Zacrash65 Samba Member
Joined: August 08, 2006 Posts: 7 Location: Salt Lake City, UT
Posted: Thu Feb 25, 2021 4:01 pm Post subject: Re: How to lower a Bus and all lowering questions |
That's super helpful! I appreciate it.
I'm sure I'll have to contend with old stuff settling - but having a launch point to start from is mucho bueno! |
FandFVintage Samba Member
Posted: Mon May 31, 2021 5:24 pm Post subject: Re: How to lower a Bus and all lowering questions |
Alright guys.. here is how you lower your bus.
Trade me your stock height late-split set up and done. 😬
I’ve got an adjustable WagensWest beam with disc drop spindles, offset and notched spring plates. Trans pops out of 4th gear sometimes so that may need some addressing. Tires included as I won’t need them once I’m back at stock height.
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Mon May 31, 2021 7:04 pm Post subject: Re: How to lower a Bus and all lowering questions |
FandFVintage wrote: |
I’ve got an adjustable WagensWest beam with disc drop spindles, offset and notched spring plates with IRS. Trans pops out of 4th gear. Tires included as I won’t need them once I’m back at stock height. |
Place a "want to trade" ad in the classified section on here. You will get most of what you need. _________________ nothing |
Splitsundial Samba Member
Joined: May 30, 2020 Posts: 1 Location: Escondido, CA
Posted: Fri Jun 11, 2021 9:42 pm Post subject: Re: How to lower a Bus and all lowering questions |
Erik G wrote: |
Vintagespeed wrote: |
when lowered just one spline with RGB's, would a sealed oil bearing be advised? Do I need to notch the spring plate?
I'd like to keep my stock tranny with RGB and just have a mild drop, so not two splines or flipped RGB's.
Any advise? |
I had no issues on my reduction box lowered bus, and it was my daily driver for years. I did not notch the plates, Bearings were standard
What are the tire and wheels specs? What was front lowered on? |
FeveredMind Samba Member
Joined: December 28, 2016 Posts: 147 Location: Riverside, CA
Posted: Thu Mar 10, 2022 9:21 am Post subject: Re: How to lower a Bus and all lowering questions |
I posted these images in my build thread but I thought I would post them here too to see if the lowering geniuses here can help.
Can anyone tell me if this will work for lowering my bus? I believe so. It appears to be a late beetle IRS case, but modified to SA with what looks like a long casings, so probably 68 and up axles, correct?
Also, any idea what those brakes might be? The drums are 5 lug.
_________________ New to split window busses but learning new things everyday. This forum is a wealth of knowledge. Thank you everyone for sharing.
Last edited by FeveredMind on Thu Mar 10, 2022 10:43 am; edited 2 times in total |
Posted: Thu Mar 10, 2022 9:33 am Post subject: Re: How to lower a Bus and all lowering questions |
Definitely long axle tubes and end castings. Likely from a 68 bug. Can't tell for sure on the drums, but they are either Thing drums, or early type 3, or modified early bus. Lets see a photo of the drum face, and better yet, pull one off and show us the brakes and the inside of the drum. _________________ nothing |
Posted: Thu Mar 10, 2022 10:39 am Post subject: Re: How to lower a Bus and all lowering questions |
cdennisg wrote: |
Definitely long axle tubes and end castings. Likely from a 68 bug. Can't tell for sure on the drums, but they are either Thing drums, or early type 3, or modified early bus. Lets see a photo of the drum face, and better yet, pull one off and show us the brakes and the inside of the drum. |
Once the trans arrives at my house, I'll definitely take a few more. This trans was given to me from the kind gent with the cherry picker, so can't beat that. My dad is driving it down to me next week. _________________ New to split window busses but learning new things everyday. This forum is a wealth of knowledge. Thank you everyone for sharing. |
Posted: Thu Mar 17, 2022 7:25 pm Post subject: Re: How to lower a Bus and all lowering questions |
So the trans just arrived and I’m going to have to wait until tomorrow to try and get the drums off but until then here are two pictures that may help decipher what we are working with here. Those drums are definitely not “stock”.
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Fri Mar 18, 2022 9:15 am Post subject: Re: How to lower a Bus and all lowering questions |
It looks like the earlier style type 3. Later type 3 were 4 lug with a separate hub/drum setup. Either can be used on your axles, but the 4 lug would require adapters to run wide 5’s. Your drums have had studs installed. The type 3 gives you bigger diameter brakes than the type 1 that would have been stock on that axle. For rebuild parts, check here:
https://vwispwest.com/
Some type 3 are getting harder to find, but the good news in this case is late Super Beetle FRONT wheel cylinders and hardware kits are the same as type 3 rear (cheaper and easier to get). The shoes are not. _________________ Tim |
Posted: Fri Mar 18, 2022 10:30 am Post subject: Re: How to lower a Bus and all lowering questions |
Krustybus wrote: |
Some type 3 are getting harder to find, but the good news in this case is late Super Beetle FRONT wheel cylinders and hardware kits are the same as type 3 rear (cheaper and easier to get). The shoes are not. |
Thanks for the reply. I was hoping these brakes were type 3. I like the idea of the added stopping power.
I did notice the studs as well. Ill have to get the drum off to see if those can be removed. I don't mind trying to track down some new drums.
If I pick up wide 5 replacement drums, do I still need to run a spacer for spring plate clearance on 15" stock bus wheels? I have read through the thread and this still puzzles me a bit. _________________ New to split window busses but learning new things everyday. This forum is a wealth of knowledge. Thank you everyone for sharing. |
Posted: Fri Mar 18, 2022 3:13 pm Post subject: Re: How to lower a Bus and all lowering questions |
Sorry, can’t answer that question. I’ve only used early (no spacer or adaptor) and late (just adapter) with aftermarket wheels.
Be aware that with the larger diameter drum and lowered height, it can be challenging to get the tires on and off.
Also, I was able to get 5 lug drums at ISP, but that was last October. _________________ Tim |
DevinHite Samba Member
Joined: May 09, 2016 Posts: 111 Location: Stafford, Va
Posted: Mon Mar 28, 2022 8:35 am Post subject: Re: How to lower a Bus and all lowering questions |
I have a 61 bus, can I swap the axels on the stock transmission to be able to lower the bus using 68 bug axels and tubes?
Or would it be an easier task to just replace the entire trans with a 68 bug trans/motor? I want to keep the matching numbers trans and motor installed, just need to know what I’m up against. Would also like to get rid of the gear reduction on the bus as well. |
Posted: Mon Mar 28, 2022 2:16 pm Post subject: Re: How to lower a Bus and all lowering questions |
The gears in the reduction boxes reverse the direction of axle rotation. Simply swapping out axles will leave you with 4 reverse gears and 1 forward. You can pull the trans apart and flip the ring gear to the other side. You may want to consider swapping in a complete type 1 trans and putting your numbers matching unit in storage in the event you want to go back stock. You would need a bus nosecone and hockey stick for the type 1 swap. _________________ Tim |
MrPolak Samba Member
Joined: June 20, 2004 Posts: 1337 Location: AG ,atnaltA
Posted: Mon Apr 18, 2022 2:43 pm Post subject: Re: How to lower a Bus and all lowering questions |
BATComm1 wrote: |
Anybody installed a Vintage VDub IRS conversion kit...I have one I bought several years back before my cancer fight started, just getting back to installing and have spring plate issues...cant get any answers out of them or return phone calls...
The adjustable spring plates seem to have bigger ends, by this I mean the ends that go into the torsion bar housing with the rubber mounts, they are larger in diameter and will not just push into the housing like the stock plates do..even using a little help from a dead blow and some poly lube, if I do get them to go in using the plate cover and the bolts when I take the cover off the plate will literally "pop" out of the housing.... any advise?? |
Has this been solved? Vintage VDUB is the only complete kit I can find.
https://www.vintagev-dubs.com/shop/irs-conversion-kit-transmission-split-window-bus-56-67/
Adam47374 Samba Member
Joined: September 14, 2014 Posts: 36 Location: Richmond, in
Posted: Fri Apr 22, 2022 9:54 pm Post subject: Re: How to lower a Bus and all lowering questions |
So having my transaxle rebuilt, with gear reduction boxes. The shop asked if I wanted to go straight axel instead. If I planned on lowering it, now is the time, and they have the correct tubes and axels...
So if I go that way, from what I'm seeing I need to modify the trailing arms, and then add dropped spindles on the front, for a total of a 3.5" drop. What year rear brakes would I use from a type 3 to get wide 5? Can I run the stock size tires (even on just the rear), or is that not going to happen? Later I would like to get some 17" wheels, will that change anything?
Can I lower the front some other cheap way for the short term, then next winter go to the dropped spindles?
Just trying to get an idea how much extra this is going to run me, don't plan on hauling anything in this bus, so weight isn't an issue. However I'm not trying to spend too much money doing this, since I'm also getting my bug back on the road at the same time.. It's killing the budget already as is. _________________ 1968 Bug 2nd owner
1974 Brazilian Split Window Ambulance
2017 GTI |
Posted: Sat Apr 23, 2022 8:20 am Post subject: Re: How to lower a Bus and all lowering questions |
If drop spindles don't seem inexpensive enough for you to do this now, don't lower your bus.
Drop spindles are pretty cheap, and lowering your bus can be a simple thing. But if saving money is more important that building your lowered bus properly, then keep it stock and have that trans rebuilt with stock RGB setup. _________________ nothing |
Ragtop Samba Member
Joined: November 23, 2003 Posts: 615 Location: Rio Rancho New Mexico
Posted: Mon May 02, 2022 4:32 pm Post subject: Re: How to lower a Bus and all lowering questions |
If I'm using offset spring plates with long axle and long tubes do I use the 311 501 311 A bearing cap?
Thanks in Advance |
Pacblue63 Samba Member
Posted: Wed May 25, 2022 8:07 pm Post subject: Re: How to lower a Bus and all lowering questions |
Like to kno what i will need to run 17” brms on my 1962 singlecab
Currently have front flipped spindles rear is stock big nut trans w/rgb’s
Any info is helpful
Thank you Samba members |
NUTSFORBUSES Samba Member
Joined: December 08, 2016 Posts: 558 Location: I don't recognize it anymore
Posted: Thu May 26, 2022 10:45 am Post subject: Re: How to lower a Bus and all lowering questions |
IF you run 17's, you are likely to end up with Rubber Band style tires.
You will sacrifice any decent ride.
Any lowered Bus, I would recommend OIL Adjustable Koni's at 4 corners. _________________ kaiser kills kids.com |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13270 Location: Tejas!
Posted: Thu May 26, 2022 5:08 pm Post subject: Re: How to lower a Bus and all lowering questions |
MrPolak wrote: |
BATComm1 wrote: |
I don't believe this advertiser is allowed to sell here any longer. Terrible rep, questionable workmanship, etc. You would be better off to delete that post |
