Any infos on this pre 50 split or ?... very early VDO clock?
originalo
originalo is online now
PostPosted: Wed Jan 04, 2017 9:21 am    Post subject: Any infos on this pre 50 split or ?... very early VDO clock? Reply with quote
I have never seen this kind of clock before. Face design corresponding to 45-49 split or Porsche Gemünd speedo face. Diameter of clock is working for splitbug speedo or clock pod openings. No stamping on rear side.
Any info on this clock or it´s application (pre 50 split? KdF Wagen?? pre 50 Porsche 356??? Coachbuild???) will be greatly apreciated.
mikeandkirsti
mikeandkirsti is offline
PostPosted: Sat Apr 07, 2018 12:50 am    Post subject: Re: Any infos on this pre 50 split or ?... very early VDO clock? Reply with quote
Mercedes 170?
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Sat Apr 07, 2018 8:24 am    Post subject: Re: Any infos on this pre 50 split or ?... very early VDO clock? Reply with quote
... pretty face, but if a Mercedes it probably doesn't work
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
bakersam
bakersam is offline
PostPosted: Sun Apr 08, 2018 5:57 am    Post subject: Re: Any infos on this pre 50 split or ?... very early VDO clock? Reply with quote
Owned a '50 Mercedes 170-S, and this wasn't the right clock face for that. Don't see any evidence of where the winding mechanism is on this one. Quite likely, it'd have to be on the side for a Bug. If on the bottom of the case then most certainly for someone else that had access from under the dash (i.e. Opel, BMW, Mercedes, Goliath, Hansa, Lloyd, Adler, Triumph, Auto Union, Wanderer, etc.). Looks like it slid into place from the front of the dash, and fastened in place with a bracket over that threaded post on the back. Interesting clock if you owned the right vehicle for it, but its configuration doesn't seem to support the VW theory.
originalo
PostPosted: Mon Aug 20, 2018 9:48 am    Post subject: Re: Any infos on this pre 50 split or ?... very early VDO clock? Reply with quote
Another one just popped up on ebay.de (not afiliated with the seller), just for info, item nr 123301116806, link:
https://www.ebay.de/itm/VDO-zeituhr-f-Volkswagen-K...SwtPlbbGqw
finster
finster is offline
PostPosted: Mon Aug 20, 2018 12:25 pm    Post subject: Re: Any infos on this pre 50 split or ?... very early VDO clock? Reply with quote
pretty sure I saw one like this back in the eighties and was told it was from a german coach. would have been fitted in a roof mounting so passengers could see it.
