Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Mon Jan 30, 2017 10:20 am Post subject: Advice on swapping heat exchangers |
Years ago I replaced my rusted OG heat exchangers with Dansk and realized the mistake on the next ski trip. I have acquired some good OG HE's and plan to swap them into my '69 camper. I'm reluctant to drop the engine for only this work and would like advice on the possibility of doing the swap with the engine in place.
Aloha
tp |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Mon Jan 30, 2017 10:40 am Post subject: Re: Advice on swapping heat exchangers |
it can be done. i've done it a few times on various VW's.
it can really suck to get to the upper exhaust nuts. and if you strip the nut or stud or break an exhaust stud, you're gonna end up pulling the engine anyway. it can also suck a bit trying to get the "new" heater box pipe to fit in the muffler and on the exhaust stud at the same time. if you do this, i would recommend putting it up on heavy duty jackstands (or lift, if you are so fortunate as to have access to one) and removing the wheels. it gives easier access. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Mon Jan 30, 2017 12:21 pm Post subject: Re: Advice on swapping heat exchangers |
I've never done it but I have had to tighten up the exhaust nuts a few times.. It doesn't seem like it would be impossible. You might not even have to pull the muffler off. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Mon Jan 30, 2017 12:41 pm Post subject: Re: Advice on swapping heat exchangers |
If it's not possible, then I'm an inveterate miracle-worker. I suggest you replace those pesky front exhust stud nuts with
smaller 11 or 12 mm wrench size nuts, stainless or brass, and use anti-seize. _________________ '67 bug: seized by the authorities
richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
Posted: Mon Jan 30, 2017 1:13 pm Post subject: Re: Advice on swapping heat exchangers |
I've done it. I didn't think it was that hard, but my exhaust studs were good and didn't pull out. Removing the rear apron helps a ton. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Mon Jan 30, 2017 2:51 pm Post subject: Re: Advice on swapping heat exchangers |
Oh yeah, forgot to mention I went back with the smaller diameter EMPI exhaust nuts. Definitely handy _________________ Robert in Memphis
SGKent Samba Member
Posted: Mon Jan 30, 2017 4:17 pm Post subject: Re: Advice on swapping heat exchangers |
1971 dual port experience not 1969 so can't say on that. On 1971 Factory heat exchangers. Remove the exhaust first. A couple nuts will need liquid wrench to loosen them but they will come off. May need different wrenches to get angles on the nuts. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Mon Jan 30, 2017 5:13 pm Post subject: Re: Advice on swapping heat exchangers |
Mayor Ratwell does a really nice write up on preparing the ports to fit and seal on the heads. You only want to do this job once. _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
airschooled Air-Schooled
Posted: Tue Jan 31, 2017 2:29 am Post subject: Re: Advice on swapping heat exchangers |
pioneer1 wrote: |
Mayor Ratwell does a really nice write up on preparing the ports to fit and seal on the heads. You only want to do this job once. |
That's for a late (T4) bus.
Tom, this is absolutely doable. I think it's SIGNIFICANTLY easier than removing the engine to do the job. An "s-wrench" will work wonders. With stock diameter pipes, I've never needed anything smaller than 13mm fasteners. Just retorque them a couple times after any new install. Google image search for that wrench if you don't know what I'm talking about, I can't copy Google links from my phone.
Good luck, and let me know if you get into a bind; I'll be all over Southern California in the next few months.
www.airschooled.com |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Tue Jan 31, 2017 7:59 am Post subject: Re: Advice on swapping heat exchangers |
I've done it and although it was a long time ago, I don't recall it being that difficult. I did break a stud and had to drill/ EZ out. Did it with engine in place and it sucked, but again not that difficult. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Tue Jan 31, 2017 9:03 am Post subject: Re: Advice on swapping heat exchangers |
asiab3 wrote: |
An "s-wrench" will work wonders. |
I find that a "U" wrench works super well for this job too.
hazetguy: invested?
Posted: Tue Jan 31, 2017 9:04 am Post subject: Re: Advice on swapping heat exchangers |
asiab3 wrote: |
... An "s-wrench" will work wonders. ... Google image search for that wrench if you don't know what I'm talking about, ... Good luck, and let me know if you get into a bind; I'll be all over Southern California in the next few months.
Robbie |
I believe you refer to what I have always called a manifold wrench. I have a set of those from Harbor Freight. HF calls them an S-type obstruction wrench. http://www.harborfreight.com/media/catalog/product..._12257.jpg
I'll be doing the heat exchanger swap and a center pin rebuild at Gary's this weekend. Stop by for some beer by the bus and lunch at Point Loma Seafoods with us if you are down that way.
Sounds like it it is about 60/40 engine in/ engine out. I'm just tired of crawling around on the concrete.
Aloha
tp |
wcfvw69 Samba Purist
Posted: Tue Jan 31, 2017 9:21 am Post subject: Re: Advice on swapping heat exchangers |
I think it's pretty simple IF the mounting nuts/studs are not rusted. Certainly spray all the connections with PB blaster a day or two before commencing the job. I also agree with putting the bus on jack stands and removing the rear tires for better access. I didn't remove my muffler or engine when I removed my heater boxes last time.
The other thing Tom is to REALLY check the nipples that slide into the muffler on your used heater boxes for wear/rust and being undersized. That joint likes to create irritating exhaust leaks. I sourced some used, original boxes for my 70. Both of my pipes/nipples were rusted undersized.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113255101X
These repair nipples are sweet. While I welded mine in, they don't have to be. Replacing those pipe ends and using good donuts and clamps provided zero exhaust leaks.
Last suggestion. Get a big metal file and flatten the exhaust gasket seating area that slides over the two studs on the heads. Most are warped. Making it flat again with new gaskets it worth the effort.
_________________ Contact me at [email protected]
The Samba member since 2004.
rottenkid Samba Member
Joined: June 19, 2015 Posts: 236 Location: Warkworth, ontario
Posted: Tue Jan 31, 2017 11:47 am Post subject: Re: Advice on swapping heat exchangers |
I had to torch the exhaust bolts off of my 78 bus. I repaired the heater boxes and installed them without removing the engine. It is not a fun job when it is really cold outside. I have a kerosene heater, which blew warm air while doing the installation. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Tue Feb 07, 2017 6:40 pm Post subject: Re: Advice on swapping heat exchangers |
Follow-up:
Both heater boxes were replaced without pulling the engine, or anything else, for that matter. After Tom backed into the driveway, we jacked the rear end up, put on jack stands, then pulled the rear tires. After that, the four front exhaust nuts were loosened (not hard, as they were quite hot!) Angled 13mm wrenches made this possible. After cooling down for a while, the hot and cold air hoses, and heater cables were disconnected. The rear doughnut clamps, heater box to tin screws and front flange nuts were removed. The heater boxes easily slid forward and were removed.
Reinstallation was the reverse of removal, with new gaskets and doughnut rings used. The heater box flanges were made flat with some hammer and file work. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
Posted: Tue Feb 07, 2017 6:44 pm Post subject: Re: Advice on swapping heat exchangers |
telford dorr wrote: |
Follow-up:
Both heater boxes were replaced without pulling the engine, or anything else, for that matter. After Tom backed into the driveway, we jacked the rear end up, put on jack stands, then pulled the rear tires. After that, the four front exhaust nuts were loosened (not hard, as they were quite hot!) Angled 13mm wrenches made this possible. After cooling down for a while, the hot and cold air hoses, and heater cables were disconnected. The rear doughnut clamps were removed, and front nuts removed. The heater boxes easily slid forward and were removed.
Reinstallation was the reverse of removal, with new gaskets and doughnut rings used. The heater box flanges were made flat with some hammer and file work. |
Mahalo Telford
Aloha
tp |
Posted: Tue Feb 07, 2017 6:48 pm Post subject: Re: Advice on swapping heat exchangers |
You're welcome, any time. Bottom line: this was a straight-forward job. Not complex at all.
Forgot to mention: chased the head studs with the appropriate sized die to clean them up, then lightly coated with nickel anti-seize. Made getting the flanges snug very easy _________________ '71 panel, now with FI
Last edited by telford dorr on Tue Feb 07, 2017 6:55 pm; edited 2 times in total |
Posted: Tue Feb 07, 2017 6:51 pm Post subject: Re: Advice on swapping heat exchangers |
You're welcome, any time. Bottom line: this was a straight-forward job. Not complex at all. |
It's not the lack of complexity that I am thankful for. It is is the crawling around on the cement by friends.
Aloha
tp |
Posted: Tue Feb 07, 2017 6:52 pm Post subject: Re: Advice on swapping heat exchangers |
Well, your rubber mat cushion made that not so bad...
So: the heat works good? Had to bail before it was tested... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Tue Feb 07, 2017 6:58 pm Post subject: Re: Advice on swapping heat exchangers |
I was cooking and sweating on the drive when I tested the center pin, steering and heat exchangers. OG is better than Dansk by uku million percent.
Aloha
tp |
