Rob Hicks Samba Member
Joined: April 27, 2007 Posts: 131 Location: Lake Mary, Florida
Posted: Mon Sep 24, 2007 1:58 pm Post subject: Speedo cable route? |
My '63 SC came sans speedo cable.. anyone have any sort of pics or diagram as to how this thing is routed?
THANKS! |
xavi_242 Samba Member
Joined: May 06, 2005 Posts: 1672 Location: Barcelona (SPAIN)
Posted: Mon Sep 24, 2007 2:06 pm Post subject: |
through the dash tray
through the kick panel
down, near the front nose
through a hole (look underneath)
I don't remember the route underneath but it's not complicate.
good luck! _________________ 1967 Split SO-42 Dormobile |
Posted: Mon Sep 24, 2007 2:12 pm Post subject: |
Its the route underneath that I am unsure about I guess. |
orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1516 Location: South Hadley Mass
Posted: Mon Sep 24, 2007 2:35 pm Post subject: |
i just put mine along side the wiring harness until it reached the drum and put it there. _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation. |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Mon Sep 24, 2007 2:40 pm Post subject: |
There should be "clips" along the bottom of the driver's side main chassis frame. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Mon Sep 24, 2007 8:28 pm Post subject: |
Two clips I believe to the left and above the horn with feet at passenger side and head on drivers side. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
dubstar Samba Member
Joined: January 17, 2009 Posts: 1437 Location: New York
Posted: Sun Jul 22, 2012 2:29 pm Post subject: |
how do you route the cable after it exits the second clip? I removed the old one and failed to take note of that detail and now notice that the newly installed cable ends up touching the brake line (just barely, but still making contact) when the wheel is turned all the way to the right (I think...it might be during a left turn, however)
is this normal? I have it zip tied now to prevent contact and would prefer to eliminate and contact the correct way, if there is one...
(checked workshop manual and searched forum and gallery) _________________ 1963 Type II Kombi
1977 Type I Fuel Injection
http://instagram.com/john_aka_dubstar/
http://web.stagram.com/n/john_aka_dubstar/
"you could transport really tall things too, like a giraffe" |
Posted: Sun Jul 22, 2012 3:44 pm Post subject: |
Over the top beam cross-tube and curved into the brake drum.
My '61 Double Cab
My '63 15-Window
You can see the 2 clips here
Ignore front sway bar if that is confusing - it is from a later Bus
My '63 looks closer to the brake line but I don't think it's an issue.
Note: My '63 is the '63 1-ton model so it has 64-67 style brakes. _________________ How to Post Photos
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jul 22, 2012 6:16 pm Post subject: |
Make sure the rubber grommet/seal is in the spindle and the speedo cable goes through it. Without it water splashed by the opposite wheel gets shot into the bearings inside he drum.... _________________ In Stereo, Where Available! |
shano63 Samba Member
Joined: October 06, 2006 Posts: 3596 Location: Stormville NY
Posted: Sun Jul 22, 2012 7:13 pm Post subject: |
Correct!! _________________ In Stereo, Where Available! |
Thompson2 Samba Member
Joined: June 06, 2018 Posts: 659 Location: Portland, OR
Posted: Tue Jul 30, 2019 9:16 am Post subject: Re: Speedo cable route? |
I wanted to add a little to this since I used it as reference for my cable. I found that the amount of slack you leave up by the spindle is critical.
The most obvious is if you leave too little, the housing can kink at the spindle or just make it harder to make a right turn.
But on mine I found that I had pulled a bit too much to the spindle and the cable would ride over the dampener mount in a hard left turn. Then was snagging on the dampener mount during a left turn, like this:
You can see the start of damage to the sheath
What I found is that a bit less and it'll stay tucked on the outside of the mount, even in a hard left (I'm not sure why they didn't add one more clip for this...)
And should make a nice gentle curve to the front when your wheels are straight.
And when you think you've gotten it right, do a couple of hard turns left and right to make sure it's not snagging, pulling or kinking... |
