SCM Samba Member
Joined: January 26, 2011 Posts: 3115 Location: Bozeman MT
Posted: Mon Feb 06, 2017 1:06 pm Post subject: Can engine oil get into torque convertor? |
Just curious, is it possible for a bad seal or some other failure in a WBX engine to cause motor oil to get into the transmission WITHOUT having any other detectible leaks?
I'm wondering if my excessive oil consumption is somehow related to some autotrans issues I'm having. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2795 Location: North Carolina
Posted: Mon Feb 06, 2017 1:32 pm Post subject: Re: Can engine oil get into torque convertor? |
I'm fairly certain the short answer is no. It bolts to the flex plate and slides onto the AT, click-click-click. No path for engine oil migration. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
kourt Samba Member
Joined: August 13, 2013 Posts: 1944 Location: Austin, TX
Posted: Mon Feb 06, 2017 1:36 pm Post subject: Re: Can engine oil get into torque convertor? |
The only way this could happen would be if you had the original ATF cooler installed, and there was an engine oil leak into the coolant, and then contaminated coolant intermixing via a leak in the ATF cooler--and even then you would have "milkshake" (coolant and ATF mixed) and not engine oil. Otherwise, there is no direct connection between ATF circuits and engine oil circuits.
Intermixed ATF and coolant looks like strawberry milkshake.
Tell us about your transmission issues.
kourt |
SCM Samba Member
Posted: Mon Feb 06, 2017 1:46 pm Post subject: Re: Can engine oil get into torque convertor? |
kourt wrote: |
kourt |
I'd rather you shed light on my oil consumption issues
It knocks when downshifting into first. It's not a mount or the CVs either. The trans sometimes also slips when you first try to move it on cold mornings. I think I talked about most of it in this thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=665323&highlight=auto+trans+clunk
I'm about to order a rebuilt unit but I'm a little nervous about how quickly the engine is using oil (about a Qt every 1,000 miles but no leaks, no discolored coolant, and no blue smoke out of the exhaust). I would hate to buy a rebuilt tranny with stock ratios only to end up wishing that I had something else if I did an engine conversion soon after.
While pondering all of this I got to wondering if the two issues could be related. Sounds like a "no". _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4349 Location: United States, Iowa
Posted: Mon Feb 06, 2017 2:06 pm Post subject: Re: Can engine oil get into torque convertor? |
There is, of course one other way either of the fluids can get into the wrong places.... But you'd all thought of the obvious way, right?
Whoops!!! _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Energy Concepts Samba Member
Joined: March 12, 2007 Posts: 352 Location: Yacolt, WA
Posted: Mon Feb 06, 2017 2:17 pm Post subject: Re: Can engine oil get into torque convertor? |
bobbyblack wrote: |
Whoops!!! |
ummm ... it got poured in there ??? heh...heh...
(anything under the sun theory )
Last edited by Energy Concepts on Tue Feb 07, 2017 3:51 pm; edited 1 time in total |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17124 Location: Retired South Florida
Posted: Mon Feb 06, 2017 2:21 pm Post subject: Re: Can engine oil get into torque convertor? |
I don't believe you will see a quart in a 1000 miles as smoke out the tailpipe. That is actually considered acceptable oil consumption. I imagine though the sparkplugs would probably have some soot on them if it is passing oil. _________________ ☮️ |
Terry Kay Banned
Just for the heck of it , and because I didn't see it mentioned, have you serviced the trans since last October?
No engine oil should be in the converter. _________________ T.K. |
Posted: Mon Feb 06, 2017 2:30 pm Post subject: Re: Can engine oil get into torque convertor? |
[quote="Energy Concepts"]
bobbyblack wrote: |
Whoops!!! |
I pre-charge torque converters,
but, with ATF
kourt Samba Member
Posted: Mon Feb 06, 2017 2:39 pm Post subject: Re: Can engine oil get into torque convertor? |
SCM wrote: |
I would hate to buy a rebuilt tranny with stock ratios only to end up wishing that I had something else if I did an engine conversion soon after. |
You probably already know this, but in automatics the only gear ratio change is made in the differential (ring & pinion) and not the transmission--so you can go ahead and replace or rebuild your transmission and worry about your differential later.
These automatics are so easy to rebuild. You could buy about $150 in parts and do an admirable job on your own with some help from various Samba threads.
I had to laugh about your oil consumption comment. Wish I could help there. 1qt/1000 miles seems okay for an older boxer. Check the spark plugs.
kourt |
SCM Samba Member
Posted: Mon Feb 06, 2017 2:48 pm Post subject: Re: Can engine oil get into torque convertor? |
kourt wrote: |
kourt |
Check my sig line. There's nothing old about it and it only has about 30k miles on it. GoWesty also says I shouldn't worry about it but it didn't lose a drop between oil changes until the last 5k miles. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
SCM Samba Member
Posted: Mon Feb 06, 2017 2:49 pm Post subject: Re: Can engine oil get into torque convertor? |
bobbyblack wrote: |
Whoops!!! |
I don't recall siphoning oil from my crankcase and then pouring into my ATF filler. I do sleep walk from time to time though... _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
SCM Samba Member
Posted: Mon Feb 06, 2017 2:58 pm Post subject: Re: Can engine oil get into torque convertor? |
Terry Kay wrote: |
No engine oil should be in the converter. |
I haven't touched it since the mechanic looked at it in October. I expected the mechanic to change the ATF if he thought it was the problem. When he didn't even recommend it I decided to park it for the winter and deal with it when it got closer to camping season.
I took it to one of the few shops that works on Vanagons in my town and they basically spent 30 minutes checking for obvious stuff, dumped some "conditioner" into the ATF and then recommended a rebuild from GTA.
There's a number of reasons I'd rather not rebuild my own tranny but I am thinking of getting a second opinion as to what might be wrong. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
avernon82 Samba Member
Joined: July 07, 2015 Posts: 292 Location: Richmond,CA
Posted: Mon Feb 06, 2017 9:48 pm Post subject: Re: Can engine oil get into torque convertor? |
Seems like overkill to get a completely rebuilt trains for this one issue. Sounds like a sticky valve in your valve body to me |
Terry Kay Banned
Posted: Mon Feb 06, 2017 9:56 pm Post subject: Re: Can engine oil get into torque convertor? |
So, in light of this iddue, you did not drop the pan, change the filter, and fill the trans with type F fluid ?
Why?
You'll wait till it's time to use it this spring, and then start wailing?
Crazy. _________________ T.K. |
SCM Samba Member
Posted: Tue Feb 07, 2017 8:28 am Post subject: Re: Can engine oil get into torque convertor? |
Terry Kay wrote: |
Why?
Crazy. |
Because...
- I always park the van in late October. I don't use it in the winter so no rush to bother with it.
- I don't have a heated garage. Montana is cold (January was the coldest in 40 years, in fact). So no rush to bother with it.
- It's not my daily driver. It's a hobby that I choose not to stress out over. Certainly no need to wail. So no rush to bother with it.
- Spring, or at least comfortable wrenching weather, is another 2 or 3 months away. So no rush to bother with it.
Do you see the pattern here? Essentially, anything having to do with the van is a warm weather activity. I have other things I'd rather do in the winter. This is about the time of year I start planning my van trips/projects.
I stopped wailing over cars during my teenage years. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
jberger Samba Member
Posted: Tue Feb 07, 2017 9:21 am Post subject: Re: Can engine oil get into torque convertor? |
If you have a sudden oil consumption issue with a non stock engine, perform a leak down test first. Valve guides can also create this issue. Check your intake runners with an infrared temp gun. Also check your breather tower. Do you see excess oil sitting in your intake track? |
Terry Kay Banned
Posted: Tue Feb 07, 2017 9:26 am Post subject: Re: Can engine oil get into torque convertor? |
"Because" is a great reply, it took a bunch of thought.
I didn't ask why you didn't do the filter & oil change in January, I asked you why you didn't when you were posting about the problem in October.
That's 4 months of a gap there fella.
Yea, OK, no stress.
Above all else don't get excited , not until the day prior to you wanting to go somewhere.
No--wait about 15 minutes prior to turning the key.
That'd be good. _________________ T.K. |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1000 Location: Oakland CA
Posted: Tue Feb 07, 2017 10:28 am Post subject: Re: Can engine oil get into torque convertor? |
Do you hear any change in sound when you are moving and take your foot off the gas pedal, coasting in gear? I had bad knocking noise that was suspected by local Vanagon shop to be CV joints, but it turned out to be AT fluid in the differential. Drained all fluids in both cases and refilled and noise is gone. I still need to fix this seal, but this fluid refresh confirmed the problem. _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
SCM Samba Member
Posted: Tue Feb 07, 2017 10:33 am Post subject: Re: Can engine oil get into torque convertor? |
Terry Kay wrote: |
Yea, OK, no stress.
That'd be good. |
The same rational applies. I was shoveling snow and skiing in October, as I will be doing until April.
It's just a car Terry. It complies with MY schedule and isn't going to get any worse because of it. You're making some incorrect assumptions of how I value my time (and perhaps how late "spring" comes to my neck of the woods). If it's not fixed when I want to take my first camping trip of the year I'll simply the throw the tent and Coleman stove into my car - just like I'd done before I had my van. Pretty simple really. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
