richierich Samba Member
Posted: Wed Dec 21, 2016 3:48 pm Post subject: Quick Q about Jaycee pushrod tubes install |
Just about to instll new Jaycees on my 2387 as the current tubes are weeping. My question is, should i apply a bit of vaseline to the O rings on the inner tube to prevent binding? Or would white grease be best? |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Dec 21, 2016 3:56 pm Post subject: Re: Quick Q about Jaycee pushrod tubes install |
I always use a little silicone grease on those, just habit when using o rings anywhere. _________________ modok wrote:
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Wed Dec 21, 2016 4:47 pm Post subject: Re: Quick Q about Jaycee pushrod tubes install |
I use the same oil I run in the engine. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Wed Dec 21, 2016 9:32 pm Post subject: Re: Quick Q about Jaycee pushrod tubes install |
richierich wrote: |
I've had the same problem with my Jaycees leaking. Using white grease won't be a long-term solution as it dissipates over time. Oil is no good either.
Some use vaseline or other all-purpose grease on the O-rings. Others add a second feature by creating a "dam" with a lip of RTV silicone on the bottom half of the tube overlap (this keeps the oil from leaking out). _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
maui Samba Member
Posted: Wed Dec 21, 2016 10:56 pm Post subject: Re: Quick Q about Jaycee pushrod tubes install |
I use a little red silicone. Always worked for me. |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Thu Dec 22, 2016 8:05 am Post subject: Re: Quick Q about Jaycee pushrod tubes install |
For the price I would think they will last a lifetime and never leak. I say pull the heads and use CB wide mouth's. Otherwise a little Curil K2 would be my next go-to. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
77charger Samba Member
Posted: Thu Dec 22, 2016 2:15 pm Post subject: Re: Quick Q about Jaycee pushrod tubes install |
yamaducci wrote: |
For the price I would think they will last a lifetime and never leak. I say pull the heads and use CB wide mouth's. Otherwise a little Curil K2 would be my next go-to. |
I tried the scat 3 oring gold ones and ditched them they leaked more than i wanted to see on my buggy and went cb big mouth too. _________________ Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine |
