Manfreds78bay Samba Member
Posted: Thu Feb 02, 2017 12:59 pm Post subject: Running Lights and Turn Signals Acting up |
1978 FI 2.0 Camper
I was sorting out some issues with my reverse lights and license plate light and now I'm getting some really strange behavior.
The fuse holder for the back up lights seemed to have gone bad. I put in a spare and it seemed to fix the problem. The license plate light had a bad ground. I Also the right side marker light was not working. It also a bad ground.
I don't know what I did but now I'm experiencing the following issues.
Lights on:
Rear left running light and turn signal comes on at the same time. Left rear turn signal does not flash. Right rear lights seem to work fine. Both brake lights work fine. Both front turn signals flash at the same time when trying to use the left turn signals
Lights off
Brake lights work fine. When using the left turn signal the left rear side mark light flashes at the same time as the left rear turn signal. The right rear turn signal works fine. The front turn signals do not flash.
I didn't have any issues with the lights besides the revers lights and license plate light.
I've pulled both rear lights and verified the side marker lights have their own ground and the rear lights all ground to the rear of the light housing on both sides. I don't see any crossed wires.
Any help would be great _________________ 1978 2.0L FI Campmobile
1982 AMC Eagle SX4 4.2L FI |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3551 Location: San Diego (Encinitas)
Posted: Thu Feb 02, 2017 8:33 pm Post subject: Re: Running Lights and Turn Signals Acting up |
Sounds like you have a bad ground at the left rear light fixture, so the turn signal is grounding through the tail light circuit. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Fri Feb 03, 2017 8:03 am Post subject: Re: Running Lights and Turn Signals Acting up |
telford dorr wrote: |
Sounds like you have a bad ground at the left rear light fixture, so the turn signal is grounding through the tail light circuit. |
Okay thanks. I'm not sure how that is possible because the rear light housing is out of the bus while I troubleshoot, but I'll have a closer look. Thanks for pointing me in the right direction. _________________ 1978 2.0L FI Campmobile
Posted: Fri Feb 03, 2017 9:45 am Post subject: Re: Running Lights and Turn Signals Acting up |
Lights off
I've pulled both rear lights and verified the side marker lights have their own ground and the rear lights all ground to the rear of the light housing on both sides. I don't see any crossed wires. |
Quote: |
Okay thanks. I'm not sure how that is possible because the rear light housing is out of the bus while I troubleshoot, but I'll have a closer look. |
OK, I'm confused. How are you testing the housing if it's out of the bus? I assume the housing is not in it's body hole, but are the wires connected? Or is it completely removed? Trying to get a clear picture here.
Also: "the rear running light" - is this the tail light? side marker light? or something else? I assumed this was the tail light in my response. Please clarify. _________________ '71 panel, now with FI
SGKent Samba Member
Posted: Fri Feb 03, 2017 9:52 am Post subject: Re: Running Lights and Turn Signals Acting up |
What Telford is saying is that you are missing a grounding wire on that housing. The brown wire goes to a screw on the body of the bus. That is the return path for the electricity.
When you get things working semi right be sure to look at the emergency switch with the battery disconnected because that switch comes apart almost 100% of the time on a late bay and causes all kind of problems in the turn signal circuit.
Right now your problem however is you need to add that brown ground wire.
. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Feb 05, 2017 9:51 am Post subject: Re: Running Lights and Turn Signals Acting up |
Lights off
Also: "the rear running light" - is this the tail light? side marker light? or something else? I assumed this was the tail light in my response. Please clarify. |
Yes, that's right it's just hanging by the wires.
The rear running light is the brake light when lights are on but the brake lights are not.
The side marker lights are the red lights on rear sides of the bus.
Going to go see if I can track this problem down in a few minutes. Will report back. _________________ 1978 2.0L FI Campmobile
Posted: Sun Feb 05, 2017 9:57 am Post subject: Re: Running Lights and Turn Signals Acting up |
SGKent wrote: |
Yes I do have a ground coming from the bus to the rear light holder completing the ground. I'll have a look at the emergency switch. I might just need to be cleaning. But it was working find before I started messing with this.
Background here: the reverse lights never have worked on this since bought it about 8 years ago. And I was having all kinds of issues with the turn signals back then. I think i just screwed with the ground wires until I go everything working to satisfaction and never really found the issue. I think I'm reaping what I sowed back then.
Will report back with a fix or what I've tired to fix. _________________ 1978 2.0L FI Campmobile
Posted: Sun Feb 05, 2017 1:49 pm Post subject: Re: Running Lights and Turn Signals Acting up |
Worked on it for an hour or so, still could not figure out where the bad ground is.
I turned on the lights with the key off.
I disconnected all the body grounds in the engine compartment one at a time to see if anything would cause the left turn signal to shut off. The only time it would shut off is when I removed the ground from the left rear light bracket (the thing that holds all the bulbs). Of course this would cause the running light to shut off as well.
So one thing that I didn't tell you is I'm running all LED lights. I put in all standard bulbs to see if I got any difference. It didn't.
However, I did notice some strange behavior. When I disconnected the ground from the left bulb bracket with the LED lights plugged in, the running red light had some voltage running through it. There is a very faint glow only coming through the red running light.
I'm not sure how this is possible since there is no ground connected to it at all. So what does this tell me? The running light is grounding some place else? Would a hole in the plastic allowing the wire to touch the frame some how cause this faint glow?
If this is the case, could this bad ground through the running light cause my turn signal to come on? _________________ 1978 2.0L FI Campmobile
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Sun Feb 05, 2017 2:01 pm Post subject: Re: Running Lights and Turn Signals Acting up |
that faint glow is telling you that the light you pulled the ground off of is now useing that lights circuit as a ground.many led light are polarized pos to pos neg to neg. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Posted: Sun Feb 05, 2017 2:10 pm Post subject: Re: Running Lights and Turn Signals Acting up |
lil-jinx wrote: |
that faint glow is telling you that the light you pulled the ground off of is now useing that lights circuit as a ground.many led light are polarized pos to pos neg to neg. |
So the LED is causing it light circuit to ground itself? _________________ 1978 2.0L FI Campmobile
Posted: Sun Feb 05, 2017 3:53 pm Post subject: Re: Running Lights and Turn Signals Acting up |
You have a bunch of lamps (tail, turn, stop, backup) all mounted in one housing, all sharing the same ground connection. If that ground were to become disconnected, then the power to one lamp (say the tail lamp, for example) will travel through that lamp to the lamp holder frame, then backwards through the other lamps (for example, the stop lamp) then through its wire to the stop lamp on the other side, then through that lamp to ground. It will also travel through the backup lamp, then through the wire to the other backup lamp, through that lamp to ground, etc. It becomes a bit of a convoluted path through multiple lamps to ground. Thus, the original tail lamp will light (but not as brightly as normal, because of all of the other lamps stealing some of the power). You may even see light from the other lamps.
Now with LEDs, it's a little different as, unlike filament type bulbs, LEDs generally pass current in only one direction. Thus, the other lamps in the housing will become reverse biased, and won't pass current (unless they break down and fail internally, or the mfg. put rectifier or protection diodes in the lamp assembly).
Strange fact: LEDs are photo-sensitive: if you shine a bright light (like the sun) on an LED, it will generate a voltage that you can measure with a meter. Different color LEDs have different sensitivities to light. FWIW... _________________ '71 panel, now with FI
Posted: Sun Feb 05, 2017 4:02 pm Post subject: Re: Running Lights and Turn Signals Acting up |
with the light on and you pulled the ground,the power going to the light tried to find another path to ground,it would travel into the metal housing that holds all the bulbs,then it would enter 1 of the bulbs thru the ground side of that bulb and travel out thru the pos side of the bulb and travel up the wire until it entered the other bulb [the 1 that's glowing]then it would go to ground at that light turning that light on at half power because now you have two lights hooked in a series circuit.when you turn the lights on you take away that path to ground,so it keeps traveling looking for a ground and finds it at your front right signal.
keep looking for a faulty ground clean all the connections,all the bulb sockets.
do it 1 light at at time until your 100% sure it,s making a good connection then move onto the next 1,take your time.
Don't let it drive you nuts,good luck. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
Posted: Tue Feb 21, 2017 1:36 pm Post subject: Re: Running Lights and Turn Signals Acting up |
Okay I finally got back around to troubleshooting this issue. I couldn't find a bad ground connection I start pulling the bulbs and making sure everything was clean and tight. Still having the same issue.
So here is a new development.
If I pull the second fuse from the left, which is for the right rear tale light, license plate and right rear side marker lights, I get the following condition
1. Lights OFF, left running light and turn signal light work as they should. Front turn signal does not work
2. Lights OFF, right turn signal works as it should. Front signal does not work
3. Lights ON, left rear turn signal and running light work as they should. Both front turn signals blink at the same time
4. Light ON, Right rear turn signal works as it should. Front turn signal does not work.
I think I've narrowed down the issue to the #2 circuit. Some how my rear left light is getting power from my right rear light.
I removed the plastic from the wire harness that connects the right and left lights. All the wires look fine. _________________ 1978 2.0L FI Campmobile
