ebennett Samba Member
Joined: December 18, 2003 Posts: 280 Location: West Chester PA
Posted: Mon Dec 19, 2016 12:14 pm Post subject: Eagle Racing Cams - 385 lift 252 degrees |
Attention engine builders. I need some guidance on how this cam shaft should be applied.
Thoughts on this cam, what would it be ideal for? Would the note "1466 - Hydr." be an indication that it requires hydraulic lifters?
_________________ GDTRFB
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Mon Dec 19, 2016 6:11 pm Post subject: Re: Eagle Racing Cams - 385 lift 252 degrees |
it does not say if the duration is at lash or at .050, and I'm not sure which one it would be
what is stamped on the cam? |
slalombuggy Samba Member
Posted: Tue Dec 20, 2016 6:49 am Post subject: Re: Eagle Racing Cams - 385 lift 252 degrees |
Just phone CB Performance. It's their cam, and their customer service is great.
brad |
Posted: Mon Jan 09, 2017 8:36 am Post subject: Re: Eagle Racing Cams - 385 lift 252 degrees |
modok wrote: |
I updated the original post with images of the cam but not sure if they are relevant
slalombuggy wrote: |
brad |
I think that is exactly what I will do! _________________ GDTRFB |
midtravelmidengine Samba Member
Joined: August 06, 2009 Posts: 861 Location: Riverside, Ca
Posted: Mon Jan 09, 2017 8:42 am Post subject: Re: Eagle Racing Cams - 385 lift 252 degrees |
DAMN!! that is a PEAKY cam lobe _________________
modok wrote: |
And I know you don't know because if you did you would know the reason for my knowing you didn't. |
youngnstudly wrote: |
I just wasn't sure if I should recommend the 1/3 race cam, the 1/2 race cam, or the 5/8 race cam instead...guess it depends on how much of the race he wants to lead???
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Mon Jan 09, 2017 9:01 am Post subject: Re: Eagle Racing Cams - 385 lift 252 degrees |
midtravelmidengine wrote: |
DAMN!! that is a PEAKY cam lobe |
That's what I noticed!
Ebennett- what's written on the end of the cam where the gear bolts up? _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
mark tucker Samba Member
Posted: Mon Jan 09, 2017 11:38 am Post subject: Re: Eagle Racing Cams - 385 lift 252 degrees |
Im not a fan of that kinda lobe, but they work......call cb, yup liiks to be a hyd cam, and a mild one at that. |
fastfil Samba Member
Joined: November 25, 2006 Posts: 356 Location: Sunshine Coast, AUS
Posted: Mon Jan 09, 2017 12:25 pm Post subject: Re: Eagle Racing Cams - 385 lift 252 degrees |
x2
Careful you don't cut yourself on that lobe. _________________ "...swingaxle...transaxle...same diff." |
Posted: Mon Jan 09, 2017 12:29 pm Post subject: Re: Eagle Racing Cams - 385 lift 252 degrees |
If you end up not using the cam, at least you could mount a handle and split some wood
HAHAHAHAHA _________________
modok wrote: |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Mon Jan 09, 2017 7:47 pm Post subject: Re: Eagle Racing Cams - 385 lift 252 degrees |
It says running clearance 0. Set valves at 0. Sounds kinda' like a hydraulic grind to me. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Posted: Mon Jan 09, 2017 9:18 pm Post subject: Re: Eagle Racing Cams - 385 lift 252 degrees |
I used a web cam with lobes like that for a guy. he said everybody told him that was the beess knees or some shit...so....wtf it was his , if it died it was still his...that was 4 years or more ago, so apparently.. might work. |
Posted: Tue Jan 10, 2017 5:45 am Post subject: Re: Eagle Racing Cams - 385 lift 252 degrees |
Pat Downs <[email protected]> wrote: |
Good Morning Eric, That cam is an old hydraulic grind. I believe it was designed to be a stock replacement, just hydraulic instead of solid. The duation is advertised, not measured at .050. It has a very sharp nose and meant to be run with stock valve springs and a small diameter hydraulic lifter like a chevy or ford. I would not recommend using it with solid lifters. Hope this helps answer your questions.. |
I got my answer above
In addition, apparently you need to run this cam at an elevated RPM for a certain duration of time to break it in. _________________ GDTRFB |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Tue Jan 10, 2017 7:23 am Post subject: Re: Eagle Racing Cams - 385 lift 252 degrees |
ebennett wrote: |
In addition, apparently you need to run this cam at an elevated RPM for a certain duration of time to break it in. |
Pretty much SOP for all new cams. |
Posted: Tue Jan 10, 2017 10:18 am Post subject: Re: Eagle Racing Cams - 385 lift 252 degrees |
probably be ok with mild springs &ratio rockers to add a bit more gettitty up and went. I used some 1.4's on a hyd cam motor worked great.but it wasent that cam. |
ps2375 Samba Member
Posted: Tue Jan 10, 2017 10:31 am Post subject: Re: Eagle Racing Cams - 385 lift 252 degrees |
That pointy of a cam would scare me! Looks like it's all done by 5000 RPM at best. |
