ldj1002 Samba Member
Posted: Wed Feb 01, 2017 3:49 pm Post subject: Duel carbs |
I may want to go look at a car with 1600 DP with duel carbs. Don't know which distributor or carbs. I do know from what I read that the VW is very finicky about distributor and carb combination. I get the idea if not what came from factory you will have dead spot and idling problems. So are the duel carbs a bad thing since there was no distributor made for duel carbs? |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Wed Feb 01, 2017 4:39 pm Post subject: Re: Duel carbs |
Dual. |
B Ramsey Samba Member
Joined: February 05, 2006 Posts: 477 Location: Ramona ca.
Posted: Wed Feb 01, 2017 4:47 pm Post subject: Re: Duel carbs |
Dual carbs are an upgrade. if not running right then obviously something is wrong. _________________ Go outside and do something. |
Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Wed Feb 01, 2017 4:52 pm Post subject: Re: Duel carbs |
Dueling carbs, whether using swords or pistols would be rather dangerous and could get messy under the hood. It's best to find two that are compatible.
But all kidding aside I had a single port 1600 wth dual solex carbs that ran exceptionally well, I wish I could remember which stock distributor I had. I'm sure someone will know, just ( I think ) stay away from the 009 ??? _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Wed Feb 01, 2017 5:22 pm Post subject: Re: Duel carbs |
A 1600 with dual carbs work well with a VJ4BR8 or a 019 mechanical distributor. _________________ Glenn
Member #1009
#BlueSquare |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Thu Feb 02, 2017 2:02 pm Post subject: Re: Duel carbs |
Multi69s wrote: |
Dual carbs are the best way to go if you have the knowledge to jet and sync them...................................... |
X2 ....... When I went from a dual carb set up ( stock small Solex carbs & single port heads) to a single bigger Solex, I lost about 3 mpg. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
