Ovally Samba Member
Posted: Tue Aug 29, 2017 1:12 am Post subject: Re: Solid state 6 volt regulator |
Here is a 6V voltage regulator for 90mm generators.
https://www.paruzzi.com/uk/volkswagen/electricity/dynamo-and-alternator/1950/
Made for BBT and they claim it is 100% electronic.
You can switch the cover and use the original Bosch cover.
I do not have it myself so I can not say more.
Maybe someone else?
Regards. |
Bug-nut Samba Member
Joined: December 20, 2015 Posts: 488 Location: Knoxville, TN
Posted: Fri Sep 01, 2017 9:11 am Post subject: Re: Solid state 6 volt regulator |
That's pretty cool! Thanks for sharing! For $89.40 (not counting shipping) I might have to give that a try.
My regulator is still working fine, I've not had any trouble running all lights (high beams also) at night, it only starts to dim when the engine goes to idle. Thanks for the tip on sealing the cover screw; I was unaware that needed to be done. _________________ 1959 Fjord Blue Volkswagen Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1962 Austin-Healey Sprite
Snort wrote: |
A 59 Beetle is just an Oval-Window car with aspirations of modernity. |
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
Posted: Fri Sep 01, 2017 9:40 am Post subject: Re: Solid state 6 volt regulator |
herbie1200 wrote: |
OK OK but my question is still unanswered.
Stock 6V generator can produce up to 6V-45A (~270W).
When using a 30A regulator watts available drop to 6*30=180W.
This is not good; 90W are dropped out. In some condition you need all of 270w available: high beam (90W) + park lights (30W) + engine (~20W) + turn signal (42W) + stop light (42W), you have no residual current to charge battery.
If the 6V30A regulator is well working it should drop voltage when more than 30A are requested... so your 45A generator is used under of its capability. |
The local starter/generator shop owner of 40 years, said after testing hundreds of 90mm generators he never saw more than 25A at 6V, not 7.2V.
I have a digital volt meter on my '66, the meter input wire connects directly to the regulator terminal with no other loads to cause a voltage drop. After the battery is charged, the voltage is 7.2V, but with the lights on (13A) it drops to 6.8V. Not good, because 6.8V does not charge the battery. I have had two engines in my '66, both generators have the same limitations.
The generator will burn up with too much current. The regulator has a current limit winding, it limits the current to prevent damage to the generator windings.
More info:
https://www.thesamba.com/vw/forum/viewtopic.php?p=5460190
_________________ Additional products https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231 |
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 350 Location: Green Bay, WI
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Thu Sep 21, 2017 10:49 am Post subject: Re: Solid state 6 volt regulator |
I ordered one, it arrived today.
I will take photos of the inside, and install it tonight and update y'all. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
Ovally Samba Member
Posted: Fri Sep 22, 2017 3:00 am Post subject: Re: Solid state 6 volt regulator |
Thanks, I look forward to see the photos and what your experiences are with this solid state 6V voltage regulator.
Regards. |
Posted: Fri Sep 22, 2017 5:38 am Post subject: Re: Solid state 6 volt regulator |
Here it is, not much to it.
You can swap the cover out with the Bosch cover if you want.
Made by BBT, sold through JP Group.
I have yet to test it.
Cover removed.
All Potted in
Box
1966 Ghia (sold)
1966 Red Beetle |
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Fri Sep 22, 2017 7:02 am Post subject: Re: Solid state 6 volt regulator |
Dear Mr.Duncan
Can I suggest a couple of tests on this unit? From results I can describe how this item works, if interested. Also, it will be a test of correct working.
So, after installing it and fully wired, if you want you should:
1) Connect a multimeter between ground and double B+ regulator terminal, start engine (all electrical accessories off), to accelerate directly from the carb leverage and to measure the max voltage reached.
It should be from 6.0V at idle up to 7-7,2V at 3000rpm. Could you post exact max measurement?
2) temporarily detach the spade connector that now is on oil bulb and connect it to the "DF" terminal , so the oil light gives an idea of how regulator is shaping generator excitation.
Please confirm that you should note that:
- at engine stopped or idling green light is fully "on"
- when engine revs up green light starts to blink (or fading)?
- when engine is very fast green light is almost off
- if, when at middle revving, you turn on high beam, the green light should "enforce" its lighting.
After test n.2) remember to reconnect the spade connector to the oil pressure sensor.
Thank you in advance if you plan to make those tests. |
Posted: Fri Sep 22, 2017 11:28 am Post subject: Re: Solid state 6 volt regulator |
herbie1200 wrote: |
Dear Mr.Duncan
will do, I may need to change my generator first.
I was having charging issues (My battery would be at 6.3 volts with the engine running.) and a dimly glowing generator light that increased with RPMs, and increased while hitting the brakes.
(Resting voltage of my battery is 6.38 volts.)
All my ground connections were clean, same with the positive side, and the battery is only 2 months old.
With the regulator unhooked, I was able to get 20 volts out of my generator but only at 4000 rpm engine speed.
Yes, I did polarize the generator too.
I tried 4 mechanical regulators, all gave me the same battery voltage of 6.3 volts with the engine running, and the solid state relay does the same.
I think my generator is on its way out, and I can pickup a rebuilt one at Oreilys for $90.
Will test it out next week. _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Fri Sep 22, 2017 11:59 am Post subject: Re: Solid state 6 volt regulator |
Disconnect your generator from the regulator, then run a jumper from the DF terminal of the generator to the D- terminal (or other good ground).
Connect a voltmeter between D+ and ground.
Start up the engine - at idle you'll probably see around 6v but it should go up dramatically as the engine is revved. You should easily see upwards of 35v well before you get to 4000 rpm.
Just only do this test for a few seconds, otherwise you will burn out the generator. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Fri Sep 22, 2017 12:06 pm Post subject: Re: Solid state 6 volt regulator |
sjbartnik wrote: |
Just only do this test for a few seconds, otherwise you will burn out the generator. |
I did, and only got 20 volts around 4000 rpm. _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6593 Location: Houston, Texas
Posted: Sun Sep 24, 2017 10:20 pm Post subject: Re: Solid state 6 volt regulator |
I've got 111 903 801 C NOS Bosch.
Edit: Bosch number is 0190213001 _________________ www.vwnos.com [email protected]
Posted: Mon Sep 25, 2017 1:41 am Post subject: Re: Solid state 6 volt regulator |
Mr.Duncan wrote: |
sjbartnik wrote: |
I did, and only got 20 volts around 4000 rpm. |
It's fine.
I think 35V (whitout load neither regulator) are a goal for 12V generators. For 6V goal is about a half (~18V). |
Posted: Mon Sep 25, 2017 5:43 am Post subject: Re: Solid state 6 volt regulator |
herbie1200 wrote: |
Mr.Duncan wrote: |
sjbartnik wrote: |
It's fine.
I've tested:
1 NOS Bosch regulator
2 aftermarket regulators
1 Solid State regulator.
and cant get my battery voltage above 6.3 volts while the engine is running.
Maybe the new battery I have is a dud? _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
bluebus86 Banned
Posted: Mon Sep 25, 2017 9:20 am Post subject: Re: Solid state 6 volt regulator |
Mr.Duncan wrote: |
herbie1200 wrote: |
Mr.Duncan wrote: |
sjbartnik wrote: |
It's fine.
I've tested:
Maybe the new battery I have is a dud? |
ok 6.3 volt when running, what is the batterynvoltage when engine is off, what is voltage when battery is disconnected from car? if the answer you find is 6.3 volts, then connect battery to a portable charger hooked to house current (with battery disconnected from car) charge over night, do not exceed about 10 amps charge during this time. also check to make sure the plates are covered in fluid, if low, add DISTILLED water to correct level if needed. after over night charge disconnect battery for a few hours so surface charges can disapate. (thse surface charges will give a false high reading of volts) then remeasure, if still 6.3 volts, then the battery has a problem. of course make sure your volt meter is reading correct, why not measure the voltage off another car with a good battery, even a 12 volt car, or borrow a second meter to confirm the low voltage.
sometimes a battery can be bad when purchased, rare but it happens
good luck now zap this issue! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
'64cal lookdub 1200 Deluxe
heimlich VWNOS.com
Posted: Wed Sep 27, 2017 10:30 pm Post subject: Re: Solid state 6 volt regulator |
One of my Beetles still has the original regulator in it.
It's amazing that new is more expensive than NOS. _________________ www.vwnos.com [email protected]
Posted: Mon Sep 24, 2018 12:10 am Post subject: Re: Solid state 6 volt regulator |
I bought this solid state regulator and tested it; not satisfied. Noticed those issues:
1) it starts charging over 2000rpms, so into city traffic battery never charged
2) due to a poor design, this regulator drops 0,7~0.8 Volts from generator to battery, I think they used a normal silicon diode for the cut-off. Some power then is wasted and the generator light has always a small glow, due to the wasting of voltage.
I'm going to return this regulator to the seller. |
rcroane Samba Member
Joined: January 03, 2013 Posts: 2000 Location: Springfield, Virginia
Posted: Mon Sep 24, 2018 4:33 am Post subject: Re: Solid state 6 volt regulator |
herbie1200 wrote: |
Which one did you buy? WW? _________________ '65 Sunroof Bug |
