stonecat Samba Member
Joined: December 20, 2012 Posts: 14 Location: Montgomery
Posted: Fri Jan 20, 2017 12:23 pm Post subject: How do I reattach the speedo panel clips? |
I have a 1978 Westy and I recently took off the speedo panel to replace the dim/broken dash light bulbs. I have the four clips and screws to attach the panel back, but I have no way of reaching my hand in behind the dashboard to hold the clips in place - my bus has an original DPD air conditioner unit under the dash, making access under the dashboard impossible.
I realize now I should have asked this question before starting this job, but what is the easiest way for me to attach the four clips?
Many thanks!
70Crew Samba Member
Joined: June 12, 2006 Posts: 776 Location: Grand Rapids, MI
Posted: Fri Jan 20, 2017 3:14 pm Post subject: Re: How do I reattach the speedo panel clips? |
Thanks - I figured there is no easy solution. |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Fri Jan 20, 2017 4:02 pm Post subject: Re: How do I reattach the speedo panel clips? |
They are spring clips. It's pretty easy and definitely doesn't require sticking your hand up under the dash.
Pull out the instrument panel. Attach the clips with the rounded part pointed up on the top and down on the bottom. you can leave the bottom ones a tiny bit loose.
Push instrument panel back into the hole on the dash. It will snap right into place. Tighten the bottom screws. _________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
rottenkid Samba Member
Joined: June 19, 2015 Posts: 236 Location: Warkworth, ontario
Posted: Fri Jan 20, 2017 5:51 pm Post subject: Re: How do I reattach the speedo panel clips? |
It is not a job to rush. My 78 bus was missing one of the clips. I made one out of a piece of wrought iron. I had no choice, but to reach behind the dash to get the one clip in. |
babysnakes Samba Member
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Fri Jan 20, 2017 8:20 pm Post subject: Re: How do I reattach the speedo panel clips? |
BayCreamPuff wrote: |
Push instrument panel back into the hole on the dash. It will snap right into place. Tighten the bottom screws. |
Wow, that makes perfect sense! I've been making a very simple task into a difficult one just because I didn't realize the purpose of the clip.
Thanks BCF! If we ever meet, I'm buying you your drink of choice.
And maybe two, if your choice is a soft drink... |
Posted: Sat Jan 21, 2017 11:09 am Post subject: Re: How do I reattach the speedo panel clips? |
KentPS wrote: |
No problem! It may not be the right way, but it works well for me.
Bentley shows the clips around the lip of the dashboard. The method I'm using squishes the clips between the dashboard and instrument cluster, holding it in place with friction. Makes removal much easier as well. Just loosen the bottom clips a bit and pull out.
Earl Grey
Marsha Mellow
'00 Eurovan VR6 Full Camper |
Posted: Sat Jan 21, 2017 5:45 pm Post subject: Re: How do I reattach the speedo panel clips? |
Wow, this is great. Many thanks!! |
jvanhoover Samba Member
Joined: July 13, 2016 Posts: 5 Location: Williamson New York
Posted: Fri Sep 24, 2021 6:20 am Post subject: Re: How do I reattach the speedo panel clips? |
Does anyone know where to buy replacements for the spring clips? |
Posted: Fri Sep 24, 2021 8:47 am Post subject: Re: How do I reattach the speedo panel clips? |
They are easy to make with a copper pipe hangers. |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Yoda78 Samba Member
Joined: May 20, 2023 Posts: 4 Location: Guelph, ON, Canada
Posted: Thu Mar 07, 2024 4:44 pm Post subject: Re: How do I reattach the speedo panel clips? |
jvanhoover wrote: |
There's someone on E-Bay selling 4 for $39.85. Seems pricey. |
dstimm Samba Member
Joined: June 29, 2018 Posts: 153 Location: Encinitas, CA
Posted: Fri Mar 08, 2024 7:31 am Post subject: Re: How do I reattach the speedo panel clips? |
I want to make a magnetic mounting system, I hate these clips with a passion. _________________ 1979 Sage Green California Westy. |
