jeremy57ride Samba Member
Posted: Tue Dec 31, 2019 12:33 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
ryans65 wrote: |
looks good up nice and tall, makes me want to run stock height and knobbies! |
I hope the bias tires ride ok... I definitely like the look. Lowering is for deluxe (IMO)! I had a set back on my tranny install- I tried the custom bracket a samba member had come up with, it was not lining up as well as I had hoped. I finally pulled it back out and have the Wagenwest adapter on order.
_________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
Posted: Tue Dec 31, 2019 12:38 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
I've read good things about the tr3 polish- so I was anxious to try it out. It does do a very good job on oxidation and mild polish- I am very thankful the truck remained dove blue and unhacked inside for all those years-
Posted: Mon Jan 13, 2020 6:40 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
Update on the transmission adapter. As is turns out, the custom made adapter from samba member (Jason) would have worked just fine. I was not realizing the resistance from the nose cone clearance which was not allowing the transmission to fully set. I did buy the adapter that Nate sells and I am pleased with it. That said, for those following- it seems the home made adapter would have worked, as some have already posted. ALL that said- now I need a reverse switch plug, I hoped I could gain the space by shaving the terminals, no such luck.
Below is the difference needed for the nose cone shave- it was quite a bit more than I originally thought.
I tried using the suppled Allen head bolt for added clearance, I need the plug
Posted: Mon Jan 13, 2020 6:46 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
I couple other steps forward... I pulled the main harness into position and also ran some hard lines which are much easier to do with the transmission removed. _________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
Posted: Sat Jan 18, 2020 7:58 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
My challenges continued on installing the big nut trans in the single cab. The plug I ordered seemed all good for my clearence issue, but it still would not clear the bolt head- back out with the trans, so close.
I did some grinding on both the plug and the bolt head- and finally, the tranny rests in place, just as it should. I wish I had caught the bolt clearence issue earlier on, but maybe my experience will assist someone with the same problem. At last- this truck is a roller!
I would have rolled her outside for the photo op, but it was a nasty weather day here in PA, ice and sleet. I've pretty well sorted the wiring... a bit more to attend to...
panel Samba Member
Joined: December 02, 2001 Posts: 1091 Location: Victoria B.C. Canada
Posted: Sat Jan 18, 2020 9:42 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
You didn't want the big whitewalls on the outside ? _________________ My '65-Subaru EJ20 Turbo conversion |
Posted: Sun Jan 19, 2020 12:09 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
panel wrote: |
You didn't want the big whitewalls on the outside ? |
Well, not on a truck- I could see it if it were a deluxe bus. I'm definitely more of a blackwall guy- to each his own _________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
Posted: Thu Jan 23, 2020 6:55 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
I cleaned up my wiring- also spent some time adapting the OG tail light housings to use with the LED upgraded tail lights.
I pulled the terminals and found a rubber grommet that fit...
Rear of LED installed- very pleased with the quality and fit of this product _________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
Posted: Thu Jan 23, 2020 6:57 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
Here is the link on those LED tail lights- Thank you Chip!
https://www.thesamba.com/vw/classifieds/detail.php?id=1412740 _________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Sat Jan 25, 2020 4:53 am Post subject: Re: 1958 Single Cab "be careful what you wish for" |
Wow cool he even has latter LED sets too!
Your SC is looking great Jeremy.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Sat Jan 25, 2020 8:23 am Post subject: Re: 1958 Single Cab "be careful what you wish for" |
jeremy57ride wrote: |
Have you tried this on the exterior yet? _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
chuckfoo Samba Member
Posted: Sat Jan 25, 2020 12:37 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
Can you post a video or photos of the tail lights to show brightness difference between brake and running light? The video from where you purchased them from doesn’t really help see this difference. Thx! |
Posted: Sat Jan 25, 2020 5:23 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
LAGrunthaner wrote: |
Thanks Linda- I did not know Chip offered the later tail lights... I am running a third brake light on the westy... but may have to take a look at those. _________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
Posted: Sat Jan 25, 2020 5:25 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
Riff Raff wrote: |
Have you tried this on the exterior yet? |
I am not planning to polish the exterior at this point... after all the metal work I am currently deciding whether to clear coat. I am tempted to just polish it... I'll have to step back when it is all together. _________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
Posted: Sat Jan 25, 2020 5:26 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
chuckfoo wrote: |
I can do that but it will be awhile- I have a starter coming next week and will likely hook the battery in a couple weeks. _________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
Posted: Sat Jan 25, 2020 5:30 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
I got into stripping the deck lid- the dove is there... man I forgot how much work it took to find this blue! _________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
Posted: Sat Jan 25, 2020 6:44 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
Bringing me back to those page one memories... _________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
Posted: Sun Feb 09, 2020 1:31 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
Took a few more steps forward, got a good used Bowden tube and the missing clips for my throwout bearing... that led to the engine install
Posted: Sun Feb 09, 2020 1:32 pm Post subject: Re: 1958 Single Cab "be careful what you wish for" |
Last week I took advantage of some Florida sunshine, hauled the deck lid on our vacation and stripped the remaining paint. _________________ "If you don't do it this year, you'll be one year older when you do." -Warren Miller |
