High flow air filter
kmichael
kmichael is offline
PostPosted: Sat Jan 21, 2017 9:56 pm    Post subject: High flow air filter Reply with quote
Notice "High-Flow" Air Filter and "Free-Flowing" Exhaust for maximum performance. .... Shocked . Kim
"The star of the beetle is still shining with undiminished brightness and you see for yourselves every day what vitality there is hidden in this car..."HeinzNordhoff
PostPosted: Sat Jan 21, 2017 9:59 pm    Post subject: Re: High flow air filter Reply with quote
I'm not sure what you are trying to show here.
This appears to be an industrial engine so those parts may be standard usage on those engines.
I do wonder why the coil was moved to that position.
kmichael
kmichael is offline
PostPosted: Sat Jan 21, 2017 10:20 pm    Post subject: Re: High flow air filter Reply with quote
I just cleaned-up this unusual 36 HP engine and wanted to share a photo and figured this forum has so many knowledgeable vintage engine folks that they might enjoy it. I believe the coil was moved to accommodate it fitting under a shroud or to maybe show-off the badge behind it. Anyone familiar with this set-up?
