Differential failure or wheel bearing??
khalimadeath
khalimadeath is offline
PostPosted: Sat Jan 28, 2017 10:10 am    Post subject: Differential failure or wheel bearing?? Reply with quote
So ive had a noise for a while, 4+ months. I only started to really notice it a few months ago then realized it had been there for a while. The noise is a humming low rumbling noise. So the first thing that popped into my mind was wheel bearing, the more I drove the bus the more I thought that may not be the issue.
Symtoms:
Humming when in 3rd and 4th gear going strait, the noise goes away when I turn left in these conditions, it remains when I turn right. The noise also goes away when let off the throttle in any direction at any speed, off throttle = no noise. It is not noticeable in 2nd and 1st gear.
So this is what made me hesitant to check the wheel bearings. The CV joints are freshly packed and installed as of 3k miles ago. The were inspected by me when I took them out and I re installed them correctly. They did not appear to be worn in any way.
Thoughts?
If transmission, if I cannot find a place locally, whats a good place to order from?
The United States Constitution
(c) 1787. All Rights Reserved
1970 Bus Westfalia
1964 Kombi
busdaddy
busdaddy is offline
PostPosted: Sat Jan 28, 2017 10:36 am    Post subject: Re: Differential failure or wheel bearing?? Reply with quote
Sure sounds like a wheel bearing, jack it up and spin the LH wheel for a listen, wiggle it as well.
Also check the LF, sometimes noises come from deceptive places.
SGKent Premium Member
SGKent is offline
PostPosted: Sat Jan 28, 2017 11:16 am    Post subject: Re: Differential failure or wheel bearing?? Reply with quote
check the lug nuts and the drum for cracks. It may be that or as Mark suggested, wheel bearings. Were it me I would also check my fluid level in the trans and the bolts that hold the CV joints on. Normally a differential ring gear howl doesn't change much with turns but it does change with load. CV, wheel bearings, lug nuts, cracked drums change with load and turning.
"There are no great men, there are only great challenges that ordinary men are forced by circumstances to meet." - Adm William F. Halsey Jr
Caveat: I am not telling you what to, or what not to do. When a suggestion is offered, it is wishing you the best, and is based on my experiences as a mechanic, automotive machinist, and from racing in the era your bus came to life. My only goal is to share what has been learned on my path. Smile
1971 (sold)
1977
khalimadeath
PostPosted: Sat Jan 28, 2017 11:02 pm    Post subject: Re: Differential failure or wheel bearing?? Reply with quote
I suppose I can do that again, when I adjusted the brakes about a month ago all the wheels spun smoothly before I had the brakes adjusted to friction.. The reason I hesitated to think it was a wheel bearing is because I inspected and greased all of them in June.. although I guess its hard to tell if one of the rollers is going out..
1970 Bus Westfalia
1964 Kombi
Cap10323
Cap10323 is offline
PostPosted: Sun Jan 29, 2017 1:27 am    Post subject: Re: Differential failure or wheel bearing?? Reply with quote
Sounds like a wheel bearing to me. I recently replaced a rear wheel bearing that was causing a humming/rumbling that I was convinced was rear differential in my Subaru Legacy. I assumed diff because as soon as I let off the gas it went away.
It was the wheel bearing... I went out and bought a replacement diff and everything.
'77 Westy
khalimadeath
PostPosted: Sun Jan 29, 2017 9:19 am    Post subject: Re: Differential failure or wheel bearing?? Reply with quote
Well thats promising, is the best way to check to jack up each corner and spin the wheel?
1970 Bus Westfalia
1964 Kombi
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sun Jan 29, 2017 10:24 am    Post subject: Re: Differential failure or wheel bearing?? Reply with quote
If it were me, I'd unhook the CV joints at the stub axle, then spin the each rear wheel with my hand. Then, place the other hand on the trailing arm or bearing housing. If you have a rough bearing, you'll feel it on those parts as you spin it.
You may be able to feel the rough bearing with the axle hooked up.
Bill
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
hazetguy
Location: basking in the glow of orange sunshine, well within my 900 meter safe zone
hazetguy is offline
PostPosted: Sun Jan 29, 2017 12:03 pm    Post subject: Re: Differential failure or wheel bearing?? Reply with quote
i had this issue with a freshly rebuilt transmission. it was a bad bearing in the trans. sorry, i can't remember which one it was. have you checked your gear oil level lately?
Your crystal ball ain't so crystal clear
Parts and mechanical restoration services available. I restore and rebuild fuel pumps, distributors, spindles, etc.
Check my ads or send a PM.
Wildthings
Wildthings is offline
PostPosted: Sun Jan 29, 2017 1:19 pm    Post subject: Re: Differential failure or wheel bearing?? Reply with quote
You may be able to detect a failing wheel bearing because it will give off a bit more heat than a good bearing. You would probably have to make a highway run of several miles and then coast to a stop with minimal use of the brakes to detect this.
richparker
richparker is offline
PostPosted: Sun Jan 29, 2017 10:01 pm    Post subject: Re: Differential failure or wheel bearing?? Reply with quote
I found I could hear my wheel bearing going bad while cornering, everybody has a different story to tell.
If transaxle work/replacement is needed I'd use Arizona Transaxle. They even ship.
__________
71 Westy build
Adventure thread
khalimadeath
PostPosted: Mon Jan 30, 2017 5:53 pm    Post subject: Re: Differential failure or wheel bearing?? Reply with quote
I suppose I will try to listen closely with the axels attached first.. It could be bad CV too. Diagnosing is difficult with this.
1970 Bus Westfalia
1964 Kombi
khalimadeath
PostPosted: Mon Jan 30, 2017 5:54 pm    Post subject: Re: Differential failure or wheel bearing?? Reply with quote
Changed recently.
1970 Bus Westfalia
1964 Kombi
djdh68dlux
djdh68dlux is offline
PostPosted: Wed Feb 01, 2017 10:36 am    Post subject: Re: Differential failure or wheel bearing?? Reply with quote
Make sure the big axle nuts are torqued down tight enough. Years ago, mine started with the humming sound, thought it was a bearing. Then one day I end up stranded as I could hear the transmission spinning, but no power to the wheels. Immediately thought my trans was screwed, then realized the axles were turning, just not the drum. The axle nut had loosened itself and the splines in the drum that ride on the axle had been stripped/sheared smooth. Had to buy a new drum and bought one of these: http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D7045
Problem solved!
Good luck, hope you find the answer you're looking for.
1968 Deluxe "Clipper L" Type 2
Looking for a VW club in Southern California? Check out Inland Valley Volkswagens: www.ivvw.org
khalimadeath
PostPosted: Wed Feb 01, 2017 10:52 am    Post subject: Re: Differential failure or wheel bearing?? Reply with quote
I torqued them about 4k miles ago and installed the cotter pin, I suppose I can check again tho.
1970 Bus Westfalia
1964 Kombi
Wildthings
PostPosted: Wed Feb 01, 2017 1:18 pm    Post subject: Re: Differential failure or wheel bearing?? Reply with quote
Get hold of some Vanagon nuts and then use the Vanagon spec. Higher initial torque by 50% without the maximum possible torque once the cotter pin holes are aligned being any higher.
