TheDon Samba Member
Joined: July 14, 2005 Posts: 498 Location: Windermere
Posted: Fri Feb 03, 2017 3:14 pm Post subject: Metal sunroof to solid roof? |
As I sit in my bug tearing the ripped to shreds headliner out I'm curious if I can easily remove the subroof pan and weld up the giant hole? Mine is a '64 so it's no ragtop and I'm not a big fan of sunroofs plus mine is missing 75% of everything to make it work so I'm looking at $$$$ to have a giant hole in my roof that leaks water.
I could easily list he sunroof stuff for sale. I'm just curious if I have to do a roof clip or if I can just drill out all of these spot welds. _________________
lawn ninja wrote: |
Every time I crush a fat chick I feel like a I save baby kittens and baby kittens are important to everyone. |
TheDon Samba Member
Posted: Fri Feb 03, 2017 3:21 pm Post subject: Re: Metal sunroof to solid roof? |
Or I could make it a rag top.....and not have to repaint.....hmmmw _________________
lawn ninja wrote: |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Fri Feb 03, 2017 3:25 pm Post subject: Re: Metal sunroof to solid roof? |
Metal sunroofs do not leak!
They are designed to drain the water that gets past the dust seals . . . similar to the way your door glass seals will let water past only to drain out the bottom of the door.
If you let your sunroof drain tubes plug-up, the water WILL back up and get into your interior. Do not confuse that by saying you sunroof leaks!
It will take you a few minutes to clear those drains, but if that is too much trouble, yes it is possible to weld in a filler piece and then cover half the roof with Bondo! _________________ Jesucristo es mi Seņor y Salvador! |
TheDon Samba Member
Posted: Fri Feb 03, 2017 3:32 pm Post subject: Re: Metal sunroof to solid roof? |
I could get a section of roof from a solid roof bug and patch it in?
Or just spend the money and fix the sunroof.
I'm going to talk to the VW shop in Orlando and talk to them about it _________________
lawn ninja wrote: |
Posted: Fri Feb 03, 2017 4:00 pm Post subject: Re: Metal sunroof to solid roof? |
Clearing the drains will cost you nothing!!!!!!! _________________ Jesucristo es mi Seņor y Salvador! |
KTPhil Samba Member
Posted: Fri Feb 03, 2017 4:07 pm Post subject: Re: Metal sunroof to solid roof? |
If yours is an original sunroof car, then the drains are there. Clearing them (and maybe replacing the clear connecting hoses), and patiently waiting for parts to come up in the classifieds (or scouting junkyards), and you will have all you need. There are threads about rebuilding it so it works like new. |
TheDon Samba Member
Posted: Fri Feb 03, 2017 4:14 pm Post subject: Re: Metal sunroof to solid roof? |
57BLITZ wrote: |
Clearing the drains will cost you nothing!!!!!!! |
Yeah but when everything except the sunroof panel is missing it's expensive to bring it back.
I just snaked the drains and they are clear. _________________
lawn ninja wrote: |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
jzjames Samba Member
Joined: September 27, 2007 Posts: 1921 Location: Windy Point, WA
Posted: Fri Feb 03, 2017 7:16 pm Post subject: Re: Metal sunroof to solid roof? |
Go with finding a donor roof and patch it in. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Feb 04, 2017 6:41 am Post subject: Re: Metal sunroof to solid roof? |
While a properly working and draining steel sliding sunroof is great and generally do not leak from the roof.. they do drain into very bad places..
Not a bad option to have.. but needs improvements.
The front drains drip into the A pillars... and ...we all know the A pillars never rust out..
The rear drains drip over the running board and heater channel at the lower edge of the quarter panels.. and ....we all know the heater channels, rockers, and running board mounts never rust out..
IMO.. no parts... = make it solid ..Even if that means.. using a stock sunroof panel as the base to simply seal in place and correct the drains.. or weld the panel or a roof graft panel into place.. and forgetaboutit.
Parts are fairly easy to source if you search and place want ads.
Sliding Ragtops are nice... simpler than the metal..ad an older appeal but are pricey to graft in especially if you have to source a donor and pay someone to hack it in.
Then....since its now a graft.. if a sale is in even at all a possible future.. the Vw snobs will tear it apart and nit pick it to death.. especially if its a 65 and newer..
When and if you have the parts (for others) and want it.. at least move the drains to better locations.
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
j.goodspeed Samba Member
Posted: Sat Feb 04, 2017 8:31 am Post subject: Re: Metal sunroof to solid roof? |
With a bit of work and patently sourcing parts, you can make it work. I love having a sunroof with a set of pop out windows for airflow. _________________ Jeremy Goodspeed
www.goodspeedmotoring.com
www.goodspeedmotoring.net |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sat Feb 04, 2017 5:13 pm Post subject: Re: Metal sunroof to solid roof? |
... 10 people will have 10 different opinions... is just a matter of preference.
my 2 cents is all 3 versions could be enjoyable... 1. I think metal sunroofs are not worth the trouble,. they are tiny and unattractive. 2. solid roof would be my preference. 3. rag tops are great. 3 folds are the way to go, but expensive... 2 folds are less expensive, a great size when open, a little more work to install and to maintain...
... if I had a choice, I'd take solid with pop-out rear quarters... a real cheap way to go might be to (clear) silicone the silly metal roof closed and add pop-outs. _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Feb 04, 2017 5:52 pm Post subject: Re: Metal sunroof to solid roof? |
I've had 2 new vehicles with sunroofs. I hate the stupid things. They take up headroom and the manufacturers tack them on with other options that you want so you HAVE to get the $1200+ sunroof to get the other stuff.
Having said that, I LOVED the sunroof on the '63 ragtop Beetle I had. Would probably still have it if some idiot in a Mercury Marquis hadn't run a red light and totaled it for me about 25 years ago. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
TheDon Samba Member
Posted: Sat Feb 04, 2017 7:02 pm Post subject: Re: Metal sunroof to solid roof? |
ZENVWDRIVER wrote: |
... if I had a choice, I'd take solid with pop-out rear quarters... a real cheap way to go might be to (clear) silicone the silly metal roof closed and add pop-outs. |
I'm not siliconing it closed. I have a bit more class than that. I'm going to ask my local shop Monday about going solid. _________________
lawn ninja wrote: |
Posted: Sat Feb 04, 2017 7:08 pm Post subject: Re: Metal sunroof to solid roof? |
TheDon wrote: |
I'm not siliconing it closed. I have a bit more class than that. I'm going to ask my local shop Monday about going solid. |
... guess I am lower class as I silaconed my T-T-tops on my 1993 mr2,,, did a very neat job for a low class guy. No sealer could be seen at all. _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
TheDon Samba Member
Posted: Sat Feb 04, 2017 7:37 pm Post subject: Re: Metal sunroof to solid roof? |
If I'm painting the car I kind of don't want to silicone it shut. I'd rather do it right the first time. Which is either repair thebsunroof or convert to solid roof _________________
lawn ninja wrote: |
EVfun Samba Member
Posted: Sat Feb 04, 2017 7:55 pm Post subject: Re: Metal sunroof to solid roof? |
1964 is the only year of the small window Bug that came with the sliding steel sunroof. It is a unique thing to that year and removing one is likely bad for future resale value. That said, it is your car and do what you want with it.
It should be no issue to weld in a section of roof from another Bug. You should be able to use a roof section from any year Bug to make the patch as it is well back from the windshield.
Personally, I avoid convertible and sunroof Bugs. I live in a place where it never gets over 100F, but it rains over 150 days a year (Seattle.) _________________
Wildthings wrote: |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat Feb 04, 2017 8:28 pm Post subject: Re: Metal sunroof to solid roof? |
EVfun wrote: |
1964 is the only year of the small window Bug that came with the sliding steel sunroof. ... That said, it is your car and do what you want with it.
(Seattle.) |
Thank you for being the first one to say this. '64 sunroof cars are the rarest of any sunroof series- production since the early 50s. Ragtop cars outnumber SR '64s at least 10:1. I'd throw a bag of kittens in the river to own one (I hope you're not reading this Clara).
I'd fix the thing- period. If you can't find a sunroof parts car at a junkyard for $75 then you're not looking. _________________
EverettB wrote: |
FU#5 |
67ctbug Samba Member
Posted: Sat Feb 04, 2017 8:51 pm Post subject: Re: Metal sunroof to solid roof? |
I was going to say the same thing. They are very rare, being one year only. I wouldn't suggest closing it. It may be hard to fix, but it will be worth it in the end. The rarity is there and sunroof cars always go for more if you ever decide to sell it. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Posted: Sat Feb 04, 2017 8:55 pm Post subject: Re: Metal sunroof to solid roof? |
SBD wrote: |
Having said that, I LOVED the sunroof on the '63 ragtop Beetle I had. Would probably still have it if some idiot in a Mercury Marquis hadn't run a red light and totaled it for me about 25 years ago. |
... can relate, the love of my life (1993 Civic Si) with tilt sun roof and 392K miles was broadsided by a huge speeding Ford Victoria police cruiser in 2007...
1960 single cab
'87 Toyota MR2
