VWAL Samba Member
Posted: Tue Jan 24, 2017 4:05 pm Post subject: '91 VW Jetta Odometer Inoperative |
The odometer on my '91 Jetta diesel quit working recently. Actually, it quit then worked a very little bit then quit again. Speedometer works fine, but odometer and trip odometer don't work. Any ideas? Can I fix this myself or is it time to look for another cluster? I'd like to keep the miles accurate if I can. Thanks! |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Tue Jan 24, 2017 4:50 pm Post subject: Re: '91 VW Jetta Odometer Inoperative |
It's the little plastic gear that drives the shaft with the numbers on it, it's amazing that it's lasted this long. Some people have been able to slide the gear out a little, use a dab of super glue & slide it back in place. If you do have any luck with it, don't reset the trip odometer. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Tue Jan 24, 2017 8:07 pm Post subject: Re: '91 VW Jetta Odometer Inoperative |
Personally, I would not use any "glue" . Rather, if the gear is NOT cracked, slide it off and "score" the metal shaft where it sits, with a couple of angled "bites" from some diagonal pliers. That will totally be enough to keep the gear in place. Personal example: I did this on my 85 Golf when I bought the car 16 years ago. Guess what? It is still going strong and has spun around over an additional 220,000 miles.
Now, if the gear is cracked, that's different: "Just Say No To Crack"... and you'll need to replace it, if it looks anything like this:
_________________ Andy T.
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Wed Jan 25, 2017 3:09 pm Post subject: Re: '91 VW Jetta Odometer Inoperative |
FYI, car w/o a trip-odometer don't seem to have this issue. My 1980 Rabbit turned the odometer about 5 or 6 times and never had a problem. |
Posted: Wed Jan 25, 2017 3:13 pm Post subject: Re: '91 VW Jetta Odometer Inoperative |
Well, the 85 Golf I mentioned above, certainly DOES have a trip meter, and it definitely had a bad odometer drive gear when I bought it in 2001, with an uncracked gear that was running a bit "loose" on the shaft. _________________ Andy T.
VWAL Samba Member
Posted: Wed Jan 25, 2017 7:25 pm Post subject: Re: '91 VW Jetta Odometer Inoperative |
Thank you. I guess I'll have to dig into it one of these days. Are you saying that after I get this corrected there's a better chance of it staying fixed if I don't use the trip odometer? |
Posted: Wed Jan 25, 2017 7:36 pm Post subject: Re: '91 VW Jetta Odometer Inoperative |
Resetting the trip odometer definitely caused the issue. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
crsmp5 Samba Member
Posted: Thu Jan 26, 2017 12:08 am Post subject: Re: '91 VW Jetta Odometer Inoperative |
http://www.odometergears.com/
to buy new gears... remember by law you are tampering with it to fix it.. why im impressed those people still offer the gears... you will not buy them anywhere else... i remember the days when you could buy new ones from vdo.. till it was breaking the law... _________________ [url=http://cdn2.driiive.com/7037.jpg]Click to view image[/url] |
bvolks Samba Member
Joined: April 26, 2004 Posts: 845 Location: New Brunswick, Canada
Posted: Thu Jan 26, 2017 8:39 am Post subject: Re: '91 VW Jetta Odometer Inoperative |
TDCTDI wrote: |
It's the little plastic gear that drives the shaft with the numbers on it, it's amazing that it's lasted this long. Some people have been able to slide the gear out a little, use a dab of super glue & slide it back in place. If you do have any luck with it, don't reset the trip odometer. |
I must have been lucky with mine. It lasted until I quit driving the car with over 750,000 km on it.
_________________ 1985 Diesel Jetta Coupe (temporarily retired at
756,000 km)
1971 Doublecab project
1995 Golf CL
1974 Beetle
1978 Westfalia |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Thu Jan 26, 2017 9:58 am Post subject: Re: '91 VW Jetta Odometer Inoperative |
crsmp5 wrote: |
remember by law you are tampering with it to fix it.. why im impressed those people still offer the gears... you will not buy them anywhere else... i remember the days when you could buy new ones from vdo.. till it was breaking the law... |
This is one statement that proves everything on the internet is NOT true.
Fixing an odometer is not tampering. Fixing an odometer is not fraud. Fixing an odometer is not breaking the law. Making odometer parts is not breaking the law either. VDO may have stopped making gears for the public, but not because it was 'Breaking the law'. Fixing an odometer will not put you in jail or even pay a fine.
VDO stopped making gears for the public just like most companies stopped making small parts, it costs too much money and the market was not there. The way they print gears anymore, it's fairly easy for someone to make their own. That is why there is a small industry that does that.
http://www.rolledbackodometer.com/federal-odometer-law.html |
VWAL Samba Member
Posted: Mon Jan 30, 2017 7:11 pm Post subject: Re: '91 VW Jetta Odometer Inoperative |
Thanks again. We've been using the trip odometer to check fuel mileage thus resetting it every tank full. Now I know that's a bad idea, and I'll stop doing it. |
Posted: Tue Jan 31, 2017 10:05 am Post subject: Re: '91 VW Jetta Odometer Inoperative |
I've held off on replying to the trip meter stuff, but my take on it, that thing rotates NO MATTER if you push the reset button or not. I totally fail to see how resetting it would cause issues. Also, I've pushed mine at least 650 times since I did the fix I mentioned above... and you'll never guess, it still works just fine and has never had any issues. I do not plan to stop using it. _________________ Andy T.
Posted: Tue Jan 31, 2017 10:26 am Post subject: Re: '91 VW Jetta Odometer Inoperative |
I suspect the problem arises when the trip odometer is reset while the car is in motion. Some of the cars have a plastic gear & others have a metal gear. I'm sure the longer hot summers may play a role too. I probably replaced 200 of the units before they were discontinued & before the gears were available _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Jan 31, 2017 11:02 am Post subject: Re: '91 VW Jetta Odometer Inoperative |
glutamodo wrote: |
I've pushed mine at least 650 times since I did the fix I mentioned above |
SINCE I did the fix being the operative phrase. The plastic gear is just a friction fit on a polished metal shaft from the factory, once you alter that then you shouldn't have an issue. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Feb 01, 2017 9:14 am Post subject: Re: '91 VW Jetta Odometer Inoperative |
A couple burr on the shaft holds the gear on.
Many German cars [Mercedes/BMW/VW, etc] had the same issue and I've fixed them at the dealership since the 80's. The parts manager would hate me because I never sold a speedo, but I always looked at it that I could fix the customers complaint that day and it was cheaper for them.
Of course, I made a couple more bucks too. |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Mon Feb 20, 2017 5:38 pm Post subject: Re: '91 VW Jetta Odometer Inoperative |
TDCTDI wrote: |
I suspect the problem arises when the trip odometer is reset while the car is in motion. Some of the cars have a plastic gear & others have a metal gear. I'm sure the longer hot summers may play a role too. I probably replaced 200 of the units before they were discontinued & before the gears were available |
I've seen this comment in other forums. I had a Cabriolet whose odometer stopped working when I forgot to reset the trip meter at the gas station, and decided to reset it while going up the on-ramp. Stopped working immediately.
I fixed it with a little super glue that evening in the hotel room. I was on the first leg of a road trip and was excited to get an idea of the mileage I was getting as I had just swapped in a 1.6 diesel motor.
That was years ago, but I recall that mine was a plastic gear and it cracked. _________________ Dave Cook
1973 Wild Westerner
My Thing |
VWAL Samba Member
Posted: Sat Apr 22, 2017 1:55 pm Post subject: Re: '91 VW Jetta Odometer Inoperative |
I FINALLY got around to working on this. Found the little red plastic gear to be split. I used a 1/8" twist drill and while holding the gear gently with pliers to kind of keep it from spreading at the crack, ran the drill through it a couple times to remove enough material so that the crack would be pretty much closed up when pushed onto shaft. I thought if I didn't do that, the mesh of the gears might be messed up at that point. Then after cleaning things with alcohol, I applied super glue carefully and sparingly, pushed gear on, and let set overnight. It's been working fine since then.
Oh, guess what! Now my '84 Jetta has the same problem. I presume the fix is about the same. Am I right?
Thanks, guys, for the help. |
