BATComm1 Samba Member
Joined: April 28, 2011 Posts: 152 Location: Broken Arrow,Ok.
Posted: Sat Nov 03, 2018 12:30 pm Post subject: Re: How to lower a Bus and all lowering questions |
Anybody installed a Vintage VDub IRS conversion kit...I have one I bought several years back before my cancer fight started, just getting back to installing and have spring plate issues...cant get any answers out of them or return phone calls...
The adjustable spring plates seem to have bigger ends, by this I mean the ends that go into the torsion bar housing with the rubber mounts, they are larger in diameter and will not just push into the housing like the stock plates do..even using a little help from a dead blow and some poly lube, if I do get them to go in using the plate cover and the bolts when I take the cover off the plate will literally "pop" out of the housing.... any advise?? _________________ I support gay marriage...as long as both chicks are really HOT !!
1965 Beetle, 1966 13 window deluxe walk thru (SOLD) 84 Rabbit 16V Swap |
Filipke Samba Member
Posted: Fri Nov 16, 2018 1:31 pm Post subject: Re: How to lower a Bus and all lowering questions |
I have the same problem here with adjistable spring plates. But even whitout the rubbers in between i can not get the cover of the torsiebars over it...
The plates seem to be to thick...
mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5001 Location: Nor Cal 707
Posted: Fri Nov 16, 2018 1:33 pm Post subject: Re: How to lower a Bus and all lowering questions |
Filipke wrote: |
Who supplied these? They should have spacers to make up for the thicker (double) plates. |
Posted: Fri Nov 16, 2018 2:13 pm Post subject: Re: How to lower a Bus and all lowering questions |
I have the horseshoe as I call them spacers that were provided with my kit, but the bushing is still my issue I even went with the stock rubber bus bushing but it won't fit over the spring plate without ALLOT of help but still will not seat in the torsion tube....
My kit is from Bruce at Vintage VDub _________________ I support gay marriage...as long as both chicks are really HOT !!
Posted: Fri Nov 16, 2018 4:05 pm Post subject: Re: How to lower a Bus and all lowering questions |
I got a friend Who has bouth a set from https://type2detectives.com/collections/suspension...onor-parts
He has rubbers bushes That are wither on the inside diameter.
I am going to try and adjust my bushings. I have flipped them inside out an then hold them against a grinder. Then Flip them again. That way i have made the inner circle larger...
I got my set Together with the bus.
At That time i didn't took the time to check everything out, and did not have That info About al those things. Now i am placing this and run into a problem every now and then... |
Posted: Sun Mar 10, 2019 3:28 pm Post subject: Re: How to lower a Bus and all lowering questions |
I am installing my handbrakes or meergebruikerssysteem brakes on a Splitbus 64
I have irs of a Beetle and type 3 brakes
The handbrake cable That i have seems to be to short.
I know i have to shorten the spring and i have a small bushing/adaptor where the cable Goes into the back of the brakes.
Do i just need to switch the left side with the right one? So the hole fir the handbrake is at the top instead of at the bottom?
This is What i have right now...
tdubz510 Samba Member
Posted: Mon Jul 01, 2019 2:53 pm Post subject: lowered bus and tire choices |
cdennisg wrote: |
In these pics I have changed the rear tires to 205/65's on custom offset rims. I had the outer hoop removed and moved outward 5/8" for springplate clearance for the wider tire.
I can't find a good pic of the tires from before this change. |
Those wheels look NICE!
Who did the custom offset rear rims??
I like that idea A LOT..
Todd |
jeffff Samba Member
Joined: February 23, 2006 Posts: 1044 Location: Alberta, Canada
Posted: Wed Jul 10, 2019 10:51 am Post subject: Re: How to lower a Bus and all lowering questions |
My rear wheel cylinders are leaking....my 62 has IRS but I don't know what drums were used.
What is the easiest way to find out? |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13271 Location: Tejas!
Posted: Wed Jul 10, 2019 11:30 am Post subject: Re: How to lower a Bus and all lowering questions |
jeffff wrote: |
take pics, post them here, we will help _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
jeffff Samba Member
Posted: Sat Jul 13, 2019 10:57 am Post subject: Re: How to lower a Bus and all lowering questions |
Erik G wrote: |
jeffff wrote: |
take pics, post them here, we will help |
Here ya go:
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Sat Jul 13, 2019 1:34 pm Post subject: Re: lowered bus and tire choices |
tdubz510 wrote: |
Todd |
Watt Wheel in Spokane, WA. They are no longer in business after something like 50 years of doing wheel work.
Other places will do this job for you. It's pretty simple. As I recall it was about $75 to do both. _________________ nothing |
peecee69 Samba Member
Joined: January 27, 2005 Posts: 1572 Location: Annapolis, MD/Bloomfield Hills, MI
collinscott Samba Member
Posted: Fri Jul 26, 2019 10:13 am Post subject: Re: How to lower a Bus and all lowering questions |
peecee69 wrote: |
I'd like opinions on getting dropped spindles vs. an adjustable beam. I have plans to put a ball joint beam from a '69 bus in my DC, and was wondering for a mild lowering job (1"-2.5") if there are reasons to go one way or the other. |
I have both 2" narrowed adjustable beam, and drop spindles on my DC. Tricky part about the adjustable beam is welding the adjusters in the correct position for how low you want the bus to be. I welded mine when I was 16, so naturally it is now (11 years later) much lower than I prefer it to be.
I like the adjustable beam, now has been moved to the "bottom" of the adjusters (raising the bus) and sits very nice and rides well. Pro Adjusters due to the flexibility of dialing in the ride height as you finalize tire size, and in my case - how heavy you are to get the bus to sit just right.
Drop spindles are nice, due to the fact there's now extra fab work to set up the beam.
There are definitely others here that have more experience but that's my 2 cents. _________________ 1960 Kombi
1963 W/T Double cab
1959 356A Coupe |
Posted: Fri Jul 26, 2019 10:26 am Post subject: Re: How to lower a Bus and all lowering questions |
collinscott wrote: |
peecee69 wrote: |
There are definitely others here that have more experience but that's my 2 cents. |
Oh yeah - you have the ruby red walkthrough! That's a beautiful DC! Glad you finally finished it. Or at least got it driveable. I was following that thread in 2010 when it went dead, was happy to see some closure to it. _________________ 1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
1966 Doublecab - Starting resto - https://www.thesamba.com/vw/forum/viewtopic.php?t=668518&highlight= |
Vintagespeed Samba Member
Joined: October 01, 2005 Posts: 579 Location: Westerlo (Belgium)
Posted: Wed Oct 09, 2019 7:54 am Post subject: Re: How to lower a Bus and all lowering questions |
when lowered just one spline with RGB's, would a sealed oil bearing be advised? Do I need to notch the spring plate?
I'd like to keep my stock tranny with RGB and just have a mild drop, so not two splines or flipped RGB's.
Any advise? |
Carlp336 Samba Member
Posted: Wed Oct 09, 2019 5:41 pm Post subject: |
hey all, after rear plate install. on the horseshoe side of the plate that goes around axle tube there appears to be forward and back slides, is there a procedure for setting that? |
Posted: Wed Oct 09, 2019 6:29 pm Post subject: Re: How to lower a Bus and all lowering questions |
Vintagespeed wrote: |
Any advise? |
One spline inner, or one spline outer? They are different and you will get different results with each.
I would advise combining adjustments of inner and outer to achieve the amount of drop you want, then find out if bearings may be an issue. _________________ nothing |
Posted: Wed Oct 09, 2019 6:33 pm Post subject: |
Carlp336 wrote: |
Those are for adjusting your toe-in setting. In my experience, they need to be slid all the way to the back of the notch. Yours may be different.
Toe-in and camber change with ride height, load, and bumps. You need to dial it in with the bus full of its normal weight load, and with the suspension settled in after rolling forward a bit. Sometimes it takes a few times to get it just right. _________________ nothing |
Posted: Wed Oct 09, 2019 6:42 pm Post subject: |
cdennisg wrote: |
Carlp336 wrote: |
Toe-in and camber change with ride height, load, and bumps. You need to dial it in with the bus full of its normal weight load, and with the suspension settled in after rolling forward a bit. Sometimes it takes a few times to get it just right. |
thanks! |
Posted: Thu Oct 10, 2019 7:32 am Post subject: |
cdennisg wrote: |
Carlp336 wrote: |
measure the same target and method as front toe ? |
