sallyandsean Samba Member
Posted: Fri Oct 25, 2019 12:36 am Post subject: Holley 2100 bugspray technical help needed |
Hi all
Just picked one up and first thing was to cut the single port manifold to fit my twin port. I have a 12v manifold heater to fit so that should sort the iceing. I can see the idle screws at the bottom but they seem to have little affect. How do I tune this carb.
Please see pictures and video below.
https://youtu.be/Xzi4BNIRMCA
upload |
PEPPE Samba Member
Joined: August 24, 2003 Posts: 1068 Location: Roma Italy
Posted: Fri Oct 25, 2019 12:58 pm Post subject: Re: Holley 2100 bugspray technical help needed |
if the idle screws are not much effective idle jets can be too big. have you checked if they are stock size or reamed larger?
a question about the filter. does it have problems with the hood? is there enough clearance? |
Posted: Fri Oct 25, 2019 2:01 pm Post subject: Re: Holley 2100 bugspray technical help needed |
PEPPE wrote: |
Not sure about jets so will check. Clearance with filter is fine with decklid stand offs. |
Posted: Fri Oct 25, 2019 2:02 pm Post subject: Re: Holley 2100 bugspray technical help needed |
If anyone has any setup diagrams or pictures, that would be a big help. |
Posted: Sun Oct 27, 2019 5:23 am Post subject: Re: Holley 2100 bugspray technical help needed |
Anyone? |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Mon Oct 28, 2019 2:39 am Post subject: Re: Holley 2100 bugspray technical help needed |
I don't think Bugspray's have idle jet, I think they have fixed air bleeds in the top but some times guys drill them out. do you know what main jets are in it? they made the Bugspray in two sizes [200 cfm and 300 cfm], do you know which one you have?
How are the tips of the idle screws? are the sharp? some times they get tightened up too tight and break off the point in the seat or they are scared up and don't meter air well.
The are also know to have worn out throttle shaft bushings and have vacuum leaks, try spraying some carb cleaner around the both sides of the throttle shaft and listen for the rpms to speed up.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Mon Oct 28, 2019 3:01 am Post subject: Re: Holley 2100 bugspray technical help needed |
earthquake wrote: |
Casey |
Hi there and thanks for the reply. Mines a 2100 so assume its a 200. I can feel a little play in the shaft but sprayed carb cleaner and I didn't change the revs. Not looked at the jets or idle screws so will do that next and report back. Thanks |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2347 Location: San Clemente, Ca.
Posted: Mon Oct 28, 2019 5:07 am Post subject: Re: Holley 2100 bugspray technical help needed |
Show a picture of the bottom of the carb where it bolts to the manifold _________________ Jack Staggs
Actual name |
luvthemvws Samba Member
Joined: February 13, 2012 Posts: 117 Location: Middle of nowhere
Posted: Mon Oct 28, 2019 5:24 am Post subject: Re: Holley 2100 bugspray technical help needed |
Many, many, moons ago Gene Berg had a very useful tutorial in their Book of Instructions. It is copyrighted, and they protect that with enthusiasm, so I won't post it here.
Perhaps if you contact them and make a product purchase they would include a copy for you. |
spencerfvee Samba Member
Posted: Thu Nov 07, 2019 5:21 am Post subject: Re: Holley 2100 bugspray technical help needed |
sallyandsean wrote: |
Hi all
hi I used to run and race the bug spray carbs heres what I found out that makes them run .lower the float I used a 5/16 drill bit under the float .the bug spray likes 1 lb of fuel pressure yes the carb does not like a lot of fuel pressure also you must use a 009 dizy or a Mallory I like the Mallory because you can set it at 12 degs. int. all in by 32 degs good luck spencerfvee
upload |
Posted: Thu Nov 07, 2019 5:44 am Post subject: Re: Holley 2100 bugspray technical help needed |
PEPPE wrote: |
hi again I see you have no heat to the manifold that carb on cold days will never run right .it will ice up . looks like your running a after market fuel pump. I would be willing to bet your running from 3lbs to 6 lbs of fuel pressure way to high for a bug spray carb lower it buy using a fuel pressure gage to 1lb of fuel pressure if you don't that carb will run way to rich .that's why you cant set the idle jets the idle jet should only be set at 1/2 turn out any more than that the carb runs way to rich .also the 200 cfm carb works the best on a stock motor the 300 cmf carb would be way to big for a stock motor good luck spencerfvee |
Posted: Thu Nov 07, 2019 11:06 am Post subject: Re: Holley 2100 bugspray technical help needed |
If you want to fit a velocity stack on your Bugspray one for a Kadron will fit...
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
