bastardbus Samba Member
Joined: July 13, 2000 Posts: 1768 Location: Toledo, Ohio
Posted: Sun Dec 18, 2016 9:58 pm Post subject: Will a `70 beam fit into a `71 bus |
`71 bus and owner wants wide five drums instead.
I know the late `69-`70 beams had the later bolt pattern same as `71-`79. Will the late `69-`70 drum beam mount up to the `71 bus with minor mods?
Thanks _________________ Samba Member #95 |
60's Burnout Samba Member
Joined: December 10, 2006 Posts: 424 Location: SF Bay Area
Posted: Sun Dec 18, 2016 10:29 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
You've got the good brakes; the discs. Why you want to go retro-grade to drums???? They may look 'kool', but the third or fourth time you jump on the brakes and they pull hard to one side because they need adjusting, you'll wish you had the discs.
I had a '68 with the wide 5 and hung '73 discs on it just to get away from those drums. There is a reason they don't use drums on front axles for the last 45 years....but if you're determined..... |
Posted: Sun Dec 18, 2016 10:35 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
Not my bus dude..customer wants em.
I daily drove a split beetle with no syncros, cable brakes and 16's for years and was fine. If your bus is jumping around with drums you have problems in your system it is NOT the design. This guy will be A.O.K. with drums instead of discs on his fat chick, don't worry bout him worry bout yourself (and why your cars jump all over the place when you hit the brakes).
Now if for ONCE I can get a damn straight answer to a super simple question on the Samba without all the opinion crap on what this guy wants on his bus that would be a friggin' X-mas miracle.
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sun Dec 18, 2016 10:43 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
Yes I believe you can do the swap. Someone is going to want that 1971 beam with booster and MC _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Sun Dec 18, 2016 10:52 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
Thanks for the straight answer man...yes the `71 beam will be available for sale or trade for a late `69-`70 beam with wide mounts. I see a couple on the classifieds just wanted to make sure there was no other funny mounting differences between the `70 and `71.
I also have several other really nice split bus era beams available if someone has a `70 to swap as well.
t _________________ Samba Member #95 |
Trashman Samba Member
Joined: May 18, 2016 Posts: 280 Location: Santa Cruz, CA
Posted: Sun Dec 18, 2016 11:00 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
It should bolt up just fine but I have heard of people with a 69 with the early bolt pattern before. I would go for a 70 beam if you have the choice just to play it safe. Just in case, you can always measure the new beam to see if it has the right pattern. Here's a picture with all the measurements (used to make a narrowed beam). The bottom two holes that show to be 207,00 apart are the later pattern, and the holes above those showing 163,50 apart are the earlier pattern.
Hope this helps. _________________ Bagged 1968 Neptune Blue "Deluxe" |
VWsArent4Hippies Samba Member
Joined: April 13, 2005 Posts: 3079 Location: The Bull City
Posted: Mon Dec 19, 2016 8:05 am Post subject: Re: Will a `70 beam fit into a `71 bus |
You'll just have to get creative with the master cylinder mounting. Or you could leave the booster/ beam, and just swap from the spindles out. Then you'll have boosted drums, which is nice |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
dasdachshund Samba Member
Joined: March 29, 2010 Posts: 728 Location: Vancouver, WA USA
Posted: Mon Dec 19, 2016 9:14 am Post subject: Re: Will a `70 beam fit into a `71 bus |
I've got a '71+ beam from WagonsWest on my '70. Bolted on with no mods whatsoever. So I assume the opposet will be fine. (watchout assuming)
-dasdachshund |
Manfred58sc Samba Member
Posted: Mon Dec 19, 2016 1:01 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
Yes, it will bolt in w/o issue. I have seen early pattern up till 8-69 builds, that seems to be the change-over time to 70+ style. Boosted drum brakes are very nice . _________________ Fat chick owner/operator |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Mon Dec 19, 2016 1:45 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
I bolted a 1971 beam into a 1970 way, way back in the 1980s but I don't think they have shrunk much since then. _________________ .ssS! |
Posted: Mon Dec 19, 2016 6:15 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
VWsArent4Hippies wrote: |
Really, So the spindle mounting is the same for any of the ball joint beams and I could swap in drum brake spindles and parts from a 68-70 bus?? Hmmm very interesting and that would save a lot of busy work. Especially since I would not have to find a specific late 69-70 beam. I am guessing I could just get the spindles-drums off any early drum bay window. Correct me if I am wrong.
Thanks, some great info guys, I am pretty well versed in split stuff but not up to date on bay stuff so much. Have owned my fair share of bays over the past 20+ years and indeed those power brakes are NICEEE! but will see what the owner wants. Right now he is jonesing for a `68-`70 deluxe pass bus and found a nice `71 and asked me if I could do the conversion to wide fives for him...so here we are.
let me know on the spindle thing if any of the drum bays would work fo-sure....tanks! _________________ Samba Member #95 |
VWDog Samba Member
Joined: June 24, 2005 Posts: 617 Location: Ladysmith, BC
Posted: Mon Dec 19, 2016 10:40 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
I can't really ad anything to what people have said here, but I was wondering if your customer is actually after drum brakes, or just a bolt pattern? I myself like the earlier wide 5 hubcap, so I 'put up' with the drums(besides, I am used to them and have driven many thousands of "drum" miles without incident). Friends of mine hate drums and don't have my hubcap fetish. I guess my desire to have those early caps comes from my family's 70 Westy bought back in 1970...maybe your customer has the same affliction? Isn't there some sort of adapter plate to go from 5x112 to 5x205? ...Just a thought...worth, well, about 2 cents _________________
1970 Lotus White Single Cab 2015- , 1979 Sage Green 2014-2015, 1978 Dakota Beige Westy 2012-2015, 1978 Neptune Blue Riviera 2012-2017 , 1970 Neptune Blue Bus 2010-2012, 1970 Deluxe Savannah Beige 2010-2012, 1985 Iltis 2010- , 1962 Single Cab 2010-2013, 1975 Brasilia? Bay/Split Kombi from Brazil 2008-2011, 1985 DoKa 1999-2009, 1971 Bus 1999-2000, 1968 Double Cab 1991-1998, 1965 Ghia 1987-1991, 1970 Westfalia-bought by Mum and Dad in 1970, sold by me in 1993 why-oh-why :_(
Posted: Mon Dec 19, 2016 10:46 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
bastardbus wrote: |
let me know on the spindle thing if any of the drum bays would work fo-sure....tanks! |
That's correct. Just note that if you're doing balljoints at the same time, and end up swapping in 68-69 trailing arms for whatever reason, they use a shorter lower shock mounting stud so you have to use the shock and/or spacer combo that matches. |
Posted: Mon Dec 19, 2016 10:50 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
VWDog wrote: |
I can't really ad anything to what people have said here, but I was wondering if your customer is actually after drum brakes, or just a bolt pattern? I myself like the earlier wide 5 hubcap, so I 'put up' with the drums(besides, I am used to them and have driven many thousands of "drum" miles without incident). Friends of mine hate drums and don't have my hubcap fetish. I guess my desire to have those early caps comes from my family's 70 Westy bought back in 1970...maybe your customer has the same affliction? Isn't there some sort of adapter plate to go from 5x112 to 5x205? ...Just a thought...worth, well, about 2 cents |
A lot of people don't like the idea of running adapters. Those 5x112 to 5x205 adapters also add a lot to your track width. I think at least 1/2" per side |
VWDog Samba Member
Posted: Mon Dec 19, 2016 11:08 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
VWDog wrote: |
With an appropriate rim choice, couldn't that be mitigated by offset? _________________
Mr Beckstar Samba Member
Joined: April 11, 2015 Posts: 25 Location: The Entrance, NSW, Australia
Posted: Tue Jan 24, 2017 4:43 am Post subject: Re: Will a `70 beam fit into a `71 bus |
68Transporter wrote: |
..... The bottom two holes that show to be 207,00 apart are the later pattern, and the holes above those showing 163,50 apart are the earlier pattern.
Hope this helps. |
Excellent info thanks 68Transporter. |
airschooled Air-Schooled
Posted: Tue Jan 24, 2017 1:20 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
For the record, even though this is an old thread:
The split bus enthusiast in question can use 64-70 drum spindles, on ANY ball joint bus beam. The backing plates and drums work in a matched set, either 64-68 or 69-70. Regardless, the shoes and wheel cylinders are the same too.
Once the front is taken care of, I hope the customer knows that they will have to deal with the rears as well…
Boosted drum brakes are a hoot. Hope the customer is happy.
www.airschooled.com |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Tue Jan 24, 2017 3:46 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
All of this done with the proper use of the apostrophe.... I'm an ecstatic grammar curmudgeon today! _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Tue Jan 24, 2017 4:51 pm Post subject: Re: Will a `70 beam fit into a `71 bus |
TomWesty wrote: |
All of this done with the proper use of the apostrophe.... I'm an ecstatic grammar curmudgeon today! |
Welcome to The Samba.
Where we have downgrading of braking systems and we can still find time to police the grammar of the forum. I love it.
