What engine is this $
chief645
chief645 is offline
PostPosted: Thu Jan 05, 2017 12:38 pm    Post subject: What engine is this $ Reply with quote
I am looking at a trike which has the letters and numbers on the crankcase as follows : AH 250-17... The owner says it is a bus engine, I think it is a type I instead. What is it actually?
Bashr52
Bashr52 is offline
PostPosted: Fri Jan 06, 2017 5:58 am    Post subject: Re: What engine is this $ Reply with quote
Dual port 1600. Same engine was used in the early buses along with bugs. The bus didn't get its own engine until the type 4 came out.
chief645
chief645 is offline
PostPosted: Fri Jan 06, 2017 6:01 am    Post subject: Re: What engine is this $ Reply with quote
Thanks for the reply...
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Tue Jan 31, 2017 7:10 am    Post subject: Re: What engine is this $ Reply with quote
Beginning in 1968 buses began using a rear engine support AKA mustache bar. They used this through the 1971 model year with upright dual port engine. 1971 bus would be a one year only application for this in dual port form, 68 through 70 being single port. But it is possible you have a bus engine and decoding the serial number would tell the story.
