sled Samba Member
Posted: Fri Jan 20, 2017 11:34 pm Post subject: 25hp air direction vanes |
can someone tell me if these are a necessity on a 25hp? (part #34)
they were omitted in later engines
_________________ drive your split. |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Sat Jan 21, 2017 4:11 am Post subject: Re: 25hp air direction vanes |
Purists use them still.
I would think VW dropped them later for a reason. _________________ Master of my domain! |
Bengt H Samba Member
Joined: September 11, 2005 Posts: 332 Location: Sweden
Posted: Sun Jan 22, 2017 8:48 am Post subject: Re: 25hp air direction vanes |
I think the later ones on the underside of the cylinders are better. When I restored the engine of my -49 I removed them in favor for the late ones. |
splitjunkie Samba Member
Posted: Sun Jan 22, 2017 9:06 am Post subject: Re: 25hp air direction vanes |
usariemen wrote: |
I would think VW dropped them later for a reason. |
The ones that mounted on the top were replaced by the ones that go on the bottom.
You have to have one or the other or risk overheating problems.
The later bottom mounted ones continued all the way until the end so it was obviously the better of the two.
If you want an engine to be period correct then you should use the top mounted ones.
If you want your engine to be more reliable then you have to use the lower mounted ones. _________________ Chris
rod_vw Samba Member
Joined: December 20, 2006 Posts: 416 Location: Shropshire, UK
Posted: Mon Jan 30, 2017 4:13 pm Post subject: Re: 25hp air direction vanes |
I have the later type in the engine for our '46 in the hope that I will not experience any overheating problems. Time will tell!
Although much of the tinware was of a very early type the air deflectors had already been changed for the later type by some past owner. _________________ Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
2016 T6 Selfbuild Camper and a LWB MAN TGE in build. |
