Squeaky front end
blue65
blue65 is offline
PostPosted: Thu Dec 22, 2016 3:20 am    Post subject: Squeaky front end Reply with quote
My 1965 VW Beetle squeaked a fair bit.
The front has been lowered by about an inch. Has KYB shocks and an anti-sway bar. This was installed 10 years ago.
When I brake (moderately) the front of my beetle squeaks a fair bit, or when I go around corners.
My mechanic did a lube job and it helped.
But when I am going straight and I apply my brakes the suspension seems to be squeaking or straining.
Is it a serious problem?
anthracitedub
anthracitedub is offline
PostPosted: Thu Dec 22, 2016 5:28 am    Post subject: Re: Squeaky front end Reply with quote
I wonder if your beam has the after market bushings or OE bearings?
The bushings have been known to squeak. Also, I have seen the sway bar bushing squeak too.
Stuart Maingot
Stuart Maingot is offline
PostPosted: Thu Dec 22, 2016 11:25 am    Post subject: Re: Squeaky front end Reply with quote
yes, could be those aftermarket bushings or not enough grease in the oe needle bearings. When properly greased the grease should squeeze out of the dust covers on the end of the beam right where the trailing arms bolt to the torsion leaves.
Incidentally I had a persistent squeak some years ago that turned out to be a cracked frame head, just where the metal fuel line enters the tunnel.
Check that area out as well.
modok
modok is offline
PostPosted: Sat Dec 24, 2016 12:45 pm    Post subject: Re: Squeaky front end Reply with quote
The link pins and kingpins really need to be greased often, perhaps 4 times a year or more. They don't HOLD very much grease. If the grease has dried out and rust has set in it is near impossible to push in fresh grease. Just have to take it apart and clean it up and polish the pins and re-assemble to get it working again.
The beam does not have as much of a problem. Very rare for the arms to be rusty or needle bearings to go bad, but it CAN happen.
And the urethane replacement ones.......yeah, they are stiff and squeaky.
I say junk, but I guess they are ok for some, I suppose it isn't dangerous and that's a step above a lot of aftermarket pieces.
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sat Dec 24, 2016 2:14 pm    Post subject: Re: Squeaky front end Reply with quote
... or just might need more grease.
Roads Scholar & distributor restorations
1956 oval third owner 36 hp- slow drag Champion 2012, 2014, 2015, 2017
1957 Kombi low mileage 36 hp governor equiped M 178 Slow Drag Winner 2014, 2015, 2018
1960 sunroof beetle owned since 1991 36 hp
1965 hrdtop Deluxe Microbus owned since 1990 M 620 factory 12 v 1500cc
blue65
blue65 is offline
PostPosted: Tue Jan 03, 2017 5:09 am    Post subject: Re: Squeaky front end Reply with quote
My mechanic greased it up. It went okay for a week or so. But the squeaking came back again.
Thank you for your suggestions. I'll take it up with my mechanic when he returns back from the holidays.
