New Front Apron
67ctbug
67ctbug is offline
PostPosted: Mon Dec 26, 2016 8:08 am    Post subject: New Front Apron Reply with quote
Just received a new apron for Christmas, but it has creases on the bottom.
How should I get rid of these?
'67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote:
...or the PO envied the terrorists' bus in "Back to the Future". Laughing
mukluk wrote:
He's fine, just waiting for the dragon in winklepickers to move out of his lane.
63Ragtop NZ
63Ragtop NZ is offline
PostPosted: Mon Dec 26, 2016 3:02 pm    Post subject: Re: New Fromt Apron Reply with quote
Stop.
Hammertime!
Laughing
If you can't join them, beat them!
67ctbug
67ctbug is offline
PostPosted: Mon Dec 26, 2016 3:17 pm    Post subject: Re: New Fromt Apron Reply with quote
Laughing I just hammer it? Do I need a dolly? The creases look less in the photos.
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
theKbStockpiler
theKbStockpiler is offline
PostPosted: Mon Dec 26, 2016 4:32 pm    Post subject: Re: New Fromt Apron Reply with quote
Edit: Is there too much metal in that area or not enough?
If your using filler on other parts of the car ,why not their as well?
If you hammer and dolly those ridges out it's going to stretch that area and make it bulge.The reason those ridges are there is because during the manufacturing process the method used was not good enough to shrink it so it bulked it up.
To do the job totally right ,you will have to shrink the ridges down. Edit: That would keep the generalized contour the way it is without the ridges.
My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask.Smile
67ctbug
67ctbug is offline
PostPosted: Mon Dec 26, 2016 6:28 pm    Post subject: Re: New Fromt Apron Reply with quote
It seems there is more metal than needed there.
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
theKbStockpiler
PostPosted: Mon Dec 26, 2016 8:58 pm    Post subject: Re: New Fromt Apron Reply with quote
I would put that on my list of things to nitpick and probably ,hopefully never get to it. You could smooth it out with filler and always use a heat gun and scrape it off and redo it at a later time.
67ctbug
67ctbug is offline
PostPosted: Wed Dec 28, 2016 11:12 am    Post subject: Re: New Front Apron Reply with quote
Here's how bad it really is.
I think I'll just get some rage gold and smooth it out.
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
theKbStockpiler
PostPosted: Wed Dec 28, 2016 3:26 pm    Post subject: Re: New Front Apron Reply with quote
I would contact the vendor on that part and tell them you need a shipping label to return that to them. That can't be by design but a test run or something.
air-h2o-air
air-h2o-air is offline
PostPosted: Wed Dec 28, 2016 8:21 pm    Post subject: Re: New Front Apron Reply with quote
take a look at your original apron..I bet you see similar stretch marks
67ctbug
67ctbug is offline
PostPosted: Wed Dec 28, 2016 8:49 pm    Post subject: Re: New Front Apron Reply with quote
I got it for Christmas, I'd rather not return it. It's from WW so they pick them so they all were probably the same.
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
WADVR
WADVR is offline
PostPosted: Wed Dec 28, 2016 11:38 pm    Post subject: Re: New Front Apron Reply with quote
I also got a front apron from WW in the same condition. I've been contemplating sending it back, leaving them alone or trying to pound them out.
- 67 Beetle Full Resto Project
- 66 Beetle “Parts Car” Project
67ctbug
67ctbug is offline
PostPosted: Thu Dec 29, 2016 12:06 am    Post subject: Re: New Front Apron Reply with quote
I bet all of the companies that's sell these have the same bad stampings. I think the best we can do is hammer and bondo.
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
theKbStockpiler
PostPosted: Thu Dec 29, 2016 12:11 pm    Post subject: Re: New Front Apron Reply with quote
So you know, that type of workmanship is what a cost cutting domestic car manufacturer would do on the area around the tunnel/firewall/front floor and would be covered up with padding and insulation. GM for example ;who did not cut corners with their body forming ,would have never done a job like that.
It's not the stampings is because they are not stretching the panel somewhere else.
67ctbug
67ctbug is offline
PostPosted: Thu Dec 29, 2016 1:20 pm    Post subject: Re: New Front Apron Reply with quote
I know a big name company wouldn't do that, klokkerholm is not really that big of a name and I see them cutting corners like this. Ever other part of the panel is fine even perfect if I dare say.
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
ssx
ssx is offline
PostPosted: Fri Dec 30, 2016 1:10 pm    Post subject: Re: New Front Apron Reply with quote
Wow, that's pretty bad. Not sure how much it cost, but I'd either prep it properly and bondo, or return and order a top notch piece from Wolf. I plan to order a 4 finger apron from Wolf for my 56.
1956 Oval/Ragtop
67ctbug
67ctbug is offline
PostPosted: Fri Dec 30, 2016 5:47 pm    Post subject: Re: New Front Apron Reply with quote
I'm gonna prep and bondo with rage gold. Who is this "Wolf" you speak of?
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
Bill W
Bill W is offline
PostPosted: Fri Dec 30, 2016 6:38 pm    Post subject: Re: New Front Apron Reply with quote
Wolfsburg West,
https://www.wolfsburgwest.com/
67ctbug
67ctbug is offline
PostPosted: Fri Dec 30, 2016 7:03 pm    Post subject: Re: New Front Apron Reply with quote
I don't think he is talking about them. This is from WW and is clearly not "top notch"
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
57BLITZ
57BLITZ is offline
PostPosted: Fri Dec 30, 2016 9:46 pm    Post subject: Re: New Front Apron Reply with quote
WOLFPARTS . . . this thing is like artwork! http://wolfparts.com/?product=front-apron-1950-1959
Jesucristo es mi Señor y Salvador!
67ctbug
67ctbug is offline
PostPosted: Fri Dec 30, 2016 9:52 pm    Post subject: Re: New Front Apron Reply with quote
That looks great, but it's nearly $300!
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
