reference for 36HP main bearings set with Standard size ?
grailoc
grailoc is offline
PostPosted: Fri Jan 20, 2017 2:29 pm    Post subject: reference for 36HP main bearings set with Standard size ? Reply with quote
Hi there,
Does anyone know what is the reference number for a standard size main bearings set for a 36HP engine ?
need STD size for both, Case, Crank and Trust.
Thanks for help,
Jerome
My 59 low light ghia: http://www.thesamba.com/vw/forum/viewtopic.php?p=7852268
My 56 beetle convertible: http://www.thesamba.com/vw/forum/viewtopic.php?p=7796259
My 60 SO23 westy: http://www.thesamba.com/vw/forum/viewtopic.php?t=341539
Check my blog: http://us-road-trip-vw-bus.skynetblogs.be/
and my garage build thread: http://www.garagejournal.com/forum/showthread.php?t=199438
My other vehicles
KG 64
vespa 1961 Acma & spanish GT 160
2 Lambretta LI 150
2 1971 Honda CT70
snowbug
snowbug is offline
PostPosted: Fri Jan 20, 2017 3:13 pm    Post subject: Re: reference for 36HP main bearings set with Standard size ? Reply with quote
grailoc wrote:
Hi there,
Thanks for help,
Jerome
111-198-451
Old enough to remember THRILLS, the gum that tastes like soap.
grailoc
grailoc is offline
PostPosted: Fri Jan 20, 2017 4:35 pm    Post subject: Re: reference for 36HP main bearings set with Standard size ? Reply with quote
snowbug wrote:
111-198-451
thank you Snowbug.
Seems like that bearing set is not quite easy to find.
I got my engine case and crank controlled and got confirmation that no boring nor machining was needed.
So I am looking for a NOS STD/STD/STD 36hp bearing set.
Hope to find it soon... if someone knows a place or someone who might have such bearing set, let me know.
Jerome
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
snowbug
snowbug is offline
PostPosted: Sat Jan 21, 2017 6:25 am    Post subject: Re: reference for 36HP main bearings set with Standard size ? Reply with quote
grailoc wrote:
snowbug wrote:
111-198-451
thank you Snowbug.
Jerome
http://www.bugparts.com/
I just bought some from this guy. Not sure if he has any more. Jim
txoval
txoval is offline
PostPosted: Sat Jan 21, 2017 7:10 am    Post subject: Re: reference for 36HP main bearings set with Standard size ? Reply with quote
Same shop as www.aircooledresearch.com
Give Matthew a call
Also, the Vintage Speed forum is the best place for 36hp data
pig-pen
pig-pen is offline
PostPosted: Sat Jan 21, 2017 3:20 pm    Post subject: Re: reference for 36HP main bearings set with Standard size ? Reply with quote
http://www.machine7.com/product.php?xProd=13481
in the UK...
although the split ones in my set seem to be oversize... which I am emailing them about...
1954 L227 Type 113
1964 L31 Type 265
grailoc
grailoc is offline
PostPosted: Mon Jan 23, 2017 7:18 pm    Post subject: Re: reference for 36HP main bearings set with Standard size ? Reply with quote
thanks finally found some in Finland
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
