sjdineen88 Samba Member
Joined: September 01, 2016 Posts: 5 Location: Seattle
Posted: Thu Jan 12, 2017 6:43 pm Post subject: Eurovan Replacement Clock Spring Source |
Hello All,
I replaced my heater core this summer, and in the process I think I may have broken the clock spring. I have airbag and abs/esp lights that won't go away, and the horn doesn't work.
The replacement part runs close to $500 everywhere I can find it...does anyone know of a cheaper source? I'd rather not drop $500 when I don't know for sure if it will fix my problem. Also if anyone can suggest ways to test the clock spring, I'd appreciate any tips. I plan to check the airbag harness continuity next time I take it apart.
Thanks! |
Joined: August 31, 2013 Posts: 12857 Location: North Carolina
Posted: Thu Jan 12, 2017 7:18 pm Post subject: Re: Eurovan Replacement Clock Spring Source |
I don't know for sure but VW has a tendency to take advantage of their vast parts bin. I would take a look at possible cross referencing it to a Golf, Jetta, or Passat & try to source it through a local pick-a-part. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1268 Location: Bethlehem, PA
Posted: Fri Jan 13, 2017 2:17 pm Post subject: Re: Eurovan Replacement Clock Spring Source |
Maybe take the part number and put it in Alibaba? You never know. |
Itsamoto Samba Member
Posted: Fri Jan 13, 2017 3:11 pm Post subject: Re: Eurovan Replacement Clock Spring Source |
At $500 - you're pretty close to just buying a whole parts van.
I'm still trying to find a cost reasonable solution - such as using one of these from another VW. The Eurovan unit, from all that I know - is unique to the van. Its shape and form factor allow it to fit into the back of the steering wheel, where as on Jetta/Golf/Passats the unit is larger/different and covered by a cowling. So there is some hope there to retrofit a different clockspring/sensor - but it may take some serious fiddling.
There was some talk on this topic before (where I've posted pics of my failed unit), here: http://www.thesamba.com/vw/forum/viewtopic.php?t=646985&start=0 |
d-9 Samba Member
Posted: Fri Jan 13, 2017 3:37 pm Post subject: Re: Eurovan Replacement Clock Spring Source |
Afaik the esp clock spring with steering angle sensor is unique to the T4, I spent a while looking at the parts catalogue because I need this to make my horn work!
Would love to be proven wrong on this, so please post up if you find a match. I would also buy your broken clockspring if you manage to find a replacement!
Have you checked with VCDS what faults are showing, or looked to see if there is a calibration procedure? |
gakali Samba Member
Joined: August 19, 2007 Posts: 448 Location: Cambridge, Ontario, Canada
Posted: Fri Jan 13, 2017 4:16 pm Post subject: Re: Eurovan Replacement Clock Spring Source |
See if these guys can help you out looks like they have a whole van for parts.
http://www.ebay.ca/itm/REAR-WIPER-MOTOR-LIFTGATE-F...mp;vxp=mtr _________________ Why do it? Because you can.
1999 Eurovan
2003 A4 Avant 1.8T Quattro
1992 W201 190e 2.3 Mercedes
2006 W220 S600 V12 Twin Turbo 5.5 Mercedes |
Posted: Fri Jan 13, 2017 4:37 pm Post subject: Re: Eurovan Replacement Clock Spring Source |
d-9 wrote: |
Yes - the unit failed internally. I was chasing codes and such as well - finally I had to open it up to see if I could fix it myself (I can't). Board level failure - traces rubbed off.
If I figure out a fix/replacement -- then (@D-9) I'd be willing to swap it for a power-equipped side view mirror (RHD version). |
d-9 Samba Member
Posted: Tue Jan 17, 2017 1:25 am Post subject: Re: Eurovan Replacement Clock Spring Source |
Hah I'll see what I can do itsamoto |
Posted: Wed Feb 01, 2017 4:11 pm Post subject: Re: Eurovan Replacement Clock Spring Source |
Well thank you for all the replies, but I ended up taking it to my local Westy shop (Peace Vans, Seattle) due to time constraints on my end, and not wanting to be on the hook if I mangle another $500 part trying to install it... The bad news is their part cost was ~$600 and they wouldn't take an owner provided part. The good news is I have my horn, ESP, ABS, and airbag back.
FYI if you have an ESP equipped van, the part is ~$500. If it doesn't have ESP the part is ~$200. I do wonder how hard it would be to modify the non-ESP part to work... |
Posted: Wed Feb 01, 2017 4:14 pm Post subject: Re: Eurovan Replacement Clock Spring Source |
The non-ESP part is one part number different...they might be pretty similar. |
Posted: Wed Feb 01, 2017 9:53 pm Post subject: Re: Eurovan Replacement Clock Spring Source |
There is hope! According to the german T4 wiki - the arrow here is pointing to the ESP device that is part of the steering angle sensor.
Joined: February 15, 2020 Posts: 1 Location: new york
Posted: Fri May 29, 2020 6:17 am Post subject: Re: Eurovan Replacement Clock Spring Source |
My 02 eurovan needs a new clock spring, will not pass inspection. The clock spring is no longer manufactured. Its the one with EPS. I have called mutliple junk yards, searched everywhere high and low, called eurovan mechanics. No one can help me. The car runs fine, do I just junk it!? I'm so bummed its valued at 6k but now it seems its value is 0 bc of this. |
Broseph Stalin Samba Member
Posted: Fri May 29, 2020 9:55 am Post subject: Re: Eurovan Replacement Clock Spring Source |
Won't pass inspection because it has CEL's??? I see the non-ESP clock spring is still available.
https://parts.vw.com/p/Volkswagen__/Air-Bag-Clockspring/49106316/7D0959653.html
The NLA PN is 7D0959654. I guess if the non-ESP is suitable, you guys with ESP-equipped vans should buy one now before they also go NLA . . . .
Reading some other threads I think all you lose is the more sophisticated aspects of ESP - yaw control, engine modulation. You still have fourwheel ABS and lo-speed traction control on the front wheels.
For instance, all EVC's were imported without ESP, but still had fourwheel ABS and lo-speed traction control, airbags. I bet the EVC uses 7D0959653. _________________ '68 Bus in West Germany, 1977-1979
'67 Riviera poptop conversion in the US, 1984-1990
'95 EVC Winnie, 2018, Sold
'03 EVC Winnie, 2018, Sold |
Posted: Thu Jun 04, 2020 11:52 pm Post subject: Re: Eurovan Replacement Clock Spring Source |
This is an issue that will keep coming up -- as I believe the traces on the ESP wheel position sensor (clockspring) wear off over time.
I donated my failed unit to Doug at VAR PARTS to have him see if he could come up with a replacement board -- to make this a repairable situation for all of us - rather than a $500 part. He thinks he can do something to fix this.
Doug seems like a good guy with a good little business - doing mods on ECU's etc. I had an immobilizer II issue with one of my vans (broke the chip in key trying to fix it) and it was cheaper/easier to send him the ECU to do an immo delete than to get Vagtacho to read the SKU (it can't!).
Anyhow, maybe inquire with him and see if he can do a board level repair of the traces. I think if more of us contact him and he knows the demand for this fix is real -- he may prioritize the fix. |
Joined: January 03, 2010 Posts: 297 Location: Amesbury, MA
Posted: Thu Jun 25, 2020 2:04 pm Post subject: Re: Eurovan Replacement Clock Spring Source |
I did look into the non esp clockspring
View Air Bag Clockspring Full-Sized Product Image
Part Number: 7D0959653
Supersession(s): 7D0-959-653
Not even close for fitmet, has anybody got this to fit _________________ 2001 eurovn weekender 207k fresh batteries |
boostin20v Samba Member
Posted: Fri Jun 26, 2020 1:40 pm Post subject: Re: Eurovan Replacement Clock Spring Source |
[email protected] wrote: |
it shouldn't be causing a CEL...what specifically isn't your van passing inspection for? Mine needs replaced...and don't have any issues with inspection. |
Posted: Sat Jun 27, 2020 8:38 am Post subject: Re: Eurovan Replacement Clock Spring Source |
Actually you are correct
the lack of a decent clockspring, does not effect my inspectability _________________ 2001 eurovn weekender 207k fresh batteries |
ELO78 Samba Member
Joined: September 18, 2015 Posts: 168 Location: Oak Park, IL
Posted: Sun Jun 28, 2020 9:41 am Post subject: Re: Eurovan Replacement Clock Spring Source |
https://www.jimellisaudiparts.com/products/Audi/Ca...59654.html
I have no experience with this vendor, but it appears they have the air bag clockspring with steering sensor for the 2002-3 EV. Good luck! _________________ Eric
1990 Westy Multivan, 2.1 L WBX, 4-speed - SOLD
2003 EuroVan Westy Weekender |
Posted: Sun Jun 28, 2020 12:29 pm Post subject: Re: Eurovan Replacement Clock Spring Source |
Thanks I did go and hit that link, looks to be the last few left until they can be cloned
Sam _________________ 2001 eurovn weekender 207k fresh batteries |
Posted: Mon Jun 29, 2020 4:43 pm Post subject: Re: Eurovan Replacement Clock Spring Source |
actually the part on that link is no longer available
The soviets have some it appears
sam _________________ 2001 eurovn weekender 207k fresh batteries |
