babysnakes Samba Member
Posted: Mon Jan 02, 2017 3:06 pm Post subject: 7 wire turn signal switch |
Why can't I find one in the Bentley? I have a '72 bus and the indicator switch is crapped out. I looked through the classifieds and saw a few "7 wire, 1972 only switch" ads. My bus has a 5 wire as per the Bentley. A well respected/trusted Sambanista found a good switch he pulled from a '72 but it's a 7 wire. To ad even more confusion to the mix, I purchased a NOS 1969 switch for my SC, it's a 7 wire. The Bentley that I own and the technical section on The Samba only show 8 wire ('68-'71) or 5 wire ('72).
Dear Abby, what advice might you have?
Flabbergasted in Florida. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jan 02, 2017 4:33 pm Post subject: Re: 7 wire turn signal switch |
Dear Flabby,
Have you talked to your switch to find out what's really bothering it deep down inside? Sometimes just telling it how you really feel is all it needs.
As for the number of wires I don't know what the later one would have the bonus ones unless it's a one part fits all replacement unit, the early switch needs the extra ones for the combined brake/signal single bulb tail light fixtures, a 72 has separate signal bulbs so there's no need to work a brake light into mix. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3477 Location: viroqua wi.
Posted: Mon Jan 02, 2017 4:35 pm Post subject: Re: 7 wire turn signal switch |
Looked at my Bentley and tech section here. I see 3 and 4 wire early switches not 8 and 5 wire later. No 7. |
Posted: Mon Jan 02, 2017 4:44 pm Post subject: Re: 7 wire turn signal switch |
If you want to split hairs a North American 68-71 should have 10 wires (maybe 9 if the switch uses the column as a ground, not many do), the 72-79 system (as well as 68-71 Euro models) uses a minimum of 5 wires, 3 for the signals, one for the headlight relay and a ground. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jan 02, 2017 4:57 pm Post subject: Re: 7 wire turn signal switch |
busdaddy wrote: |
Dear Flabby,
Have you talked to your switch to find out what's really bothering it deep down inside? Sometimes just telling it how you really feel is all it needs. |
Tonights winner!!
I dug deep and found how to hack the 8 wire to work a five wire. You seem to be suggesting VW came out with a (Maybe) universal switch at some point? It threw me for a curve as I spent a lot of time trying to figure this out. No big deal, but the "7 wire" '72 only may have been a fix that might work on other years? Maybe it's an earky '72 vs a late '72. |
Posted: Mon Jan 02, 2017 5:15 pm Post subject: Re: 7 wire turn signal switch |
babysnakes wrote: |
You seem to be suggesting VW came out with a (Maybe) universal switch at some point? |
I have no way to confirm that, it's just a theory. As thier model line expanded space on the shelves in the warehouse must have gotten tight, why not offer a single part that fits 68-mid 74?, include an instruction sheet saying "snip off surplus wires W, X & Y when installing in models built after 8/71" and the bean counters all pat each other on the backs. Signal switches are a high wear item like ignition tumblers and shift couplers, many must have worn to the point of replacement when these cars were still ~10 years old. Or maybe they were a jobber part like all the Dorman stuff for semi current Chevy's, etc...?
Both styles of switch work the same internally, to use an early one with a late system just use the front signal circuit and leave the rear terminals alone. (although they could be used to light the front signals constantly as DRL's, connect the brake wire to a keyed power source and wire the whole system backards {rear in front, front in rear}). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3547 Location: San Diego (Encinitas)
Posted: Mon Jan 02, 2017 5:33 pm Post subject: Re: 7 wire turn signal switch |
busdaddy wrote: |
although they could be used to light the front signals constantly as DRL's, connect the brake wire to a keyed power source and wire the whole system backards {rear in front, front in rear}. |
An interesting concept. My only concern would be the short life of the bulb's 'turn' filament when run in this mode. Adding a little resistance to the brake wire (to drop the bulb operating voltage to maybe somewhere around 10 volts) would solve the problem. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Mon Jan 02, 2017 5:34 pm Post subject: Re: 7 wire turn signal switch |
bsairhead wrote: |
Maybe you're looking in the wrong place.
Find "H" near the lower right hand corner. That is the turn signal switch. There are 10 wires. Two are for the horn. The other eight are for the turn signal. '69-'70. |
Posted: Mon Jan 02, 2017 5:40 pm Post subject: Re: 7 wire turn signal switch |
Um, aren't two of those eight wires for the high beam relay?
Worst case turn signal wire requirements would be: rf lamp, lf lamp, rr lamp, lr lamp, flasher relay, brake light signal - six wires total. (Later systems would drop one pare of lamps and the brake switch wire. Now you're down to three wires.)
Add two horn wires and two headlight relay wires, and you get a maximum of ten wires. Early models don't have the horn wires going through the turn switch...
With all of these possibilities, no wonder it's confusing! But for a '72, I would think you would need five wires (three turn, two headlight). Unless, the horn goes through the turn switch and not up the column, then there would be seven. Take it apart and look?
Posted: Mon Jan 02, 2017 6:00 pm Post subject: Re: 7 wire turn signal switch |
telford dorr wrote: |
Worst case turn signal wire requirements would be: rf lamp, lf lamp, rr lamp, lr lamp, flasher relay, brake light signal - six wires total. (Later systems would drop one pare of lamps and the brake switch wire. Now you're down to three wires.)] |
1973, 3 wires like you said.
E2 near center of page. |
Posted: Mon Jan 02, 2017 6:15 pm Post subject: Re: 7 wire turn signal switch |
Yup. Bottom line: as long as the switch physically fits, mechanically works, and has enough wires, it should be fine. Too many wires? Snip off (or tape up) the ones unneeded. _________________ '71 panel, now with FI
aeromech Samba Member
Joined: January 24, 2006 Posts: 16926 Location: San Diego, California
Posted: Mon Jan 02, 2017 7:00 pm Post subject: Re: 7 wire turn signal switch |
Told ya _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5778 Location: Los Alamos, New Mexico
Posted: Tue Jan 03, 2017 2:08 pm Post subject: Re: 7 wire turn signal switch |
Both BusDepot and aircooled.net offer '68-'71 switches with instruction on how to modify them to work for a '72 bus. I just got one for my '72, but have not wired it up yet. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Tue Jan 03, 2017 2:13 pm Post subject: Re: 7 wire turn signal switch |
Yep, I found the mod while digging through a shit load of threads. Is you new after market switch 8 or 7 wires? I wanted a good OG switch. My NOS 7 wire is SWF as is the used one I'll be getting any day now. |
jtauxe Samba Member
Posted: Wed Jan 04, 2017 1:44 pm Post subject: Re: 7 wire turn signal switch |
The one I got from aircooled.net is the 8-wire version. Seems to be decent aftermarket repop:
http://vwparts.aircooled.net/Turn-Signal-Switch-1968-71-Type-2-211-953-513G-p/211-953-513g.htm _________________ John
http://vw.tauxe.net
chaddhamilton Samba Member
Joined: February 08, 2017 Posts: 42 Location: Charleston, SC
Posted: Mon Feb 05, 2018 7:51 am Post subject: Re: 7 wire turn signal switch |
babysnakes wrote: |
Hey Snakes. I have a 73 with a bad switch. I knew someone has made the 8 wire work, but can't find a how-to on the wiring. Can you recall where you found the thread on this?
Thanks! |
