Removing Seam Sealer
67ctbug
67ctbug is offline
PostPosted: Thu Dec 22, 2016 12:11 pm    Post subject: Removing Seam Sealer Reply with quote
In an effort to fix my squishy floors I'm going to remove the seam sealers so that I can re-weld the floor where it's wobbly so they don't bounce. How should I go about doing this? I've tried using a wire brush on the drill but it's removed it but not the part in the cracks between the tunnel and the floor.
'67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote:
...or the PO envied the terrorists' bus in "Back to the Future". Laughing
mukluk wrote:
He's fine, just waiting for the dragon in winklepickers to move out of his lane.
theKbStockpiler
theKbStockpiler is offline
PostPosted: Thu Dec 22, 2016 12:56 pm    Post subject: Re: Removing Seam Sealer Reply with quote
Heat gun and physical means while still hot.
My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask.Smile
67ctbug
67ctbug is offline
PostPosted: Thu Dec 22, 2016 1:02 pm    Post subject: Re: Removing Seam Sealer Reply with quote
I don't think a heat gun is necessary, but I'll try. The stuff is peeling off everywhere else Shocked . My other problem is that it may be underneath the pan on the lip so how would I go about getting that off too?
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
beetlenut
beetlenut is offline
PostPosted: Thu Dec 22, 2016 1:10 pm    Post subject: Re: Removing Seam Sealer Reply with quote
I just used a putty knife. Sometimes I would heat the end of it with a torch to get thru thick areas. Then I used an 80 grit flap wheel to get the remaining down to bare steel. In some tight areas where even the putty knife wouldn't fit, I'd use small screwdrivers or razor knifes. Whatever works to get the job done. Not the best job to do, but necessary to move on to the good stuff!
scrapyards are for quitters
Wetstuff wrote:
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again.
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104
67ctbug
67ctbug is offline
PostPosted: Thu Dec 22, 2016 1:48 pm    Post subject: Re: Removing Seam Sealer Reply with quote
Ok I'll try that guys, but what if it got under the pan...
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
