to be certain.
I haven't adjusted my Bus Boys beam for almost 30 years now, but from what I remember, your assumptions are correct. The linkpins will bind if the top and bottom are too far off; that's about the worst that can happen.
Set the top and bottom adjusters, then put it on the ground and jump on the front bumper. If it's smooth, you should be in good shape. _________________ "OG = Original German" -- TheSamba.com dictionary |
Posted: Thu Jul 26, 2018 1:34 pm Post subject: Re: How to lower a Bus and all lowering questions |
Split 66' wrote: |
It would probably be best to ask Wagenswest these questions, to be certain. |
Best idea I've heard. Let Nate handle the customer service on his products, but I'll help...
Split 66' wrote: |
Set the top and bottom adjusters, then put it on the ground and jump on the front bumper. If it's smooth, you should be in good shape. |
Terrible idea.
Instead, put your beam on stands, loosen both adjusters and jack one (or both) wheels to where you *think* you want the ride height to be (remember it's going to compress a couple inches once set on the ground)
As you are jacking the wheel you will see the adjusters do NOT move the same.
If you set the adjusters in the same positions you are binding the beam. The upper and lower arms will be fighting each other causing a rough ride.
Set it on the ground, decide if it needs to go up or down (jumping up and down on the bumper shouldn't be necessary unless you have a poorly built beam with tight bushings and link pins)
Put it on stands, adjust as needed
Repeat |
Posted: Fri Jul 27, 2018 11:59 am Post subject: Re: How to lower a Bus and all lowering questions |
It took me three tries, years ago, to get to the lowest point, without binding.
I didn't use a protractor to set my spring plates either. It's not rocket science. _________________ "OG = Original German" -- TheSamba.com dictionary |
Posted: Fri Jul 27, 2018 12:08 pm Post subject: Re: How to lower a Bus and all lowering questions |
Split 66' wrote: |
I didn't use a protractor to set my spring plates either. It's not rocket science. |
There are different versions of lowered as well.
vs
It takes a bit more work to achieve the bottom photo |
Posted: Sun Jul 29, 2018 11:46 am Post subject: Re: How to lower a Bus and all lowering questions |
Yes, body and frame mods are not my thing. _________________ "OG = Original German" -- TheSamba.com dictionary |
Posted: Sat Aug 04, 2018 3:08 pm Post subject: Re: How to lower a Bus and all lowering questions |
If I’m installing a type 3 tranny with drums and backing plates, do I need to flip the backing plates so the wheel cyl sits on the bottom?
If I dont flip them it seems like I cant get the brake line to hook up. |
Posted: Sun Aug 05, 2018 1:44 pm Post subject: Re: How to lower a Bus and all lowering questions |
I put the T3 wheel cylinder up top, so that the weep hole for the trans oil overflow, is on the bottom.
I also used the e-brake extension tubes from WideFive, to get the e-brake cables on the bottom:
https://www.thesamba.com/vw/classifieds/detail.php?id=1973717 _________________ "OG = Original German" -- TheSamba.com dictionary |
Posted: Sun Aug 05, 2018 8:38 pm Post subject: Re: How to lower a Bus and all lowering questions |
How did you get the brake hard lines to match up to the wheel cyl being up top? I’m using the bus hard lines. |
Posted: Mon Aug 06, 2018 10:50 am Post subject: Re: How to lower a Bus and all lowering questions |
It's been about 7 years since I did the rear hard lines. I may have purchased actual T3 rear hard lines from ISP West.
I do know that the soft lines attach to the axle tubes, then I custom bent the hard lines from the axle tube mount, to the top position of the backing plate.
Maybe give ISP West a call and ask them what the length of T3 rear hard lines are, and then compare them to the length of the T2.
https://www.vwispwest.com/pg98
I used a cheap Harbor Freight brake-line bender wrench, to get the angles right.
I can get pictures if you need them. _________________ "OG = Original German" -- TheSamba.com dictionary |
Rustyscrew Samba Member
Posted: Wed Aug 08, 2018 2:33 am Post subject: Re: How to lower a Bus and all lowering questions |
Has anyone have issues with 3.5 inch flipped spindles with stock beam with 185/60/15? And then stock rear down one outer spline? I was thinking of going with this poor mans lowering. Any issues with this setup? |
Posted: Wed Aug 08, 2018 7:07 am Post subject: Re: How to lower a Bus and all lowering questions |
Rustyscrew wrote: |
Lowering the rear with the RGB's still in place will lead to extreme negative camber. It can work that way, but it looks goofy and can lead to odd tire wear and bearing oil starvation issues. But, it has been done before by many. _________________ nothing |
MrBusCo Samba Member
Joined: February 13, 2007 Posts: 1561 Location: stoughton, WI
Posted: Wed Aug 15, 2018 3:32 pm Post subject: Re: How to lower a Bus and all lowering questions |
I keep finding dead links and pic links. Is there a template to modify my stock spring plates for a SAK? where to drill, where to cut?
I have a bug SA trans, these long axle tubes with the large/long end castings, and long spline, long axles. What spring plates do I use?
Thanks _________________ Josh The Bus Guy formerly known as JOGR
BlazeCutUSA.com MrBusCo.com |
Posted: Wed Aug 15, 2018 4:14 pm Post subject: Re: How to lower a Bus and all lowering questions |
To use those axle tubes you either need to buy/build offset spring plates, or modify those tubes. You need to press those castings off the tubes, extend the tubes 1 1/8" (correct me if I am off) and press a short axle casting back on there.
I think jeremyrockjock posted a template for cutting the bus spring plates to fit the beetle axle tubes. _________________ nothing |
Posted: Wed Aug 15, 2018 4:27 pm Post subject: Re: How to lower a Bus and all lowering questions |
Thank you sir. _________________ Josh The Bus Guy formerly known as JOGR
mr white Samba Member
Joined: October 02, 2005 Posts: 1193 Location: beautiful Oregon & Mohave County, AZ
Posted: Fri Aug 31, 2018 7:39 pm Post subject: Re: How to lower a Bus and all lowering questions |
Still reading this thread. Lots to take in. Regarding shocks, Anyone have part numbers for a billstein shock for a bus that has flipped spindles with a straight axle? Reading continues. |
