dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon Nov 27, 2017 6:08 pm Post subject: Re: Beware of Thermex brand front heater core |
Mellow Yellow 74 wrote: |
Terry Kay wrote: |
Not innovative at all, just capable of duplication, and at a higher cost to boot. |
Current prices - TK $279, Gowesty $199 |
...FWiW/currently: $145 @ Van Cafe, plus cookies...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
greebly Samba Member
Joined: August 27, 2009 Posts: 966 Location: Here and now
Posted: Mon Nov 27, 2017 8:23 pm Post subject: Re: Beware of Thermex brand front heater core |
Christopher Schimke wrote: |
http://www.thebrassworks.net/shop/Heater-Cores-Oth..._info.html
"Tip 2: The rear heater would originally have had a restrictor to limit coolant flow through the rear heater and force additional coolant through the front heater. If "someone" removes this restrictor you may have limited flow through the front heater especially at idle. Test this possibility by pinching off the hose to the rear heater. If the heat rises in the front you'll know why.
Seems like the control valve for the rear heater could be used to test that out. I would think it presents a restriction when it is closed. |
Altoona Samba Member
Posted: Tue Nov 28, 2017 2:15 pm Post subject: Re: Beware of Thermex brand front heater core |
dhaavers wrote: |
Terry Kay wrote: |
- Dave |
If the pictures are any indication, that one at VC is the dreaded Thermex brand. Not the good repros that GW or TK offer. |
Slimvest Samba Member
Joined: March 20, 2014 Posts: 431 Location: Portland, OR
Posted: Sun Jan 14, 2018 9:48 am Post subject: Re: Beware of Thermex brand front heater core |
Pulled my Thermex yesterday and replaced it with a used OEM core that I pressure tested first.
The Thermex core looked to be full of coolant when I pulled it but was not producing heat. I was expecting air entrapment. I have to wonder if the design paired with the flow rate of the vanagon coolant system just doesn't allow for coolant to circulate through the Thermex. _________________ '87 GL w/ Reimo top |
detoxed Samba Member
Posted: Mon Jan 15, 2018 9:53 am Post subject: Re: Beware of Thermex brand front heater core |
Anybody using the Brassworks core? Feedback other than pricey? |
Posted: Tue Feb 06, 2018 2:46 pm Post subject: Re: Beware of Thermex brand front heater core |
I've been working with CIP, whom I bought the Thermex core from, on returning the part. They reached out to the supplier and said there was indeed a product recall on the Thermex core.
I've been offered credit but am trying to get a refund. _________________ '87 GL w/ Reimo top |
SyncroChrick Samba Member
Joined: January 10, 2005 Posts: 1010 Location: San Francisco, CA
Posted: Tue Feb 06, 2018 3:40 pm Post subject: Re: Beware of Thermex brand front heater core |
Side question - what is this restrictor they are referring to?
"Tip 4: The rear heater would originally have had a restrictor to limit coolant flow through the rear heater and force additional coolant through the front heater. If "someone" removes this restrictor you may have limited flow through the front heater especially at idle. Test this possibility by pinching off the hose to the rear heater. If the heat rises in the front you'll know why." |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4799 Location: Bemidji, MN
Posted: Tue Feb 06, 2018 6:05 pm Post subject: Re: Beware of Thermex brand front heater core |
okay, i'm freakin' out a little bit. have a new Van Cafe heater core on the bench i'll be putting in very soon. worrying that it is the dreaded Thermex but take a look at these photos... it is different from what Fogerty1970 posted. please make me feel better!
first my VC core overall
now, looking down the inlet/outlet. notice how there is not a restriction as per the Thermex photo further below. it's just full bore. i also shined a strong light in the openings and there was zero light transmittal between the inlet and outlet.
and finally, a repost of the photo from Fogerty1970 of his Thermex inlet:
so. tell me the VC isn't a Thermex and make me feel good!!
-dan |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4098 Location: East Kootenay, British Columbia
Posted: Tue Feb 06, 2018 6:42 pm Post subject: Re: Beware of Thermex brand front heater core |
SyncroChrick wrote: |
It's something like these:
http://www.van-cafe.com/page_2010_1140/heater-core-hose-reducer
The original VW part looks different but these work the same way to reduce flow. _________________ Currently:
Posted: Tue Feb 06, 2018 7:34 pm Post subject: Re: Beware of Thermex brand front heater core |
MsTaboo wrote: |
The original VW part looks different but these work the same way to reduce flow. |
Wow even after all these years I can still learn new things!! that's what so great about Vanagon, always full of surprises!
I guess I need to add this to the list when I do my engine swap. Thank you |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Tue Feb 06, 2018 9:48 pm Post subject: Re: Beware of Thermex brand front heater core |
That’s an interesting observation that lack of heat up front can be dependent on components in the rear heater area.
Can a defecive heater core be identified by a simple flow test with a garden hose?
Would be interesting if someone with a Thermex core AND a OEM core (& others?) could set a garden hose at some calibrated flow rate and compare the output flow of the two cores.
It’s fairly easy to determine flow rate with a stopwatch and a 5-gal bucket. If the bucket is half-full in 30 seconds the faucet setting is 5 gallons per minute. Perhaps a good test can be Samba-developed so folks have better confidence before closing up a das project. _________________
....KTMs, GasGas, SPOT mtb |
jberger Samba Member
Posted: Tue Feb 06, 2018 10:29 pm Post subject: Re: Beware of Thermex brand front heater core |
I'm not buying it.. Reduced flow would allow the fan or other air flow to pull more btu's from the available heated "coolant" leaving a luke warm heater box.
I have personally pulled a fully functional OE heater core to replace with a thermex only to end up with Zero heat... It has nothing to do with original flow characteristics and everything to do with the overall fabrication of the replacement core. Are the passages too large? Too restricted? Internally blocked? The latter is what agrees with me. How can the input side of the core be hot and the drivers side remain Ice Cold... Shameful
J |
Sodo Samba Member
Posted: Tue Feb 06, 2018 11:04 pm Post subject: Re: Beware of Thermex brand front heater core |
jberger wrote: |
I'm not buying it.. Reduced flow would allow the fan or other air flow to pull more btu's from the available heated "coolant" leaving a luke warm heater box. |
Reduced coolant flow will certainly result in reduced heat output. Or are you saying there is good flow but zero heat? I have a hard time believing that, but,,,,
Basically since there’s doubt regarding some brand heater cores it seems useful to develop a simple test that members can do prior to reassembling their dash. What if you just blow thru it with your breath? _________________
Posted: Tue Feb 06, 2018 11:16 pm Post subject: Re: Beware of Thermex brand front heater core |
Sodo wrote: |
jberger wrote: |
Basically since there’s doubt regarding some brand heater cores it seems useful to develop a simple test that members can do prior to reassembling their dash. What if you just blow thru it with your breath? |
I don't like being put in a situation beyond my control or understanding. What I'm telling you is, despite perfect coolant flow, the Thermex heater core I was subjected to did not produce heat. I went through almost every experiment you can think of (almost, because I know you are very creative) with the same result. Nothing wrong with the coolant flow.... everything wrong with the replacement core.
I would not install a Thermex core in any of my vans... period. Installing the heater core is not THAT hard.. its just that you want a certain assurance that the product will work.
J |
Posted: Wed Feb 07, 2018 5:53 am Post subject: Re: Beware of Thermex brand front heater core |
i don't think the heat issues with the Thermex were from reduced flow... it was short-circuiting as i recall. someone shone a light in one pipe and could see light in the other.
i know on the core i have there is not light between the passages but before i put it in service am going to hook it up to the faucet and take an IR movie of changing the water from cold to hot to see the heat flow pattern thru the core. that should identify whether there is any short-circuits on this core.
-dan |
Posted: Wed Feb 07, 2018 11:34 am Post subject: Re: Beware of Thermex brand front heater core |
^^^ Wise.
Who'da guessed in this day and age we'd still have companies
trying to figure out how to make a heater core that works...???
"The WonderVan"
danfromsyr Samba Member
Posted: Wed Feb 07, 2018 11:51 am Post subject: Re: Beware of Thermex brand front heater core |
companies make parts to sell not to work.
by the time the returns come in they've cashed out the company .
and it's the new holding company's problem. _________________
Abscate wrote: |
Zeitgeist 13 Samba Member
Posted: Wed Feb 07, 2018 12:11 pm Post subject: Re: Beware of Thermex brand front heater core |
The short circuit theory makes the most sense to me. The coolant flow will take the path of least resistance, and thus create a semi-permanently cool/cold eddy inside the core--flow goes in and immediately out again. I've seen radiator cores nearly completely occluded with scale and they still were able to shed heat, which leads me to think the tiny passages theory isn't quite telling the whole story here. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Wed Feb 07, 2018 2:32 pm Post subject: Re: Beware of Thermex brand front heater core |
here it is... i took an infra red video of cold and hot water flowing thru my new Van Cafe heater core, purchased Oct 2017 for $125, don't know what brand they sell. water inlet/outlet is at the bottom left of the screen.
i have confidence in this new core that it isn't short circuiting and has even flow thru the element. i'll install it!
https://youtu.be/Hn-7Z4osCos
-dan |
Posted: Wed Feb 07, 2018 6:14 pm Post subject: Re: Beware of Thermex brand front heater core |
FIFY:
DanHoug wrote: |
here it is... infra red video ...
- Dave
PS: Yeah, looks good! _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
