Envious Samba Member
Joined: January 08, 2003 Posts: 1819 Location: Toronto, Ontario, Canada
Posted: Thu Jan 12, 2017 7:40 am Post subject: Correct finish for misc engine parts |
I'm putting together the S motor for my 64 and I'm trying to determine the correct factory finishes for some of the parts and pieces that have either been lost and replaced, painted, or rusted over the years.
I realize that a lot of people posting in this forum don't care about these details. I get that.
I'm looking for correct finishes for:
a) distributor clamp (black or zinc?)
b) the clamps used for the intake boots to the air cleaner. (thinking zinc)
c) clamps for the boots to these exhaust elbows. I have NOS and they're a factory flat grey paint?!? _________________ 71 Type 1302 Custom
64 Type 151
63 Type 117 L469 Anthracite
64 Type 361 L575 Nutria
64 Porsche 356c
56 Type 113 L227 Strato Silver
52 BSA C11G
59 Heilite Single Wheel Camping Trailer
56 Allstate Single Wheel
84 Vanagon Westfalia
http://www.thesamba.com/vw/forum/viewtopic.php?t=388225 |
gregson1 Samba Member
Posted: Thu Jan 12, 2017 8:38 am Post subject: Re: Correct finish for misc engine parts |
The grey paint on the elbows is proper, and that goes for the early parts pictured and the later elbows, as well. It's a high zinc paint that the stock muffler systems were finished in.
The distributor clamp is an interesting question. My wife's '65 Type 14 distributor clamp was painted black, but I have a pile of those Type 3 clamps and some are painted, and some are not. I was going to go painted, including the sleeve, and use a black oxide nut.
Curious to see what others have to say. |
Posted: Thu Jan 12, 2017 8:47 am Post subject: Re: Correct finish for misc engine parts |
gregson1 wrote: |
How about the clamps? _________________ 71 Type 1302 Custom
64 Type 151
64 Porsche 356c
52 BSA C11G
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21474 Location: Oklahoma City
Posted: Thu Jan 12, 2017 8:55 am Post subject: Re: Correct finish for misc engine parts |
I do not know for your exact model.....but items like the distributor clamp....both from a "what I remember"....what I still have.....and how things have aged/decayed over the years.........I would say they are zinc + something else. But they do not seem to have normal zinc plate characteristics.
What is the most probable....just from how they AGE.....is that they are white cadmium with some light passivating layer over the top.
I note how they age....because over time they develop a white dusty/dull look. When they get wet and sit for long periods they bloom out with white corrosion that look like thin crusty salt.
This is characteriatic of cadmium. One thing I have realized over the years....is that if these are cadmium......that white residue is VERY toxic and will bio accumulate in your system. Wire wheeling should nit be done. Ray |
bobnorman Samba Newfoundlander
Joined: August 09, 2010 Posts: 1389 Location: Newfoundland
Posted: Fri Jan 13, 2017 9:52 am Post subject: Re: Correct finish for misc engine parts |
I just finished cleaning up the clamp on my 64. It was black. The head of the bolt was black too. The nut and the tube were zinc plated. Pretty sure it's original, nobody would have bothered to paint it back in the day when it was running. _________________ Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
notchboy Samba Member
Joined: April 27, 2002 Posts: 22416 Location: Escondido CA
Posted: Fri Jan 13, 2017 10:44 am Post subject: Re: Correct finish for misc engine parts |
That distributor clamp in that pic looks amazing. Like new spot on restoration. That kind of gleaming part is hard to find. Simply stunning.
The elbow clamps are rough zinc - the old ones. But Ive seen that goldish shit and chromish too. But those should be later replacement parts. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33883 Location: Conejo Valley, CA
Posted: Fri Jan 13, 2017 11:56 am Post subject: Re: Correct finish for misc engine parts |
I have seen replacement clamps that were painted black. Type 3 clamps got replaced often as owners/mechanics over-tightened them and broke off the little weld or tab keeping the bolt from rotating. On a Bug or Bus you just used two wrenches, but the location on the T3 made that impossible, so they had to be replaced or welded. So the black one could be NOS, or it could be an aftermarket or replacement part. |
Posted: Fri Jan 13, 2017 3:40 pm Post subject: Re: Correct finish for misc engine parts |
notchboy wrote: |
That distributor clamp in that pic looks amazing. Like new spot on restoration. That kind of gleaming part is hard to find. Simply stunning. |
What a d*ck!
Yes. Nice job, Jason. Is there a finish on the barrel and nut or are they wire wheeled and raw? _________________ 71 Type 1302 Custom
64 Type 151
64 Porsche 356c
52 BSA C11G
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Fri Jan 13, 2017 3:55 pm Post subject: Re: Correct finish for misc engine parts |
That style distributor clamp was originally black. I have a bag of old ones.
#2
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Jan 13, 2017 4:08 pm Post subject: Re: Correct finish for misc engine parts |
Envious wrote: |
notchboy wrote: |
What a d*ck!
Yes. Nice job, Jason. Is there a finish on the barrel and nut or are they wire wheeled and raw? |
Bwaa.
Wire wheel raw. Satin Black paint. _________________
t3kg wrote: |
1964 1500 S
