Spitty1974 Samba Member
Joined: September 30, 2011 Posts: 647 Location: California
Posted: Sat Feb 04, 2017 10:58 pm Post subject: Front Door Hinge Inner Screw Hole Sheet Metal Notch Question |
I was wondering if members might be able to chime in regarding the front door jam area on a 1966 deluxe bus?
Would you be able to tell me if the bent sheet metal area where the two inner door hinge screws are located should be intact and not have any metal removed (like in the photo below/, photo not of my bus) or if it should be solid metal with no material removed?
I'm not sure if it was done by a previous owner on my bus, or if maybe they started drilling the area out at the factory so that it would be easier for the screws to be placed in and tightened?
I looked at some threads and pictures of older buses and they didn't have the metal removed from what I can tell. I wasn't sure if it was one of those things they started doing around 1966/1967?
What is the consensus regarding the holes?
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
RMinNC Samba Member
Joined: August 20, 2013 Posts: 11 Location: North Carolina
Posted: Sun Feb 05, 2017 9:36 am Post subject: Re: Front Door Hinge Inner Screw Hole Sheet Metal Question |
My 66 has it and appears original - when I removed my doors it appears necessary to get to the innermost screws at the correct angle. |
coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Mon Feb 06, 2017 12:47 pm Post subject: Re: Front Door Hinge Inner Screw Hole Sheet Metal Notch Question |
The '65 SC that I used to have was notched like the photo. _________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
Stocknazi Samba Member
Posted: Mon Feb 06, 2017 4:06 pm Post subject: Re: Front Door Hinge Inner Screw Hole Sheet Metal Notch Question |
Maybe this can be found in Progressive Refinements?
I have seen the same notches, but never thought they were factory. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Wed Feb 08, 2017 11:05 am Post subject: Re: Front Door Hinge Inner Screw Hole Sheet Metal Notch Question |
Thank you for all that gave responses.
Anyone else have insight to the notches?
I looked at the refinements PDF on the site as suggested by StockNazi, but didn't really see anything.....That said, I looked between 63-66 and most info listed I believe was related to the engine. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Wed Feb 08, 2017 11:46 am Post subject: Re: Front Door Hinge Inner Screw Hole Sheet Metal Notch Question |
'65, '66, and '67 all have that: factory. Maybe previous year(s) but my touchy feeley ends at '65 recently.
I can tell you from experience it makes it super easier to get out the inboard screws when using an impact screwdriver. |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Feb 08, 2017 12:59 pm Post subject: Re: Front Door Hinge Inner Screw Hole Sheet Metal Notch Question |
BarryL wrote: |
'65, '66, and '67 all have that: factory. Maybe previous year(s) but my touchy feeley ends at '65 recently. . |
The notches are missing in April 1963 DC
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Wed Feb 08, 2017 2:02 pm Post subject: Re: Front Door Hinge Inner Screw Hole Sheet Metal Notch Question |
I have them in my 60 SC. They are access holes for the door hinge screws |
sgellis Samba Member
Joined: July 06, 2016 Posts: 2014 Location: SW Nova Scotia, Canada
