pittwagen Samba Member
Joined: November 08, 2005 Posts: 766 Location: North of the 49th parallel
Posted: Mon Jan 09, 2017 7:47 pm Post subject: Re: Fuel injection conversion shopping list - parts required |
With a properly set up FI system on a well built and correctly maintained engine, there is nothing better. My 79 CA spec bus has performed flawlessly and has never let me down in almost 7 years of ownership.
And yes for comparison, many years ago I owned a new 74 P21 Westfalia so I understand how a brand new carbed engine is supposed to perform. The FI is smoother, gets better gas mileage, runs cleaner and is not affected by weather.
So for those of you contemplating the change, do it right the first time and you will not be disappointed. |
KBDDBD Samba Member
Joined: June 02, 2014 Posts: 23 Location: Southwest NM
Posted: Sun Jan 15, 2017 7:33 am Post subject: Re: Fuel injection conversion shopping list - parts required |
I want to add same as pittwagen. If you really want to travel FI is the way to go. Its very reliable and only requires a few spares - less than a few hundred bucks of stuff from shows, CL, or swap meets if you are looking for them because a lot of folks dont want the stuff. Best, is it is impervious to elevation if working properly. I live at 6K feet and can go to the beach or skiing and no difference. Also - the mileage is a little better and FI definitely runs cleaner and cooler, particularly in heavy city traffic, |
Tcash Samba Member
Tcash Samba Member
Posted: Sun Sep 10, 2017 9:06 pm Post subject: Fuel injection Fuel pumps |
To link to this post copy and paste
Code: |
[url=https://www.thesamba.com/vw/forum/viewtopic.php?p=8554618#8554618]Fuel injection Fuel pumps[/url] |
Inside the FI electric fuel pump 043 906 091
Part numbers, a little scratchy.
thnx jersey
http://www.jerseylooker.com/FicheDump/LateBaywindow/018-30-1-058.jpg
http://www.jerseylooker.com/FicheDump/LateBaywindow/018-30-1-059.jpg
1974, from ch. no. 132 408 to the end of 74 California models, 1.8, FI Elect. Fuel pump 311 906 091 D
____________________________________________________________________________________________________________________________
1975-79, 1.8-2.0, FI Elect. Fuel Pump 251 906 091 > 043 906 091
Bosch 0 580 463 010 > 0 580 463 016 >0 580 464 085 / 69469 / GFP 301 screw on terminals /
allenrobbins Samba Member
Joined: January 25, 2017 Posts: 16 Location: Fate, TX
Posted: Thu Sep 28, 2017 9:18 pm Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
What about the mount bracket for the ECU? Can't seem to find any info on how to secure it. |
Tcash Samba Member
Posted: Thu Sep 28, 2017 10:55 pm Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
allenrobbins wrote: |
Not really a bracket. If the Bus is 1974 or older. You would need to cut a slot above the battery to slide it into the body panel and two bolts hold it in place. 1975 and newer the slot is there already.
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Thu Sep 28, 2017 11:03 pm Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
The mount is secured in the engine bay. Is the mount itself removable? I've never tried. I'll add it to the list if so, thanks!
www.airschooled.com |
Mich3 Samba Member
Joined: May 22, 2013 Posts: 43 Location: Orange County
Posted: Mon May 14, 2018 10:58 am Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
Fantastic! Is there a corresponding shop list for Type 1 as well that you know of? |
Posted: Mon May 14, 2018 11:00 am Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
Mich3 wrote: |
We can make any list you’d like, but I’m not sure which Type 1 you’re referring to... The German L-Jet system that came on bugs after 1975? Or the later Mexican style fuel injection?
Posted: Mon May 14, 2018 11:02 am Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
asiab3 wrote: |
Robbie |
On my 74 Westy there is an "indention" the same size as the ECU the same place as the ECU is the picture. I just cut a hole, drilled holes and bolted it in. Worked perfect. |
Mich3 Samba Member
Posted: Mon May 14, 2018 11:08 am Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
asiab3 wrote: |
Mich3 wrote: |
Robbie |
To convert my imported OEM 79 beetle to CA standards (engine AS 1974-79 1600cc 50bhp DIN. Non-USA)
Not sure if it helps but here are few pics:
Tcash Samba Member
Posted: Mon May 14, 2018 12:53 pm Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
Mich3 wrote: |
asiab3 wrote: |
Mich3 wrote: |
Robbie |
Please move discussion to appropriate Forum.
Beetle - Late Model/Super - 1968-up
Thank you
Tcash |
chasduby Samba Member
Posted: Sun May 20, 2018 8:00 pm Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
I had a small engine fire, and had to get a replacement engine with carburetors.
This conversion back to FI all seems pretty daunting. Is it at all possible to get a 78 bus (formerly FI but now w carburetors) an exemption through the CA DMV Referee program?
I now live in CO, and they won't even test the emissions because "I went backwards in technology." |
Tcash Samba Member
Posted: Sun May 20, 2018 8:22 pm Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
chasduby wrote: |
Been a while so don't quote me. But you used to be able to apply for a hardship in Calif. But it only buys you a year. The following year you have to meet the requirements.
https://www.dmv.ca.gov/portal/dmv
Go down to FUEL INJECTION
Tech Tips
Fuel Injection (Bosch Parts Interchange)
http://www.type2.com/library/fuel/fuelibo.htm
Good luck
Tcash |
secretsubmariner Champagne Wrangler
Joined: January 08, 2011 Posts: 3104 Location: Tulsa, OK
mr matt Samba Member
Joined: May 26, 2005 Posts: 819 Location: southeast Pa
Posted: Tue Jun 12, 2018 5:28 pm Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
Guess it is too early to tell how it is holding up.. the pump that is..hey, maybe filters also... _________________ 1955 3-fold semaphore Oval beetle
1971 Convertible beetle
1977 Westfalia, FI, Berlin interior |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Sat Apr 27, 2019 3:43 pm Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
Who's brought back their engine from carbs to fuel injection? What's the hard to find items that are usually bad and needing quality pieces to get things working in tip top shape?
I have a GE engine with all the original items there, will be assessing completeness next week.
Robbie, thanks for the kickass list.
WastedYouth (Steven) as always, good looking out bro. _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Posted: Sat Apr 27, 2019 4:16 pm Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
SamboSamba22 wrote: |
WastedYouth (Steven) as always, good looking out bro. |
KentPS, AndreWTF, and a few others here have. Send them a PM if they don't see this.
Last engine I did this on was subject to CA emissions testing. Whether or not you have a visual test will affect the work and parts load greatly. Some of the hardest parts were the late EGR valve, lack of CA-legal cat until this year, finding a functioning PCV valve. All of those are easily navigated when you can run block-off plates and delete pipes, but we were stuck.
Yeah, if you start with an original FI car with the ECU, decel valve, double relay, and all that still installed, you're ahead of the game. I remember spending a while under AndreWTF's new bus rebuilding the DR wiring harness that was truncated with a sawzall or angle grinder years before…
Good luck!
oscarsnapkin Samba Member
Joined: October 22, 2013 Posts: 558 Location: Bucks County, PA
Posted: Sat Apr 27, 2019 5:02 pm Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
My first post in probably three or more years. Had twins, so the VW hobby has been kind of pushed aside, but I still get to enjoy driving my Bus. Anyhow, when I purchased my ‘77 it had a Weber progressive carb. and came with none of the FI parts. I bought a nearly complete FI system from a user here on thesamba and was able to fairly easily assemble an awesome running system. I had my injectors cleaned, used all new rubber seals/hoses, and made sure to clean the hell out of everything. Ratwell’s site made the process possible and his pictures and diagrams are indispensable. Definitely bench test everything when possible to avoid having to troubleshoot once it’s assembled in your Bus. I found a problem with my AFM before assembly that I’m sure would have been a hassle to have diagnosed otherwise. When I first decided to switch back to the FI system from the carb. (at the suggestion of other samba users) I thought it was going to be an overwhelming project, but it was actually very simple and straight forward. I would suggest studying Ratwell’s site and becoming familiar with the different parts and their functions. There’s also a troubleshooting guide that I downloaded from thesamba that was really helpful as well. I’m sure someone else here could probably post the link. Best of luck and don’t feel intimidated. _________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind." |
SGKent Samba Member
Posted: Sat Apr 27, 2019 5:34 pm Post subject: Re: Fuel injection conversion shopping list - parts required FAQ |
oscarsnapkin wrote: |
My first post in probably three or more years. Had twins, so the VW hobby has been kind of pushed aside, but I still get to enjoy driving my Bus. Anyhow, when I purchased my ‘77 it had a Weber progressive carb. and came with none of the FI parts. I bought a nearly complete FI system from a user here on thesamba and was able to fairly easily assemble an awesome running system. I had my injectors cleaned, used all new rubber seals/hoses, and made sure to clean the hell out of everything. Ratwell’s site made the process possible and his pictures and diagrams are indispensable. Definitely bench test everything when possible to avoid having to troubleshoot once it’s assembled in your Bus. I found a problem with my AFM before assembly that I’m sure would have been a hassle to have diagnosed otherwise. When I first decided to switch back to the FI system from the carb. (at the suggestion of other samba users) I thought it was going to be an overwhelming project, but it was actually very simple and straight forward. I would suggest studying Ratwell’s site and becoming familiar with the different parts and their functions. There’s also a troubleshooting guide that I downloaded from thesamba that was really helpful as well. I’m sure someone else here could probably post the link. Best of luck and don’t feel intimidated. |
good job and well written. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
