scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Fri Jan 06, 2017 6:40 am Post subject: Dump that Eberspacher BN4 heat into the dash vents! |
My BN4 is putting out great heat. It's fantastic heat. It's the best heat you can buy. I'm talking 220° at the duct. But it's all being wasted coming out under the back seat!
I want to duct that hot air, a la BA-6, to the dash vents, without hacking things up beyond repair. So before I start, would anyone care to share ideas or photos of your current gas heater solution? My heater is already bolted in and ducted into the cabin.. the heat just needs to go up front.
I've thought about cutting open the little macaroni noodle areas on the floor in the back - where some buses have rear vents - and ducting my heat into them with the heater box tubes blocked off.
Jake Raby mentioned something like that in passing once but he never went in to detail. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Fri Jan 06, 2017 8:31 am Post subject: Re: Dump that Eberspacher BN4 heat into the dash vents! |
do you have the arm rest ducts on the door?
if yes, could you duct behind the panels, up to the turn of the vents on the rear of the seating bulkheads. That is if you have bulkheads. what year bus you taking. |
busdaddy Samba Member
Posted: Fri Jan 06, 2017 8:35 am Post subject: Re: Dump that Eberspacher BN4 heat into the dash vents! |
I put a lot of thought into Y'ing the BN-4 into the main heat duct. I would have gone through the floor just ahead of the existing Y where both engine tubes come together using a made up box similar to the ones for the BA-6, I kept losing interest when it came to figuring out the anti return flaps or gates required, spring loaded?, gravity actuated?, how much is too much or not enough?
I ended up sealing up my heat exchangers and heat tube system super tight and adding a squirrel cage blower in line part way along the center tube under the cargo floor, now I can put all my engine heat on the windshield and heat the cabin with the Eberspacher. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jan 06, 2017 8:53 am Post subject: Re: Dump that Eberspacher BN4 heat into the dash vents! |
The non-return idea has kept me thinking as well. I'd say the most challenging part of putting stuff together here has been trying to keep things looking stock.. or just, not looking goofy and hacked up. It's really hard to hide generic FLAPS junk or homemade contraptions.
My bus didn't come with flow through arm rests, but I have been considering adding them when I buy new door panels. _________________ Robert in Memphis
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Fri Jan 06, 2017 9:17 am Post subject: Re: Dump that Eberspacher BN4 heat into the dash vents! |
for winter travel what do you think of just running some aluminum duct flex tube from the outlet under the seat to the cab area. Temporary but easy _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
pittwagen Samba Member
Joined: November 08, 2005 Posts: 766 Location: North of the 49th parallel
Posted: Fri Jan 06, 2017 9:45 am Post subject: Re: Dump that Eberspacher BN4 heat into the dash vents! |
You should be getting sufficient hot air to the front if your system is working properly. Having said that, adding a second blower up front to pull the air forward will make a big difference, particularly at slower speeds when the engine is not pushing max air. I have a stock late steel fan and housing with a 3 speed switch connected in line under the front floor. Front air flow is much better, defrosting especially, even with the stock rear fan on my 79.
Secondly, I have a late BN4 with the return air function and with the outlet in the center of the rear seat area so the hot air blows right up between the front seats.
I thought about running a T off the hot air pipe and dumping it down under the floor and coming up under the drivers seat into a front facing vent somewhere in front of the seat belt mount. Air would be controlled by a bowden cable so the one could have all hot to the front, rear or a combo. I would have used stock and current Espar parts for a professional looking and trouble free installation.
After using my current system for a year and now into a second very cold winter for us here on the south coast, I have not needed to go the extra ducting route. I have a switch controlling the BN4 at the front and a thermostat at the rear for overnight sleeping comfort. |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1731 Location: Portland
Posted: Fri Mar 31, 2017 10:12 am Post subject: Re: Dump that Eberspacher BN4 heat into the dash vents! |
pioneer1 wrote: |
for winter travel what do you think of just running some aluminum duct flex tube from the outlet under the seat to the cab area. Temporary but easy |
I did this when I first installed my unit and it worked great. The Eberspacher can warm the cabin pretty well when you are stationary. Cruising at 60MPH at sub 50 degrees and a rear cabin warm air exit does not keep the cab area very well heated. I swapped my louvered windows for sliders and that seemed to help. Putting in a full set of acrylic double paned windows would probably help even more. That said, the car is leaky at speed even with the front vents sealed up.
The BN4 is great for warming up the car in a camp site in the AM pretty rapidly if the roof is not popped tough. We have a switch in the back as well that is easy to reach from the bed.
Routing the BN4 output to the main duct via the duct to the rear seat outlet is a great idea. _________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
