Luggage rail rivets, what was used?
bigbulli
bigbulli is offline
PostPosted: Fri Jan 06, 2017 11:26 am    Post subject: Luggage rail rivets, what was used? Reply with quote
Does anyone know what rivets were used to hold on the rails and where I might find these? Would like to repair mine and put it back in the van.
1954 Barndoor
1955 Oval
campingbox
campingbox is offline
PostPosted: Fri Jan 06, 2017 7:27 pm    Post subject: Re: Luggage rail rivets, what was used? Reply with quote
Clara uses tubular steel rivets when she makes those panels - they are the same ones she uses for the cab dividers. You install them with a clincher tool. They look very close to the originals when they are installed.
I think they are close to 5/32".
bigbulli
bigbulli is offline
PostPosted: Sat Jan 07, 2017 1:01 am    Post subject: Re: Luggage rail rivets, what was used? Reply with quote
Many thanks Greg, appreciate the reply. I will see what I can find over here. Hope you are well. All the best, Rich.
1954 Barndoor
1955 Oval
RockStock
RockStock is offline
PostPosted: Mon Jan 09, 2017 10:34 am    Post subject: Re: Luggage rail rivets, what was used? Reply with quote
I have these (understood to be) original Barndoor rails. They are 610mm long. They still have a lot of their original rivets in place.
2 rails are black (Kombi?).
The other 6 look to be the lower body colour of a brown/brown Standard BD.
How do you specify rivets? Heads are approx 7mm diameter (with a hole), tails approx 8mm diameter (no hole).
Were these rails also used on accessory cab dividers?
Are these rails 50-55 specific, or were they also used for later years?
-StockRocks-
BeaterBarndoor
BeaterBarndoor is offline
PostPosted: Mon Jan 09, 2017 7:10 pm    Post subject: Re: Luggage rail rivets, what was used? Reply with quote
I haven't had a look at my originals but according to RS's photos I'd say they are 2 piece rivets like those used for the ashtray mounts. One "capped" side and one uncapped side , they mate together and need to be crushed to secure. Can kinda see in the photo in my ads
http://www.thesamba.com/vw/classifieds/detail.php?id=1896800
www.thebustransfer.com
Whaaaaat?
PostPosted: Tue Jan 10, 2017 8:41 am    Post subject: Re: Luggage rail rivets, what was used? Reply with quote
They were not used on Kombis for the back deck - Kombis were bare metal back there.
I have seen campingbox say in the past the rails are the same as the rails used on Panelvan cab dividers. This is on post-Barndoor Buses too.
I do not know if the length is the same, maybe he can answer that.
[size=9:180ed94369]Everett Barnes - [email protected] | My wanted ads
[b:180ed94369]Stop dead photo links! Post your photos to The Samba Gallery![/b:180ed94369][/size:180ed94369]
