hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Feb 19, 2018 9:22 pm Post subject: Re: Brake/Tailight Issue |
Eric&Barb wrote: |
hitest wrote: |
How does this sound Eric and Barb combo? |
Possible, but hard to say for sure. Bad grounds can cause such crazy things to happen. |
I was re-grinding grounds in my garage because this exact event happened- a faint glow as the filaments tried to seek earth. I never messed with the M/C switch- but you are absolutely right- crazy stuff happens due to poor grounds. It can become a "bop the squirrel" game really quickly. _________________
EverettB wrote: |
FU#5 |
Mark Evans Samba Member
Joined: April 21, 2004 Posts: 1931 Location: Alsea,Oregon
Posted: Sat Jul 13, 2019 5:34 am Post subject: Re: Brake/Tailight Issue |
This is to serve as an update, but here's what it turned out to be: I took the bug to a reputable VW shop. They found a lead from the wiper motor shorting out. Also had to pull the steering wheel and clean out the turn signal switch from hair, dirt, and goo. Grounds were all good, as I thought. So, for $165 she's back on the road! _________________ '63 Ragtop |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Sat Jul 13, 2019 7:04 am Post subject: Re: Brake/Tailight Issue |
Mark Evans wrote: |
This is to serve as an update, but here's what it turned out to be: I took the bug to a reputable VW shop. They found a lead from the wiper motor shorting out. Also had to pull the steering wheel and clean out the turn signal switch from hair, dirt, and goo. Grounds were all good, as I thought. So, for $165 she's back on the road! |
Wow !!! Good that it's fixed. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24759 Location: Olympia Wash Rinse & Repeat
Posted: Sat Jul 13, 2019 8:46 am Post subject: Re: Brake/Tailight Issue |
Great! _________________ In Stereo, Where Available! |
