Vnyd Dog Samba Member
Posted: Fri Feb 03, 2017 7:18 pm Post subject: 1.8T owners- Help with flashing temperature/coolant light. |
I'm looking for help diagnosing the constant flashing temperature coolant light but specific to a 1.8T conversion. I've read the threads on bad connections at the reservoir tanks. I looked into my bay this afternoon, topped up the coolant and still have the constant light. Just curious if diagnosing would be the same as stock? It appears the reservoir and sensors are different and possibly from the Jetta type. Any help or ideas is are appreciated. I couldn't find an expansion tank. Just a round globe shaped reservoir that looked a little low. _________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
https://www.thesamba.com/vw/forum/viewtopic.php?t=713391&highlight=life |
greebly Samba Member
Joined: August 27, 2009 Posts: 966 Location: Here and now
Posted: Fri Feb 03, 2017 7:32 pm Post subject: Re: 1.8T owners- Help with flashing temperature/coolant light. |
Same circuit as an unconverted van. Clean your sensor. |
1621 Samba Member
Posted: Sat Feb 04, 2017 12:28 am Post subject: Re: 1.8T owners- Help with flashing temperature/coolant light. |
I've had this issue before, usually after a coolant change and there is still some air in the lines. Run up to temp, then park on a mild incline with the nose down. Wait for the temp to cool a little and the coolant level to settle, top off your coolant - the globe - and you should be good to go. _________________ '85 Westy |
Posted: Sat Feb 04, 2017 7:21 am Post subject: Re: 1.8T owners- Help with flashing temperature/coolant light. |
Hmmm, well I've figured out this is the Mark IV Jetta Expansion tank. The connection plug to the exterior of the tank looks clean. No corrosion since it's basically new. Is it possible I'd need to replace the tank since it contains the sensors? It's $20.
The Story:
rubbachicken Samba Member
Posted: Sat Feb 04, 2017 7:40 am Post subject: Re: 1.8T owners- Help with flashing temperature/coolant light. |
put a jumper wire between the 2 terminals in the sensor, if flashing lights stop, change the sensor, is still flashing, go to the box, where number 3 cylinder was on the WBX, there are 2 7 pin round connectors in there, one is for the lights, the other is for the engine etc, split that plug, find the color wire from the level indicator, put that to ground, if the light goes out, you know you are looking at the plug being bad, if still flashing, pull the fuse box down so you can see the relays, i think it's 42 or 43,
okppppppppppppppppppppppppppppp
mlo;jkjpomljnuiiiiiiiiiiiiiiiiiii _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
Posted: Sat Feb 04, 2017 8:14 am Post subject: Re: 1.8T owners- Help with flashing temperature/coolant light. |
rubbachicken wrote: |
mlo;jkjpomljnuiiiiiiiiiiiiiiiiiii |
On this tank, it's not like the stocker. The probes don't come out. It's all one piece. Did you mean the paperclip test between probes? That won't work with this tank since the probes don't come out. I will try the relay in the fuse panel next. This shows it better
The Story:
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Sat Feb 04, 2017 12:39 pm Post subject: Re: 1.8T owners- Help with flashing temperature/coolant light. |
I have a Passat tank on my 1.8t, same built in sensor. I would suspect the connection where it's tied into the stock wiring first. Then expand my search to the entire run back to the dash. Good luck. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
hans j Samba Member
Joined: May 06, 2006 Posts: 2715 Location: Salt Lake City UT
Posted: Sat Feb 04, 2017 1:17 pm Post subject: Re: 1.8T owners- Help with flashing temperature/coolant light. |
Those level sensors rarely go bad.
Rubber chicken is saying put the paper clip in the wire side of the electrical connector. If the light still flashes, it's in the wiring, connections, relay, or gauge.
If the temp gauge is going up, we need to know what they did to sense coolant temp on the engine. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Posted: Thu Feb 16, 2017 8:36 am Post subject: Re: 1.8T owners- Help with flashing temperature/coolant light. |
As an update and more troubleshooting, the light remains on flashing intermittently. About 24 hours after topping off the coolant, the light started functioning properly. I thought Eureka! Alas, it has returned to it's strange ways. Recently while it was flashing, I pulled the relay stamped "43", I think that's the right one, and the light stayed flashing. Was that the proper relay to try and pull and after pulling it with the light still blinking, does that indicate the cluster gauge itself is the issue? _________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Thu Feb 16, 2017 9:58 am Post subject: Re: 1.8T owners- Help with flashing temperature/coolant light. |
If the flashing continues with the "43" pulled then the problem is NOT anything to do with the coolant level warning system. That leaves the dash area as the likely area of interest.
Mark
Vnyd Dog wrote: |
As an update and more troubleshooting, the light remains on flashing intermittently. About 24 hours after topping off the coolant, the light started functioning properly. I thought Eureka! Alas, it has returned to it's strange ways. Recently while it was flashing, I pulled the relay stamped "43", I think that's the right one, and the light stayed flashing. Was that the proper relay to try and pull and after pulling it with the light still blinking, does that indicate the cluster gauge itself is the issue? |
