Braukuche Samba Member
Posted: Sat Dec 24, 2016 5:02 pm Post subject: Ambulance step restore question |
I picked this up a while back and it was frozen up. I finally got the thing apart and can't figure out how the spring mechanism works. I thought there would be two big springs in the tube that the step slides into, but instead I found these two rods as no spring. Anyone know who this particular mechanism works?
_________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sat Dec 24, 2016 5:29 pm Post subject: Re: Ambulance step restore question |
Springs should be pushing those rods out to push the step outward. _________________ In Stereo, Where Available! |
Stocknazi Samba Member
Posted: Sat Dec 24, 2016 5:32 pm Post subject: Re: Ambulance step restore question |
I had to make new rods from some stainless steel rod and replace the springs. On my step, the spring slid over the rod; the rod end was crimped over one end of the spring. The spring/rod assembly was then lowered in the tube and the other end of the spring hooked through a slot at the end of the tube; that allows the spring to load when the step is pushed in.
My step was the earlier style w/o the dust covers on the tubes; yours looks like it might be a little different. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Sat Dec 24, 2016 5:39 pm Post subject: Re: Ambulance step restore question |
StockNazi wrote: |
Were you able to free up the foot pedal rod? |
I had to cut the hell out of it, but I finally got the rod out, cleaned it up, welded the how mess back together and now that works.
The right rod is hung up on something in there and I can see it from the one open end. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Sat Dec 24, 2016 6:12 pm Post subject: Re: Ambulance step restore question |
Braukuche wrote: |
StockNazi wrote: |
The right rod is hung up on something in there and I can see it from the one open end. |
That's the only way I found to remove the pedal rod.
Check out the 63-67 Bently. There is some information/pics there. It says to unscrew the bushes from the end of the tube. and the rod/spring assembly pulls out. The rod you have loose might have broken loose inside. _________________ WANTED:
Thomas Jefferson |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Sat Dec 24, 2016 6:19 pm Post subject: Re: Ambulance step restore question |
I redid one recently, the springs are housed inside the tube beneath the bushes on the end the rod is protruding from. The bushes unscrew. I can post pics later if needed _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
StockNazi wrote: |
Braukuche wrote: |
StockNazi wrote: |
Check out the 63-67 Bently. There is some information/pics there. It says to unscrew the bushes from the end of the tube. and the rod/spring assembly pulls out. The rod you have loose might have broken loose inside. |
I saw that Bentley bit, wasn't sure what they were referring to as the "bushes" so I guess that the rods?
Maybe I'll just simplify things and get some big springs and stick them on the tubes to push the step out I feel that rod ha indeed broken off. The ones you made were they threaded at the end?? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Sat Dec 24, 2016 6:22 pm Post subject: Re: Ambulance step restore question |
The bushes are the threaded end cap that the rod is exiting in your picture. The bushes thread into the end of the tubing _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Sat Dec 24, 2016 6:28 pm Post subject: Re: Ambulance step restore question |
Hopefully this helps _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Sat Dec 24, 2016 6:39 pm Post subject: Re: Ambulance step restore question |
Ultramoron wrote: |
Hopefully this helps |
Perfect! TOtally makes sense now, mine is so rusted and cruddy I couldn't tell there was a threaded fitting on there.
Thanks and Merry Christmas. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Tue Dec 27, 2016 4:59 pm Post subject: Re: Ambulance step restore question |
Here are some pics of the earlier style step rods; original on top.
End of step tube; hard to see with all the old grease, but there is a small rod welded inside the tube that the spring hooks to. This style step has no bushes that screw into the tube.
Thomas Jefferson |
Douglas Denlinger Samba Member
Joined: May 23, 2003 Posts: 1382 Location: Arizona's version of the east coast
Posted: Fri Mar 22, 2019 9:58 am Post subject: Re: Ambulance step restore question |
Revival time.....so I really enjoy taking on challenges....this step came with a project bus that I'm nearing the finish line on. Being an original M-coded ambulance side step bus, with it's original side step, it's time to take on the challenge to make it work. The challenging part....previous owner took it apart, leaving me the puzzle to figure out how to put it back together. Fortunately, thanks to the information above most of that is accomplished.
However, does the step lever rotate inside the tube to release the catch, which would then release the step to slide out?
Obviously the previous owner used the jaws of life, which leads me to believe that he could not get it to rotate.
So the question is does the step lever, turn inside the tube? Can/should that lever come out of the tube completely?
_________________ Transporter Restorations
Upholstery Haus
Active 23 Window Samba Collector/Restorer,since 1986 |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Fri Mar 22, 2019 11:06 am Post subject: Re: Ambulance step restore question |
I think there should be a hook in that hole that grabs the step itself to keep it from flying out.
Every time I see one of those damn steps I wish I would have kept mine. You got a good deal Lind, $40 if I remember right! _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Fri Mar 22, 2019 11:25 am Post subject: Re: Ambulance step restore question |
crofty wrote: |
Every time I see one of those damn steps I wish I would have kept mine. You got a good deal Lind, $40 if I remember right! |
Honestly they are a pain in the arse. Just like everything no one maintained the steps to function smoothly.
Yes this hook....the question is the tube that it bolts thru....is that tube supposed to turn freely....can it be removed?
Its interesting that the tubes that the step slides out from (base that bolt bolts to the bus) have zerks to grease the slides...this does not. I believe if this is suppose to turn freely then it should have had a zerks as well. _________________ Transporter Restorations
Upholstery Haus
Posted: Fri Mar 22, 2019 11:41 am Post subject: Re: Ambulance step restore question |
I found a pic of a NOS one in the gallery. I'd think that it would have to rotate in order to release the step itself. _________________ Your Vanagon sucks, Stop waving at me.
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Fri Mar 22, 2019 11:58 am Post subject: Re: Ambulance step restore question |
The pedal is welded to a (solid?) rod that rotates in the fixed (outer) tube.
The pedal rod can be removed, if you remove the hook (and the rod isn’t frozen). _________________ aka: Evan
Posted: Fri Mar 22, 2019 12:00 pm Post subject: Re: Ambulance step restore question |
crofty wrote: |
I found a pic of a NOS one in the gallery. I'd think that it would have to rotate in order to release the step itself. |
Well that answers that. Thanks for the heads up Crofty
Looks like I'll be breaking out the torch.
They really should have placed a zerk on that end of the tube _________________ Transporter Restorations
Upholstery Haus
Posted: Fri Mar 22, 2019 12:04 pm Post subject: Re: Ambulance step restore question |
easy e wrote: |
The pedal rod can be removed, if you remove the hook (and the rod isn’t frozen). |
The hook was already removed by the previous owner.....he gave up on the step lever, after he crushed the tube trying to turn it or pull it out.
Sometimes I wonder if it's less expensive to find a replacement, then spend hours rehabbing. _________________ Transporter Restorations
Upholstery Haus
Posted: Fri Mar 22, 2019 2:24 pm Post subject: Re: Ambulance step restore question |
Douglas Denlinger wrote: |
easy e wrote: |
Sometimes I wonder if it's less expensive to find a replacement, then spend hours rehabbing. |
It was a nightmare getting mine to sort of work, and it required a lot of heat, bashing, pounding, swearing and welding.
It is nice to have on my SO23 camper, though. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
easy e Samba Member
Posted: Fri Mar 22, 2019 2:41 pm Post subject: Re: Ambulance step restore question |
I could see coming to the conclusion:
Cut off the pedal / bar assembly from the step frame & remake w/new material.
It’d probably be faster & work out better in the long run.... especially if yours is already tweaked. _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
