HF bender question
cudabear
cudabear is offline
PostPosted: Tue Jan 31, 2017 11:39 am    Post subject: HF bender question Reply with quote
too all of you that have used the Harbour Freight bender. After the modification has been done to delete the two rollers and use the pipe cut in half as "shoes" does the bend stay the same diameter all the way thru ????
joescoolcustoms
joescoolcustoms is offline
PostPosted: Tue Jan 31, 2017 2:22 pm    Post subject: Re: HF bender question Reply with quote
The Bend Radius stays the same. The diameter of the tubing does increase about 1/32 to 1/16 of an inch in the middle of the bend if your "shoe" is worn. It deforms the tubing about the same as my JD Model 32 bender.
Bad News Racing 2018 NORRA 1000 3rd in Class
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
cudabear
cudabear is offline
PostPosted: Thu Feb 02, 2017 1:04 pm    Post subject: Re: HF bender question Reply with quote
thanks for the reply joescoolcustoms.. I think i have my answer. I have a HF bender that I am going to use a 1 3/4" die from my exhaust bender, make an adaptor from the die to the bottle jack 3/4" nipple. Then use two spare shoes from the bender to do the HF mod instead of the rollers. In theory and thought it should work. Let yall know
