tencentlife Samba Member
Joined: May 02, 2006 Posts: 10077 Location: Abiquiu, NM, USA
Posted: Sat Jan 12, 2019 1:07 pm Post subject: Re: Beware of Thermex brand front heater core |
Yep, that's a lot of area for flow to slip across.
On top of that, with only 3 galleries, the whole middle gallery wouldn't have anything going thru it even if the scalloped divider was a close fit.
That's some pretty piss-poor design there, seems like they took an existing matrix and added endcaps for the application without any consideration as to how coolant would flow thru it. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
loki475 Samba Member
Joined: April 18, 2005 Posts: 225 Location: Ontario, Canada
Posted: Sun Jan 13, 2019 6:17 am Post subject: Re: Beware of Thermex brand front heater core |
What a stupid setup, all they had to do was use cores with 2 galleries. They lost any proper flow direction by having that middle gallery, which made the divider on the tank useless. I guess that's what happens when you get parts made by some random small European countries. My heater from Brickwerks (same as GW is selling) is terrible and it came from some unknown company called Prasco. Ordered a Brassworks heater and I'll report back once its been installed and tested. |
uberhare Samba Member
Joined: July 16, 2008 Posts: 41 Location: Kitchener, Ontario, Canada
Posted: Wed Jan 16, 2019 4:00 pm Post subject: Re: Beware of Thermex brand front heater core |
JPGroup / Thermex heater cores have been recently updated. I have not cut one open, but they did pull from the market last year to improve the design. _________________ Cheap, fast, reliable - Pick your 2! |
Posted: Thu Jan 17, 2019 9:24 am Post subject: Re: Beware of Thermex brand front heater core |
Well once someone has one in hand, look inside to see if there are two or four galleries. If there's three, then as mentioned above, the thing will not use all of the possible surface area, and even if the divider was built for a closer fit some portion of flow volume will bypass the active galleries anyway, so it's unlikely to deliver good heat output. Send it back with a nasty note.
Adding to my comments above, the matrix they chose was obviously meant for end-to-end flow and they just stuck different endcaps on it without considering the in-and-back flow pattern at all. Stupid. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Tue Jan 22, 2019 1:48 pm Post subject: Re: Beware of Thermex brand front heater core |
Well I just received my brassworks core...
And the damage to the paint from the expanding foam it was packed in.
And the OE vw core and its 100% seal between inlet and outlet. Geez I wonder why they went to the effort of doing that.
Posted: Tue Jan 22, 2019 2:08 pm Post subject: Re: Beware of Thermex brand front heater core |
Just talked to Mike at Van-Café. They do not sell thermex, they only sold them briefly. They have their heater cores made for them. They are all aluminum. The black paint on these heater cores I have smells nasty. |
Gruppe B Samba Member
Posted: Tue Jan 22, 2019 2:31 pm Post subject: Re: Beware of Thermex brand front heater core |
What did Brassworks say when you called them? Can't anyone make a heater core?
Terry Kay would have had some great comments for this thread |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3796 Location: VA/TN
Posted: Tue Jan 22, 2019 2:47 pm Post subject: Re: Beware of Thermex brand front heater core |
Yes please keep me posted on the Brassworks deal. _________________ Brandon
Instagram @joannthevan |
Posted: Tue Jan 22, 2019 3:57 pm Post subject: Re: Beware of Thermex brand front heater core |
Brassworks said go ahead and return it. Ya to be honest a heater core is the last thing I thought I'd have problems replacing. I started to look for a core to rebuild my original heater core but that would take a while to source, if even possible.
I'm real close to just putting a wood stove where my passenger seat should be. Lots of room in the back for wood. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32591 Location: Reading Pennsylvania
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4775 Location: Bemidji, MN
Posted: Tue Jan 22, 2019 4:05 pm Post subject: Re: Beware of Thermex brand front heater core |
i am so disappointed to 'see the light' on the Brassworks core. this is the one i had highest hopes for and to have that blatant cross connection, WTF. just wow. glad they are taking it back.
had a friend with a Ford Econoline van with a wood stove in the back. they lived 20 miles outside of town with 3 little girls back in their hippie days and would fire up the stove before heading to town. worked great at -30F. _________________ -dan
www.thefixitworkshop.com |
brassworks Samba Member
Joined: December 06, 2016 Posts: 3 Location: Paso Robles, CA 93446
Posted: Tue Jan 22, 2019 5:18 pm Post subject: Re: Beware of Thermex brand front heater core |
I have not dissected the other designs out there but understand heater cores, radiators and heat exchange theory enough to comment on this post.
The vanagon heater core made by the Brassworks is baffled. If you "saw" it in half you will find a vertical baffle on the bottom that is soldered to the header and an adjacent baffle on the top that is soldered to the inside of the tank. The two nest against each other inside the length of the tank and route the fluid down the top 1/2 the core where it enters the unbaffled tank and routes back the bottom 1/2 to the other connection.
Light has an uncanny ability to sneak through the seam of the two plates but light is light and fluid is fluid. Fluid tends to take the path of least resistance via the tubes. I understand that this customer was concerned about light and so encouraged him to simply return it.
Not sure what caused the paint damage and would not be in a position to comment on that.
DanHoug and djKeev if you have further questions you can call me directly. 805.239.2501 |
Posted: Tue Jan 22, 2019 5:34 pm Post subject: Re: Beware of Thermex brand front heater core |
thank you, Brassworks, for monitoring and responding. i'll be in the market for more cores so i will give you a call sometime. i'd started this other thread on Brassworks cores so it is really good to hear from you again. speaks well of the company.
https://www.thesamba.com/vw/forum/viewtopic.php?t=696178&highlight= _________________ -dan
Posted: Tue Jan 22, 2019 8:45 pm Post subject: Re: Beware of Thermex brand front heater core |
The vanagon heater hoses are very long so there is not a lot of flow through the hoses at idle. The heater core needs to flow without bypassing at all. It was a windchill of -22 F the other day. A heater that works good in California might not cut the mustard up here. |
Posted: Tue Jan 22, 2019 9:05 pm Post subject: Re: Beware of Thermex brand front heater core |
brassworks wrote: |
Brassworks,
Can I ask if you would be able to take some photos at work tomorrow of an unassembled unit and post them here to clarify your description above?
It would be greatly appreciated by many (and I might suggest that you should probably consider building up inventory if they clearly and satisfactory show us the path the hot water takes, I suspect your sales might spike)
Ghia
Vanagon
Beetle
T3messie Samba Member
Joined: October 03, 2017 Posts: 209 Location: Germany
Posted: Wed Jan 23, 2019 12:34 am Post subject: Re: Beware of Thermex brand front heater core |
loki475 wrote: |
Why didnīt you use that good looking core? |
Posted: Wed Jan 23, 2019 10:59 am Post subject: Re: Beware of Thermex brand front heater core |
We make to order and have just completed a batch. When we sell through we'll make another batch. I will try to remember to send you images of the construction and specifically a baffle assembly. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Wed Jan 23, 2019 11:52 am Post subject: Re: Beware of Thermex brand front heater core |
^^^ Looking forward to this...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Wed Jan 23, 2019 2:13 pm Post subject: Re: Beware of Thermex brand front heater core |
T3messie wrote: |
loki475 wrote: |
Its a deceiving picture. The fins all along the bottom are corroding, basically crumbling into dust. The corrosion has reached the first row of tubes and the rubber seal for the first tube is splitting. Trust me I would have stayed with an oe vw part if I could have. Sometimes I stay up late scouring the farthest reaches of the internet for genuine vw parts. Unfortunately this time my search came up with nothing. |
Posted: Wed Jan 23, 2019 4:11 pm Post subject: Re: Beware of Thermex brand front heater core |
brassworks wrote: |
Now, understand this is just ME thinking out loud here........
But
IF I were making my living making a specific item and one of my products turned up in a forum catering to owners and DYI'ers and the comments made weren't really all that favorable about my product ......
I sure as heck would go out to the shop the next morning and yell for Charlie to come see me.
I'd Give him specific insteuctions to make just one of the item and to have Mary with you to record and photograph the process documenting and showing the interior baffles and such.
I would then go back to my office, draw a colored diagram of coolant flow and explain why this method works so well vs while VW clearly sealed the same unit into two halves.
I'd probably have a testing setup in the shop somewhere, I'd clean it off and hook this unit up to it and then using an infrared heat gun and dyed water show not only the flow but how the temperature rises quickly and evenly saturates the unit.
Why?
Because it is Winter, people are finding out that they need a new item and come Summer they will block off the coolant flow and put it off until next Fall.
I'd want to convince people to buy mine NOW!!
I also would really want this fairly tight knit community to tell others they meet, "call brassworks, every other one on the market is crap".
But that's just me.......... My Van still has the OG German one in it from 1986.
Hmmmmmm I might be one of those shoppers soon!
Ghia
Vanagon
Beetle
