would you rather drive a Vanagon or walk? |
walk |
61% |
[ 8 ] |
drive a vanagon |
38% |
[ 5 ] |
Total Votes : 13 |
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Sun Mar 28, 2004 7:02 pm Post subject: are spring plates dangerous? |
So I have read in the ghia forum, cause I own a ghia too, and all those guys are scared sh*tless about adjusting their spring plates because they are loaded. As I am preparing to install my lowered spring plates on my bus I wonder, Am I going to loose a limb when I try and remove my old spring plates or is this a type1 thing? _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
23window Samba Member
Posted: Sun Mar 28, 2004 7:13 pm Post subject: |
you aren't going to loose a limb, even if you had a limb in the way. But keep your hands clear of that plate when you pull it loose. Put a large screwdriver behind it where you can get some leverage and work it out. It will let got about 1/2" at most once it clears the lip and that's it. Wear safety googles, make sure the bus is secure on jackstands, etc. |
Posted: Sun Mar 28, 2004 7:20 pm Post subject: |
20tre coming through for a brother. Thanks main. It would kinda put a damper on my VW hobby ifin I was an amputee. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Sun Mar 28, 2004 7:25 pm Post subject: |
you wanna see a powerful ass springplate, remove one on a type 3.
BOINGGGG!!!!!! _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Posted: Sun Mar 28, 2004 7:32 pm Post subject: |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Sun Mar 28, 2004 8:10 pm Post subject: |
The plates don't move that far. I also was scared the first time because people made it sound like it was going to spin like propeller but this is not true. What I do is push the spring plate up with a jack til it is off the stop then use a screwdriver wedged under the plate at the bottom to guide it passed the stop as you lower the jack. Once it is unloaded scribe the end casting so you will know where the original possition was and then use two screwdrivers to pry it off. It is really easy. _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
Skim Rants Master
Posted: Mon Mar 29, 2004 4:49 am Post subject: |
its really not scary at all. A bus spring plate is about suprising as opening a can of biscuits and hearing it pop. _________________ GFK
1953 Kabriolet
1954 Sunroof
Saggs Samba Member
Joined: December 23, 2003 Posts: 662 Location: Lincolnton, NC
Posted: Mon Mar 29, 2004 6:07 am Post subject: |
I had to LOL when reading Super Skims description of removing a type 3 spring plate! I don't know why but I just kept laughing, I think it's because we've all had near death experiences we did'nt even know about. _________________ "One man can make a difference...Jesus did." |
jerry.t Samba Member
Posted: Mon Mar 29, 2004 8:46 am Post subject: |
just put a floor jack undernieth the rear point of the plate, and pull it back
towars you and let it down slowley. should work fine. |
