jerrybromley Samba Member
Joined: August 06, 2016 Posts: 124 Location: Michigan
Posted: Wed Jan 11, 2017 2:15 pm Post subject: It's always worse than you think My 73 convertible rebuild |
Here's my 73 convertible the day I brought it home for a winter project
don't get me wrong I knew it was going to need a lot of work. (I even bought a new miller MIG) but this surprised me
We all know the Super relies on the body to support the steering and that part of the body was rusted beyond repair, so some one found an interesting alternative
I'm not even sure what kind of rack and pinion this is but the steering linkage had an extra ujoint in it and felt a little jerky
The damage did not end there
Well you get the idea . What will follow as I get to it will be the pictures of my attempt to save this poor old girl and have her safe and fun to drive again
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Wed Jan 11, 2017 2:38 pm Post subject: Re: It's always worse than you think My 73 convertible rebuild |
The first order of business was to fix the chassis and floors
Posted: Wed Jan 11, 2017 3:02 pm Post subject: Re: It's always worse than you think My 73 convertible rebuild |
And then on to the rear of the car
and test fit
Chad1376 Samba Member
Joined: January 29, 2005 Posts: 1435 Location: Henderson, Nevada
Posted: Wed Jan 11, 2017 3:52 pm Post subject: Re: It's always worse than you think My 73 convertible rebuild |
Wow - you are a brave man. Looking at what's you've repaired so far, I'm sure you'll be able to bring that car back to life. Keep at it. |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Wed Jan 11, 2017 7:22 pm Post subject: Re: It's always worse than you think My 73 convertible rebuild |
A 73 with rack n pinion? That a PO addition?
Ambitious for sure, but looks like you are handle it . Good job. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
wcfvw69 Samba Purist
Posted: Wed Jan 11, 2017 8:02 pm Post subject: Re: It's always worse than you think My 73 convertible rebuild |
I saw your title, then looked at your "before" picture where it didn't look too bad. I also noticed the Michigan license plate in that picture and thought "this isn't going to be good"..
You are a brave guy. Keep chipping away at it. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Thu Jan 12, 2017 6:57 am Post subject: Re: It's always worse than you think My 73 convertible rebuild |
Thanks for all the encouragement Lord knows I can use all I can get
So as I looked over the front of the car I assumed I would have to cut it apart piece by piece and weld it back together as I had seen others on Samba do.
As it happens I was given the phone number to WAYOUT Salvage in Kingston (Arizona) edit Arkansas
(479.665.4126)
I had many conversations with Derrick and came up with a different plan
Here's the next installment
The rust that you can see is minimal mostly surface. Arizona is of course so much drier than Michigan even the areas I can't get to will be in better condition than mine
Last edited by jerrybromley on Sun Sep 17, 2017 11:19 am; edited 1 time in total |
Zundfolge1432 Samba Member
Posted: Thu Jan 12, 2017 7:09 am Post subject: Re: It's always worse than you think My 73 convertible rebuild |
Derrick is located in Arkansas, Kingston Ark.
www.wayoutsalvage.com |
garyt Samba Member
Posted: Thu Jan 12, 2017 7:14 am Post subject: Re: It's always worse than you think My 73 convertible rebuild |
Late model SB floorpan, came with rack and pinion. Nice work. Was it originally orange? |
Posted: Thu Jan 12, 2017 7:15 am Post subject: Re: It's always worse than you think My 73 convertible rebuild |
I have never taken a car of any kind apart at this level and this is my first VW of any kind so............ Ignorance is bliss I dove it
As you can see I started by cutting away small sections to see what I was getting into. At each point I tried to leave some of the original car so if need be I'd have something to weld to |
vamram Samba Member
Posted: Thu Jan 12, 2017 7:18 am Post subject: Re: It's always worse than you think My 73 convertible rebuild |
That is amazing. The car screamed "CRUSHER, PLEEEEEASE!!!
Are you keeping the rack and pinion? I think the section to the front of the napoleon's hat is shaped differently for that than a factory '73. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Thu Jan 12, 2017 7:19 am Post subject: Re: It's always worse than you think My 73 convertible rebuild |
Yea the car was orange and I have been told that late models had rack and pinion ........But trust me this was definitely not factory or for that matter I doubt it was a VW rack |
Posted: Thu Jan 12, 2017 7:27 am Post subject: Re: It's always worse than you think My 73 convertible rebuild |
OK so now we are in the present and here is my first test fit
My goal here is to make sure all the body bolts line up with the chassis bolt holes . Then bolt everything in place and weld it back together
More photos will come but from here on out I seem to be in charted waters |
Posted: Thu Jan 12, 2017 1:12 pm Post subject: Re: It's always worse than you think My 73 convertible rebuild |
WOW My bad !!!! I thought AR was Arizona, Well the clip is pretty solid anyways
Thanks for the correction! |
260KMN Samba Member
Joined: January 17, 2014 Posts: 236 Location: Devon UK
Posted: Thu Jan 12, 2017 2:13 pm Post subject: Re: It's always worse than you think My 73 convertible rebuild |
Excellent work and dedication. That car was bad.keep up the good work. |
Posted: Tue Jan 17, 2017 7:08 am Post subject: Re: It's always worse than you think My 73 convertible rebuild |
Transplant nears completion.
I still have some cosmetic welding to do inside but the structure is now solid
This is the front cleaco'ed in place
Welded solid ......The front end is one with the body
She kinda looks like Frankenstein's bride _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=670629&highlight= |
garyt Samba Member
Posted: Wed Jan 18, 2017 10:36 am Post subject: Re: It's always worse than you think My 73 convertible rebuild |
You're good at this.
Wonder what the rack came from if not a late beetle?
What will you put on it? Apparently late 3 bolt is easier to change ball joints than later two bolt struts. |
vamram Samba Member
Posted: Wed Jan 18, 2017 10:49 am Post subject: Re: It's always worse than you think My 73 convertible rebuild |
garyt wrote: |
If I have to work on the suspension, I prefer my '74's 2-bolt strut setup than my '72's. Changing the ball joints is easier on the ealier 3-bolts, but changing the strut insert is a lot harder. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
