cdennisg Samba Member
Joined: November 02, 2004 Posts: 20279 Location: Sandpoint, ID
Posted: Wed May 17, 2017 8:01 pm Post subject: Re: River Bank Survivor (59 Single Cab) |
Skim wrote: |
SamboSamba22 wrote: |
So doing a little bit of investigating, does anyone have any idea what tail light housings are in the rear?
These are for sure not an option anywhere along the road from VW?
If no ones pointed it out, they were 1968 Chevy Impala station wagon. Turned upside down of course. |
_________________ nothing |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Fri May 26, 2017 7:19 pm Post subject: Re: River Bank Survivor (59 Single Cab) |
Lapped valves, bead blasted chambers, a couple of inserts, and we have a solid dual port. I'll check numbers again when I've ran it a few times.
Note: Compression numbers shown are on a weak test battery, and about a quart low of oil, I believe to see higher numbers in months to come when motor has ran a bit.
Rotary bit time next, gotta clear the split-case transaxle for this big ole engine!
Edit: It would help if one would run the valves prior to testing compression...numbers to be ran again, doh! _________________ The Bus Barn Ltd. Co.
Oct. 67 Double Cab (68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Sun May 28, 2017 2:38 pm Post subject: Re: River Bank Survivor (59 Single Cab) |
Wow that is really cool. _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
Posted: Sun May 28, 2017 5:49 pm Post subject: Re: River Bank Survivor (59 Single Cab) |
jeremyrockjock wrote: |
Wow that is really cool. |
I was foremost thrilled, then happy to see the numbers. Wish I had ran the valves prior to running the battery down, but it gives insight. I'll check compression once the engine is installed, running, and hopefully purring.
It's amazing what breaking down the heads, blasting them, valves lapped, to see Brazilian Pistons and cylinders, TRW valves, clean solid cylinder heads, I'm hoping it'll push my pile around town just fine.
Fingers crossed, just bought a rotary bit, going to clear this transaxle in a couple days.
Note to remove and replace the starter bushing, it's easier to do with engine removed?
Also throwing pennies into the wishing well, hope I hear from Gerson one of these days.
Thanks for tagging along guys, _________________ The Bus Barn Ltd. Co.
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Sun May 28, 2017 5:53 pm Post subject: Re: River Bank Survivor (59 Single Cab) |
Easier to just put the engine just into place that the flywheel get a little stuck and hand turn it with plugs out. Let the flywheel cut what is required. Move the engine in a slight bit more and turn it again, repeat till the engine is all the way in. _________________ In Stereo, Where Available! |
Posted: Sun May 28, 2017 5:57 pm Post subject: Re: River Bank Survivor (59 Single Cab) |
Starter bushing is much easier to R&R with no engine in place.
Be very careful while grinding the tranny bellhousing. Magnesium flakes are really, really flammable. If you accidentally bump one of the steel trans mount screws and make a spark, you might be in a whole new world of flame and pain.
Take it easy, and be careful. Clean up your work space regularly.
Then take the pile of mag flakes outside and start them with a torch at night. Good fun if done with careful foresight. _________________ nothing |
Posted: Sun May 28, 2017 5:58 pm Post subject: Re: River Bank Survivor (59 Single Cab) |
Eric&Barb wrote: |
Easier to just put the engine just into place that the flywheel get a little stuck and hand turn it with plugs out. Let the flywheel cut what is required. Move the engine in a slight bit more and turn it again, repeat till the engine is all the way in. |
This is usually how I do it. Time consuming, but safe. And you can still save the pile of mag flakes for some pyrotechnic fun. _________________ nothing |
Posted: Wed May 31, 2017 7:01 am Post subject: Re: River Bank Survivor (59 Single Cab) |
My process:
Jack motor up, lined up push in until tight, hardware not long enough to tighten down. So, using a 3/4 drive with a 30mm socket I was manually cranking the engine over, getting a little leadway. Finally had enough in to begin tightening engine bolts. After a few cranks, trouble brewed once I rounded off the pulley nut. I know, I'm so thrilled.
So, as seen in the photo below, I pulled the motor back out and have begun to use a rotary bit to create the needed clearance. Luckily the flywheel grooved all the needed areas. Main issues are the bolt holes inside the transaxle.
Little by little.
It sure is going to suck having to remove that pulley nut in the future.
Posted: Wed May 31, 2017 7:21 am Post subject: Re: River Bank Survivor (59 Single Cab) |
It sure is going to suck having to remove that pulley nut in the future. |
Not really. Can use a plumber wrench or weld a large nut to the rear side of it.
Guessing you did not use a 6 point socket. 12 point sockets are more likely to round off the points of the bolts. Plus next time try not to shove the engine in so hard while turning it. _________________ In Stereo, Where Available! |
Posted: Wed May 31, 2017 11:13 am Post subject: Re: River Bank Survivor (59 Single Cab) |
Eric&Barb wrote: |
Guessing you did not use a 6 point socket. 12 point sockets are more likely to round off the points of the bolts. Plus next time try not to shove the engine in so hard while turning it. |
Definitely a 12 point socket, I'll see if picking up a 6 point socket helps, there's still decent meat on it but not with the resistance of trying to cut the transaxle with, plus it'll help having one for the future.
Thanks E&B. _________________ The Bus Barn Ltd. Co.
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Wed May 31, 2017 3:42 pm Post subject: Re: River Bank Survivor (59 Single Cab) |
cdennisg wrote: |
Eric&Barb wrote: |
This is usually how I do it. Time consuming, but safe. And you can still save the pile of mag flakes for some pyrotechnic fun. |
I always use a sharp chisel and chisel the bottom high spots then the rest is eazy peezy. Flywheel will clear the path. _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Posted: Sun Jun 04, 2017 6:12 am Post subject: Re: River Bank Survivor (59 Single Cab) |
Well I finally got the dual port installed into the split-case transaxle, time-consuming but nothing unbearable.
One day I'll land a hand-crank and the needed dog (starting) nut, until then I'll just use the starter
Now visible to the right of the engine, I am needing to do metal replacement work on the battery tray and the rear corner. Metal for this area is very pricey, and not my focus for right now, though much needed.
What tin is missing behind the doghouse? With the 73 engine and the protruding cooling air "cone/flap" what's my solution here?
FWIW, I am trying to sell the current 55-59 bus pan I have from Klassicfab, listed in the classifieds, to generate money to purchase the correct pan for my application. _________________ The Bus Barn Ltd. Co.
Posted: Sun Jun 04, 2017 8:59 am Post subject: Re: River Bank Survivor (59 Single Cab) |
What tin is missing behind the doghouse? With the 73 engine and the protruding cooling air "cone/flap" what's my solution here? |
do you have #'s 8,9 and 3? _________________ nothing |
Posted: Sat Jun 10, 2017 3:44 am Post subject: Re: River Bank Survivor (59 Single Cab) |
cdennisg wrote: |
do you have #'s 8,9 and 3? |
Alrighty, located #'s 3,4,6 needed for the purring kitten (to be determined) in the back half of the truck.
Also getting a good Bosch 12v starter with the need of ordering a 6v to 12v starter bushing.
For the birthday, I bought a couple "necessities" off the classifieds, the manual is a bit rough, but the sales brochures are clean, vibrant, and just oozing awesomeness.
Posted: Sat Jun 10, 2017 6:33 pm Post subject: Re: River Bank Survivor (59 Single Cab) |
When you get the boot, you gotta store things really where you wouldnt like for them to be, and Im hoping this thing isnt hidden and neglected under a tarp for very long.
Even knowing it sat outside, forgotten for 30 years, with the work Ive done thus far, its almost gutting know that its back outside...
My name is Sam, and I have a problem _________________ The Bus Barn Ltd. Co.
