Bohdan Samba Member
Joined: November 21, 2007 Posts: 143 Location: Venice, Florida
Posted: Sun Dec 18, 2016 8:08 pm Post subject: Shock absorbers |
Hey gents, is it possible that bad shocks can make the front shimmy? Not every time, at 40 mph , I will get a severe shimmy. It's not every time. Possible that by chance at a certain frequency that it can do this? Mighty obliged |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Mon Dec 19, 2016 5:45 am Post subject: Re: Shock absorbers |
I doubt it since they are just there for rebound damping. IS it happening when you go over a bump or rough spot in the road? How are your ball joints, tie rod ends, tires, etc? |
Bohdan Samba Member
Posted: Mon Dec 19, 2016 6:51 am Post subject: Re: Shock absorbers |
New tie rods on both sides. Tires are okay from observation. Appears ball joints are okay. Put in a new steering damper too. Apparently, happens just sporadically. Not over a bump or anything. Seems that I do something at the right frequency and then the planets line up and shakes the car. That is why maybe the shocks. Cheers |
Posted: Mon Dec 19, 2016 4:20 pm Post subject: Re: Shock absorbers |
How about front end alignment, and rebalancing the tires? Would be my first task ahead of replacing front end components. |
Das67bus Samba Member
Joined: April 06, 2008 Posts: 242 Location: Prescott, AZ
Posted: Mon Dec 19, 2016 7:16 pm Post subject: Re: Shock absorbers |
[email protected] wrote: |
I would say this is the answer. Wheel balancing makes a big difference along with alignment. _________________ SLOW RIDE........TAKE IT EASY!!!
-Foghat
COMFORTABLY NUMB!!
-Pink Floyd |
Joe 20 Samba Member
Posted: Mon Dec 19, 2016 8:54 pm Post subject: Re: Shock absorbers |
I had it happen on a Willys, same thing...believe it or not tire pressure was off on one side. Aired them both up the same...no more problem...Just FYI |
74 Thing Samba Member
Posted: Mon Dec 19, 2016 11:54 pm Post subject: Re: Shock absorbers |
Wheel/tire balance would be my suggestion too. If the front tires are old replace them as well. |
Bohdan Samba Member
Posted: Tue Dec 20, 2016 6:07 am Post subject: Re: Shock absorbers |
Thanks guys. That is a good idea. It would need to be done anyhow. THnaks again. Cheers |
