Trans code list?
revD
revD is offline
PostPosted: Thu Dec 24, 2015 11:08 am    Post subject: Trans code list? Reply with quote
Hey,
I am gonna pick up a tranny in a couple days and just want to verify whatever code is on the side, I have looked at the below list before but it now seems in-active. I regret not saving the sheet - but does anyone have the trans code listings saved? I am looking for the 5spd codes.
TIA !
http://www.brick-yard.co.uk/VehicleSpecific/T3/info/gbx.htm
Current:
87 Sunroof - weitec springs, 17x7.5 et35 KT1 - 265k on original drive-train
past:
'85 DOKA - 1.9l of fury
http://doka-d.tumblr.com/
syncrodoka
syncrodoka is offline
PostPosted: Thu Dec 24, 2015 11:39 am    Post subject: Re: Trans code list? Reply with quote
2wd I assume?
http://rjes.com/html/gearbox_types.html
http://vwt3.com/t3-tech/t3-data/t3-gearbox-codes/
hdenter
hdenter is offline
PostPosted: Thu Dec 24, 2015 11:52 am    Post subject: Re: Trans code list? Reply with quote
I use the one from Shaw. It's not as complete a list, but it has a calculator built into it that let's you plug in different tire sizes and gear ratios to get mpr. I don't have it on my phone, I'll post the link when I get home if no one else has beat me to it.
Hans
'79 triple white convertible bug
'84 sunroof vanagon
'85 weekender
hdenter
hdenter is offline
PostPosted: Thu Dec 24, 2015 4:31 pm    Post subject: Re: Trans code list? Reply with quote
http://www.google.com/url?sa=t&rct=j&q=&am...Sy_QPUp8Yw
Try this link for the trans ratio chart and calculator. I have spent hours running different combinations of tires sizes and gear ratios in search of what I want for my vans.
Hans
'84 sunroof vanagon
'85 weekender
revD
revD is offline
PostPosted: Fri Dec 25, 2015 4:58 pm    Post subject: Re: Trans code list? Reply with quote
Thanks all!! Perfect.
Current:
past:
Syncrozilla
Syncrozilla is offline
PostPosted: Mon Jan 30, 2017 9:42 pm    Post subject: Re: Trans code list? Reply with quote
Does anyone know where there is a current comprehensive list of T3 trans codes/gear ratios? All the links above are now dead. Except the T3 one which does not list front diffs. I can no longer find the one that used to be on club 80/90.
Please do not message me on TheSamba. Use my email, [email protected]
kamzcab86
kamzcab86 is offline
PostPosted: Mon Jan 30, 2017 10:31 pm    Post subject: Re: Trans code list? Reply with quote
http://vwt3.com/t3-tech/t3-data/t3-gearbox-codes/ (includes auto trans codes)
http://www.partsemporium.co.uk/GUIDE%20to%20VW%20T3%20t25%20gearbox%20codes.htm
2016 Golf GTI S
Syncrozilla
PostPosted: Mon Jan 30, 2017 10:55 pm    Post subject: Re: Trans code list? Reply with quote
Thanks Kammy. Unfortunately none of those list the syncro front diffs which is what I'm looking for Confused
The club 80/90 had that info but I think it's gone now. I should have printed it out and stuck it in my bentley.
kamzcab86
PostPosted: Tue Jan 31, 2017 12:19 am    Post subject: Re: Trans code list? Reply with quote
Really? Darn... didn't notice. Embarassed
Wayback Machine to the rescue!
https://web.archive.org/web/20060513084317/http://...os%205.htm Very Happy
Got the original link to put into the time machine from http://www.syncronauts.org.uk/syncro-technical/syn...front-diff .
2016 Golf GTI S
BavarianWrench
BavarianWrench is offline
PostPosted: Tue Jan 31, 2017 1:15 am    Post subject: Re: Trans code list? Reply with quote
Thanks Kamz
that is a lot of info, I never stumbled across such a clearly laid out list before.
Well done
dobryan Premium Member
dobryan is offline
PostPosted: Tue Jan 31, 2017 5:59 am    Post subject: Re: Trans code list? Reply with quote
Any way to post that spreadsheet on this topic for future reference?
Dave O
The Western Syncro build
kamzcab86
PostPosted: Tue Jan 31, 2017 11:52 pm    Post subject: Re: Trans code list? Reply with quote
Working on a complete document that will combine all of the above-posted links... stay tuned. Wink
2016 Golf GTI S
dobryan is offline
PostPosted: Wed Feb 01, 2017 9:24 am    Post subject: Re: Trans code list? Reply with quote
You are the best! Very Happy
Dave O
kamzcab86
PostPosted: Fri Feb 03, 2017 4:15 pm    Post subject: Re: Trans code list? Reply with quote
Many, many, many hours' worth of work later, here it is:
T3/T25/Vanagon Transmission Specs
If anyone sees errors, or can fill in some of the blanks, let me know.
Cool
2016 Golf GTI S
BavarianWrench
PostPosted: Sat Feb 04, 2017 6:58 am    Post subject: Re: Trans code list? Reply with quote
Kamz nice effort, Thanks.
Jake de Villiers
Jake de Villiers is offline
PostPosted: Sat Feb 04, 2017 8:51 am    Post subject: Re: Trans code list? Reply with quote
Cool
Kam, that's a work of art - thanks!! Very Happy Very Happy
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
J Charlton Premium Member
J Charlton is offline
PostPosted: Sat Feb 04, 2017 12:40 pm    Post subject: Re: Trans code list? Reply with quote
here they are - pretty much every vanagon gearbox - you can use google translate for German to English but its pretty self explanatory
http://www.t3-infos.de/images/T3-Getriebe.pdf
NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024
