Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Tue Aug 14, 2018 8:54 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
Update time!! I've been putting a lot of hours on this thing lately.
Got the shift rod bushing in, greased up and installed.
Excavated years of greasy dirt from the torsion arms on both sides, and gently faced the thrust surfaces with a file:
Started replacing all of the steel brake lines:
Bending steel brake lines by hand is one of my favorite things.
Clutch pedal maintenance:
Skipping around to the windows - all of them are held in by massive amounts of hardened caulking. Also the two remaining popouts are "latched" by screws and brackets.
Pulling the Jalousies:
Four WW Jalousie kits:
Took one apart, cleaned and greased everything, installed new seals. One down, four to go:
Also started one of the things I was really looking forward to:
Bye bye brown town!! The paint is in rough shape in parts (especially the nose), but I'm excited about getting the rest of that nasty brown and yellow off there.
Till next time.. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
Culito 11010101
Posted: Sat Sep 22, 2018 5:50 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
Update time. I've just been plugging away at this thing but not taking many pics. Here's a few:
Got my spindles back and installed.
Brakes assembled, drums on, and it's back on it's own four wheels again:
I need to skip around and do more rewarding things like this because rust repair takes it's toll. Speaking of rust repair...
Continued working on the front doors:
Had a donor piece for the pass. side door that saved me a ton of time and trouble:
I found that using a piece of perforated angle iron helped to line things up and create a "welding portal" to get a tack in there while it's clamped up.
At this point, major rust repair on the front doors is done. Welded up some trucker mirror holes and painted the upper frame:
Did some paint stripping:
Operation Ghost Flames a success! _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
Culito 11010101
Posted: Sat Sep 22, 2018 5:52 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
Next up: what's going on here?
'62 bug
johnnypan wrote: |
dschup Samba Member
Posted: Sat Sep 22, 2018 11:18 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
good progress, i'm doing the same thing as you, moving around from one part to the next, only so much rust repair I can take at a time.
Good luck |
Culito 11010101
Posted: Sun Sep 23, 2018 10:58 am Post subject: Re: '64 mouse gray / pearl white rustbucket |
dschup wrote: |
Good luck |
Thanks! Good luck on yours as well. _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
Culito 11010101
Posted: Sun Sep 23, 2018 4:08 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
Working on the hanging gas pedal setup:
'62 bug
johnnypan wrote: |
icekoffee Samba Member
Joined: March 14, 2005 Posts: 1239 Location: DeSoto, Missouri
Posted: Mon Sep 24, 2018 7:53 am Post subject: Re: '64 mouse gray / pearl white rustbucket |
Man, I haven't checked on this thread since page one. You are killing it. The bus is looking great. Keep up the great work. _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1958 Patina Beetle EJ25
1984 Vanagon Westfalia EJ25
1964 Lifted Mouse Grey Standard
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
Culito 11010101
Posted: Mon Sep 24, 2018 8:00 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
icekoffee wrote: |
Man, I haven't checked on this thread since page one. You are killing it. The bus is looking great. Keep up the great work. |
Thanks man!
I did get some window frame repair done (lots of rust along the bottom and a bunch of 30 year old silicone gobbed on everywhere) and painted with some rattle-can pearl white:
And I did end up getting the floor screwed in (I had fitted it around the A pillars over a year ago) so it was a rewarding moment:
I used most of a box of 100 screws.
Now to take one screw out, plug weld the crap out of it, take the next one out, plug weld the crap out of it... _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
Culito 11010101
Posted: Sun Dec 30, 2018 6:00 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
Time for my semi-annual update.
Front floor is now welded in:
Also patched some holes in the wheel tubs with some slightly less rusty metal:
I coated the wheel well areas with brush-on bedliner because of the large amount of pitting:
Pulled the steering box out of storage, drained it (it was pretty much empty), cleaned it up, filled it back up with gear oil/grease mix, and re-installed.
'62 bug
johnnypan wrote: |
Culito 11010101
Posted: Sun Dec 30, 2018 6:07 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
Pulled the parcel tray out of storage, cleaned off a large amount of contact cement (vinyl was glued over the whole thing), welded up some holes, prepped and painted with some texture paint to hide the overall pitting and damage. Came out pretty good:
For a little side project, I fixed one of the door handles that had broken at the spring area:
My new LED headlights came in, so I fixed up the headlight buckets and started tinkering with the electrical:
'62 bug
johnnypan wrote: |
Culito 11010101
Posted: Sun Dec 30, 2018 6:15 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
There was a lot of rust and pitting under the windshields, so I filled some of that in and painted it with Tower paint - but it wasn't a great match. Way too gray for the pearl white, but oh well.
A little buffing:
After that, I cleaned up the windshields and steering wheel, and reinstalled them:
Three-point seat belts, driver's side done:
'62 bug
johnnypan wrote: |
Culito 11010101
Posted: Sun Dec 30, 2018 6:24 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
E-brake cables and shifter installed (knob came with the bus - I'm keeping it!
New seat covers:
Working on window frames:
'62 bug
johnnypan wrote: |
cww Samba Member
Posted: Sun Dec 30, 2018 7:35 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
Culito wrote: |
Lather, rinse, repeat:
It's about time to order more metal... |
Do you have a part number for that pedestal patch panel? Cant seem to find it on KF site. Thanks |
Culito 11010101
Posted: Sun Dec 30, 2018 7:50 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
cww wrote: |
Looks like what you need might be here:
https://www.klassicfab.com/product-category/split-bus/front/front-wheel-wellsrepair-sections/ _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
cww Samba Member
Posted: Sun Dec 30, 2018 8:10 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
Thanks. That's it. Nice work on the bus. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Mon Dec 31, 2018 11:37 am Post subject: Re: '64 mouse gray / pearl white rustbucket |
Please 'splain how you did that. |
Culito 11010101
Posted: Mon Dec 31, 2018 12:24 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
Hey Barry,
I just flattened the broken areas off with a file, carefully drilled small holes with my drill press, and pressed / JB Welded in a piece of scrap steel wire.
I re-bent a small coil spring I had to replace the return spring. It doesn't have as much 'snap' as the original, but the handle does return home.
We'll see how long it lasts... _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
Culito 11010101
Posted: Mon Dec 31, 2018 5:33 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
Happy about this:
'62 bug
johnnypan wrote: |
Posted: Mon Dec 31, 2018 7:05 pm Post subject: Re: '64 mouse gray / pearl white rustbucket |
Beautiful Dash! Well done _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
BUGTHUG Samba's Rented Mule
Joined: April 22, 2007 Posts: 833 Location: KANSAS toto's fire hydrant
Posted: Sat Jan 05, 2019 2:45 am Post subject: Re: '64 mouse gray / pearl white rustbucket |
Skim wrote: |
Good to see you movin along again! |
Hey Skim this was one of my old bus. Shure wish you could get on mine quicker. _________________ I know you would understand what I'm saying if you could just see my HANDS
Even the middle of the week says W T F
1963 15 window bus
1966 VW bug
1966 21 window micro bus
1969 Dune Buggy
1965 VW bug
1974 VW bug
1972 Kelmark, VW drive line
1948 Chevrolet Hearse |
