sled Samba Member
Posted: Sat Mar 27, 2021 11:56 am Post subject: Re: 2276/86b beetle daily |
just curious, what deck height and compression were you running? _________________ drive your split. |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Sat Mar 27, 2021 12:06 pm Post subject: Re: 2276/86b beetle daily |
The chamber on the left of this pic looks like it was leaking where the heads seals against the cylinder? I notice what looks like carbon deposits from burnt mixture escaping the chamber at 9 o'clock. Do you run head gaskets? Maybe the top of that cylinder isn't perfectly flat? _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
Posted: Sat Mar 27, 2021 1:06 pm Post subject: Re: 2276/86b beetle daily |
sled wrote: |
just curious, what deck height and compression were you running? |
40 thou/ 10.2:1
evanfrucht wrote: |
UK Luke 72 wrote: |
[img]https://www.thesamba.com/vw/gallery/pix/2162214.jpg[/img |
The chamber on the left of this pic looks like it was leaking where the heads seals against the cylinder? I notice what looks like carbon deposits from burnt mixture escaping the chamber at 9 o'clock. Do you run head gaskets? Maybe the top of that cylinder isn't perfectly flat? |
Good observation, that's cylinder 3 which was up around 170-180psi though. I didn't do a leakdown but I have no reason to suspect no3 at all.
When it goes back together it'll have new cylinders. _________________ 2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172 |
challomoner Samba Member
Joined: October 13, 2010 Posts: 1214 Location: IRELAND
Posted: Sat Mar 27, 2021 5:20 pm Post subject: Re: 2276/86b beetle daily |
UK Luke 72 wrote: |
Valves all sealing, none of the guides appear to have moved although it'll be a bit more obvious once I've finished stripping them.
Rocker side play shims are worn pretty bad. Hopefully just bad heat treatment of the shims, the rockers/shafts all look fine. |
There's a guy here selling spring steel shims, I bought some for my build and they still look new.
https://www.thesamba.com/vw/classifieds/detail.php?id=2026651 |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Sat Mar 27, 2021 6:21 pm Post subject: Re: 2276/86b beetle daily |
He buys the shims from your side of the pond I believe. PM him and I’m sure he will let you know. He is a great guy |
Posted: Thu Apr 01, 2021 3:27 am Post subject: Re: 2276/86b beetle daily |
So everything is stripped and cleaned ready to go back together once I have the heads flowed and rebuilt.
I had a basic port job done on the heads 20 pages ago to kinda cover up from a bad amateur job they had before I bought them. I don't have the eye to know if the ports are any good but I thought I'd blend the valve seats into the port walls a little better. The guides came super long into the port too, so I've trimmed around 3-4mm off those. Looked alike a choke point.
They will be flowed at 10" up to .55"
Cam and lifters are perfect (FK10 and Engles phosphate coated lifters)
Clutch looks barely used, not bed in enough to be contacting eith the pressure plate of flywheel uniformly.
Oh and I've dropped in a dist drive so I can go sequential
Just waiting for an extended oil pickup tube so I can button up the case.
Old one wasn't too difficult to get out, a few whacks with the hammer. Hopefully the new one will go in ok with a bit of sealer on it.
Will I be able to use as std strainer now? _________________ 2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7215 Location: Videbaek Denmark
Posted: Fri Apr 02, 2021 2:24 pm Post subject: Re: 2276/86b beetle daily |
Its gonna be interesting to see. I´ll be surprised if they flow above 170 cfm @ 25" (Apprrox 107 " @10")
But I like to get positive surprises.
The theoretical choke point of a 42 mm valve is 0,578", so they should really be tested at least to 0,575" IRL they will most likely plateau at around 0,550-0,560" due to the small seat ID.
Have him test the exhaust side too and measure port flow veloctity. I´m pretty sure he has the tools to do it. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Fri Apr 02, 2021 4:54 pm Post subject: Re: 2276/86b beetle daily |
Yes, the seat can´t be fixed. It is too thin and will need replacement.
In a sense you are correct. But if "we" know how the port behaves a little over max lift along with port volume, it is somewhat easier to predict how the engine will behave. But I´m quite certain that Alan will give you a crash course in that when the time comes. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Sat Apr 03, 2021 8:57 am Post subject: Re: 2276/86b beetle daily |
No, the idea is not ridicoules, but I doubt you will gain much, if any. At least not if the valve to chamber relation is ok. I believe Brian E tested a little around exactly that subject some time back. He may chime in. Also, IMHO the percentage is not really valid at all sizes. with small valves it is not enough and with large valves it is too much. I work much more with how much is needed to make a proper seat. Then I vary the seat ID after what type of engine I am building. For instance, for a bus engine that should pull torque over the last few ponies up top I like a seat diameter of - 4,5 mm to valve. For street engines for Beetles, buggies, weekend warriors etc I am usually around -4,1-4,2 as is a good deal of other people. For all out engines with high valve lift and high rpm you can go as low as about - 3,25 mm. but that low requires the 30-33 degree angle to be wider than normal, like at least 3 mm. and the chamber shape becomes crucial if it is to work properly.
Edit.
To illustrate a little about it i can refer to some Coventry engines of which we have built a few over the last couple of years. Those engines are only 1460 cc in this configuration and pulls 104 BHP in stock form. We were chasing power, and driveability since it is a street legal track car (1956-62 I beleive) Stock valves 35 x 32. Performance valve set up 37 x 33. In this case I opted for -4,25 mm in order to get the "best of both worlds" as it is a relatively small engine, with a relatively aggressive cam. Then we had the cam ground on a semi tight lobe separation (105 degrees) Ported cylinder head, 10-1, dual 40 DCOE´s header etc etc. This resulted in almost 130 hp @ 6700 and 145 Nm peak torque with more than 120 Nm over 3500 rpm. Decent for a small engine that can be used with good fun on the track too. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Tue Apr 06, 2021 9:33 pm Post subject: Re: 2276/86b beetle daily |
Decided to have a little go at the manifolds.
Quick refresher on these, I bought them off a mate who had done a home brew wedge port on them with the mofoco heads.
Pretty badly but made 160bhp on them.
In the first picture, this is how they were. 2nd picture shows where I have removed around 1.8mm. This was a pretty obvious choke point before it opened up to the flange then down again towards the valve.
Now from around 1/3rd up the manifold down to the flange is about as even as I can get although it does definitely flare open a little at the flange. Would need welding to remedy
Posted: Wed Apr 07, 2021 5:43 am Post subject: Re: 2276/86b beetle daily |
Alstrup wrote: |
Its gonna be interesting to see. I´ll be surprised if they flow above 170 cfm @ 25" (Approx 107 " @10")
Have him test the exhaust side too and measure port flow velocity. I´m pretty sure he has the tools to do it. |
Are those with the manifolds on and at 0.5" lift?
Going to see Alan Friday morning. _________________ 2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3290 Location: Rapid City, SD
Posted: Wed Apr 07, 2021 11:16 am Post subject: Re: 2276/86b beetle daily |
If you have an ID snap gauge you can use it to get an idea of the sizes in different spots. The manifolds are looking good. The slightly larger area at the flange is not usually a problem, and some times it helps slow the air down so it's able to make the turn into the bowl easier. It helps the air stay attached. From here, it looks like the throats just before the seat ring could use some work. I agree with Torben's current flow estimates.
Have you measured the port volume yet? I like to measure the volume, and centerline length, and then with the flow CFM, you can calculate the average port velocity. I have found every set of heads I built over 270ft/sec average pull REALLY hard. Lots of torque, even with smaller than usual valves. Lately I have been shooting for 280ft/sec. Just for reference a stock 35x32 head is about 250ft/sec stock, and an off the shelf AA500 is about 240ft/sec.
ALWAYS flow the heads with the manifold on. It will change the number drastically without, and the engine will never be running without the manifold.
I am eager to see what you guys can come up with. Does your guy have local velocity measuring tools?
Brian
Brian _________________ www.type-emotorsports.com |
Posted: Wed Apr 07, 2021 11:38 am Post subject: Re: 2276/86b beetle daily |
What Brian said.
Yes, with manifolds.
Max flow will occor above 0,500" if the port and seat is decent. Slightly dependant on which formula you use the theoretical choke point is Somewhere between 12,7 & 14,7 mm. So in best case scenario it will keep on improving until 0,578". It wohnt, but if we take best case scenario for a 40 mm valve it will stop improving at 0,555". For comparison my super stock heads based on AA500 castings keep on flowing to 0,530" with a 37,5 mm valve. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Wed Apr 07, 2021 12:33 pm Post subject: Re: 2276/86b beetle daily |
Thanks guys.
I was using internal calipers to even all 4 out, used them as a go-no go and ground out accordingly.
I will get a port volume taken over the weekend when I get them built up again. I'll have to Google how to get the centreline length, not sure if I'm tooled to be able to do that.
Is there anything I could do with the valve throat before I get them flowed or best just to see what we're working with and leave it as is?
Currently lifting the valve to 13.59mm. I appreciate they'll never match what you two can do with a pair of heads but I'd like to make the most of what I have.
Adding sequential spark and fuel to the mix will hopefully bring some improvements too _________________ 2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
